Old Oct 16, 2012, 06:06 PM
Dr.M is offline
Find More Posts by Dr.M
Dr.M's Avatar
United States, WA, Issaquah
Joined May 2011
Originally Posted by tonyastro View Post
I'm thinking of installing my CX gyro upside down. What do I need to reverse in the tx, gyro settings?
Definitely the compensation direction on tail and elevator, roll might be the same. The piro compensation direction will also likely change as well as the direction for the collective>tail and cyclic>tail precompensation. It's really not all that hard, just verify stick inputs and compensation and make sure it works as expected. BTW, I've got both my ZYX's mounted upside down under the tail boom.
Dr.M is offline Find More Posts by Dr.M
Old Oct 16, 2012, 09:02 PM
tonyastro is offline
Find More Posts by tonyastro
3D VFX Artist
tonyastro's Avatar
USA, CA, Monrovia
Thanks Doc!
tonyastro is offline Find More Posts by tonyastro
Old Oct 22, 2012, 01:01 AM
Hajile is online now
Find More Posts by Hajile
Philippines, Calabarzon, San Pedro
Joined Jul 2012
Wow 126 pages. I don't know which page this is so forgive me if it's already answered. But i just finished setting up my CX-3x1000 and it works fine but i don't know if i set the servo type right.
I got digital servos, but when i got to the part for the servo type, there must be three different digital tail servos in there. Which one am i supposed to pick?
http://www.ehirobo.com/shop/Servos-a...duct_info.html
Hajile is online now Find More Posts by Hajile
Old Oct 22, 2012, 05:55 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
You are kidding right?
Right in the specs. at link you posted.
Pulse width: 1520us
Working Frequency: 333Hz
here is a link to a fairly large group of servo's specs.
http://www.spartan-rc.com/resources/servodb/servo.php
Charles
Old Oct 22, 2012, 06:05 AM
Joined Jul 2012
Cool! I thought 1520 was a brand model or something.
Old Oct 23, 2012, 08:25 PM
kidlat is offline
Find More Posts by kidlat
Joined Aug 2011
Is there a difference between adjusting the tail gain from the gyro and adjusting it from the tx?
kidlat is offline Find More Posts by kidlat
Old Oct 23, 2012, 08:39 PM
2Doggs is offline
Find More Posts by 2Doggs
Two helis flying
2Doggs's Avatar
North West Louisiana
Joined Nov 2009
Not really. I think most people set it to 100 in the gyro and use reduced ATV's in the TX. You can see the effect by going into the "monitor" screen in the software, which will show the effective tail gain, normally around 36% or so in HH mode. If you use the conditions feature, you might set the TX to 100% and then set different gains in the gyro for each condition.
2Doggs is offline Find More Posts by 2Doggs
Old Oct 23, 2012, 09:13 PM
kidlat is offline
Joined Aug 2011
Thanks 2Doggs!
Old Oct 23, 2012, 09:31 PM
beenflying is offline
Find More Posts by beenflying
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Hi John. I've found a bug in v1.22 that I hope you can fix. It's relating to the setup Servo Trim tab.
In this case I have ch1 reversed, but if I go straight to the Servo Trim tab, after connecting the heli or loading an ini file, the up/down collect trim arrows do not take into consideration that ch1 is reversed. I have to go to the Servo Rev tab and toggle the servo from reverse to normal and back to reverse, to get it to work correctly.
Thanks again for this excellent app.
David
beenflying is offline Find More Posts by beenflying
Old Oct 24, 2012, 10:34 PM
bwoollia is offline
Find More Posts by bwoollia
bwoollia's Avatar
United States, CO, Colorado Springs
Joined May 2008
Just found the Android app for the Bluetooth adapter!
http://www.0577mx.com/news_view.asp?clsid=15&id=270
I ordered the bluetooth adapter from OOModel on the 16th. I received an email from them on the 18th, saying that they didn't actually have it in stock yet, and would I like to backorder it, or refund the purchase. Since they asked so politely I decided to keep my order! The adapter was shipped on the 23rd, and I found this link to the .APK file today! I have yet to receive the adapter, and I'm not sure if it will work with my re-flashed CX-3X1000's, but I also have a ZYX-S on the way as well so that should at least work.
bwoollia is offline Find More Posts by bwoollia
Site Sponsor
Latest blog entry: Crash Compilation
Old Oct 24, 2012, 11:59 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
If it's the same version I tried recently, it's Chinese only. No English.
Old Oct 25, 2012, 07:07 AM
lcc014 is online now
Find More Posts by lcc014
AMA Member # 458448
lcc014's Avatar
United States, MA, ALLSTON
Joined May 2011
Just loaded the apps to my XT711, it is in Chinese, simplified characters. The interface of each setup step is very graphical as in PC software. Also, this apps supports S-BUS and Satellite Rx - same as v3.5. Very nice work; it will be excellent when characters are in English
Ching-Ho Cheng
lcc014 is online now Find More Posts by lcc014
Old Oct 25, 2012, 09:36 AM
bwoollia is offline
bwoollia's Avatar
Joined May 2008
I guess I'll have to work on my Chinese then!
Site Sponsor
Old Oct 25, 2012, 12:53 PM
Dr.M is offline
Dr.M's Avatar
Joined May 2011
David
I also noticed this bug when setting up my 450 a while back but I thought it was caused by my cross-flashed 3x1000 to ZYX 3.5.
Old Oct 25, 2012, 02:09 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Ching-Ho Cheng
It sounds good. Thanks for checking it out. Hopefully the English version will be available soon.
Sold Darthdrk Drone CX Body for coax helis like the Blade CX etc. Twmaster Aircraft - Electric - Helis (FS/W) 0 Oct 08, 2011 07:31 PM
Multiplex mc V2 servo programming PC software Thomas B Radios 3 Jul 23, 2006 09:49 AM
