Old Nov 04, 2012, 10:20 PM
John 59 is offline
Find More Posts by John 59
Relaxing in Singapore
Singapore
Joined Jan 2010
Hi John NZ,
Many thanks for your time and effort in producing and supporting the ZYX software.
I have used an earlier version and just downloaded the 1.22 version.
Question; I use a Futaba TX, how do I toggle between Condition 1 and Condition 2 on the first window. I have copied the two conditions to be the same to avoid any upsets, but using channel 5 switch on the TX has no effect (and I want to keep its function between rate and HH, anyway).
John 59 is offline Find More Posts by John 59
Old Nov 04, 2012, 11:00 PM
beenflying is offline
Find More Posts by beenflying
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
The "Cond 1" and "Cond 2" (above the connect lights, top right hand side) are buttons. Just click the button of the condition you want to switch to.
beenflying is offline Find More Posts by beenflying
Old Nov 04, 2012, 11:53 PM
John 59 is offline
Singapore
Joined Jan 2010
Thanks, Beenflying, I must of missed that in the previous posts. Is there any confirmation from the gyro of change or which Condition you are in.
Old Nov 04, 2012, 11:59 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Yes, the same buttons change color. IIRC the pinky/red color one is the current condition selected.
Old Nov 05, 2012, 04:43 AM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
I tried to get my home made bluetooth adapter to connect to the android app, but had no luck. Firstly, when it wasn't pair to the phone it came up with invalid password and once I'd manually paired it to the phone, it came up with unable to connect.
I've ordered the ZYX one from Infinity, so I'll report back if I have more success with that one.
Old Nov 05, 2012, 09:15 AM
Daddy. is offline
Find More Posts by Daddy.
Everyone is an idiot (or I am)
Daddy.'s Avatar
United States, TX, Red Oak
Joined Jun 2012
I've found bluetooth compatibility to be a PIA and haven't even tried it on the ZYX. However, it would be nice to have on the 500.
Good luck and keep us posted bf.
Best,
Ken
Daddy. is offline Find More Posts by Daddy.
Old Nov 07, 2012, 08:13 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Thanks, Ken.
Unless I'm flashing firmware to the ZYX, I use the bluetooth connection all of the time. It's super reliable using John's app. Just no luck with the android app, at this stage.
Probably if I figured out how to change the bluetooth ID, for my eBay units, to "ZYX BT", they might work with the android app. I'm not even sure it can easily be done, though.
Old Nov 11, 2012, 07:00 AM
Helinator is offline
Find More Posts by Helinator
Joined Nov 2012
Hello !
Its about the TAROT- or HK- ZYX-S FBL unit.
I am looking for the pin layout of the serial port (4 pins) located at the side of the unit.
(... the port for the USB- or Bluetooth- cable adapter)
Generally the signals are like: VCC, GND, RXD and TXD.
But which pin is which signal ?
Thanks !
Helinator is offline Find More Posts by Helinator
Old Nov 11, 2012, 07:11 AM
MikeHRC is offline
Find More Posts by MikeHRC
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
Originally Posted by Helinator View Post
Hello !
Thanks !
It's RS-232, so you have transmit (TXD) and receive (RXD),
MikeHRC is offline Find More Posts by MikeHRC
Old Nov 11, 2012, 07:59 AM
Joined Nov 2012
Hi MikeHRC.
As i already stated i know that it is VCC, GND, RXD and TXD.
(... and of course know what the meaning of the signals is, and that it is a RS-232)
I was asking about the PIN LAYOUT ...
=> pin1 (left)=?, pin2=?, pin3=?, pin4 (right)=?
... of these signals on the ZYX unit (!) ?
(maybe my english is to bad )
Thanks anyway.
Old Nov 11, 2012, 12:05 PM
DepronMan is offline
Find More Posts by DepronMan
Joined May 2005
have a look here http://fbl.net.nz/info/bluetooth you will see the pin out configuration. If you hold the blue tooth unit with the aerial on the left hand side and the pins on the right hand side, components facing you the BOTTOM two pins are the Ground and +Ve
Cheers,
Paul
DepronMan is offline Find More Posts by DepronMan
Old Nov 11, 2012, 12:17 PM
MikeHRC is offline
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
Hi MikeHRC.
Thanks anyway.
Sorry - I mis-read your post ...
FBL Bluetooth Interface
The Bluetooth unit can be obtained here: http://www.ebay.com/itm/290636551744
The 3GYS data lead here: http://www.rc711.com/shop/alzrc-3gys...le-p-5684.html
Name: DSC01916.jpg Views: 159 Size: 196.2 KB Description:
[Click pictures to enlarge]
The lead to the program box and USB link is:
GND - Red
VCC - Black
TXD - Red
RXD - White
Old Nov 11, 2012, 03:02 PM
Joined Nov 2012
OK, just to be sure ...
Looking at the port of the ZYX unit with the ZYX-logo-label of the unit facing up
the pins would be (from left to right) ...
pin1=GND pin2=VCC pin3=TXD pin4=RXD
Right ?
Old Nov 11, 2012, 03:45 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Deleted
Last edited by beenflying; Nov 11, 2012 at 03:55 PM. Reason: Sorry, already linked above to the same thing on John's site.
Old Nov 12, 2012, 01:13 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Right ?
Yes, this is correct.
Sold Darthdrk Drone CX Body for coax helis like the Blade CX etc. Twmaster Aircraft - Electric - Helis (FS/W) 0 Oct 08, 2011 07:31 PM
Multiplex mc V2 servo programming PC software Thomas B Radios 3 Jul 23, 2006 09:49 AM
