Old Oct 08, 2012, 02:17 PM
PaulB is offline
Find More Posts by PaulB
Mike's Ma Maaaaaaaaan
Paderborn DE
Slightly Off Topic Question.
Hi All, I have a question which I am posing here because I know that a lot of experts follow this thread who I am sure can help. To date I am flying my clone 450 with the 3X1000 FBL Unit and I am very happy with it. I selected ‘Soft 3D’ from John’s excellent program and without tweaking anything the model flies really well and is well matched to my ability (happy inverted in any orientation but not ‘stick banging’).
My question is, as this Unit does not seem to be developing like the Tarot version is should I re-flash it to Tarot software and buy a Tarot Prog. Box or leave it as it is? Is the Tarot software much better (nicer to fly) or should I follow the ‘don’t try to repair what isn’t broken’ rule??
Thanks in advance for any help or advice,
Paul B.
PaulB is offline Find More Posts by PaulB
Old Oct 08, 2012, 03:13 PM
2Doggs is online now
Find More Posts by 2Doggs
Ask Mike
2Doggs's Avatar
North West Louisiana
Joined Nov 2009
I have two 3x1000's, both on 450 pro's, and I may try cross-flashing one with the ZYX 2.5 firmware just to see if there's any difference.
On my 450, I found that the one thing that did benefit from changing parameters was the tail. The default settings in models #4 & #5 resulted in a fair bit of stop bounce, which I was able to dial out mainly by reducing the tail decel values.
2Doggs is online now Find More Posts by 2Doggs
Old Oct 08, 2012, 04:06 PM
Daddy. is offline
Find More Posts by Daddy.
Everyone is an idiot (or I am)
Daddy.'s Avatar
United States, TX, Red Oak
Joined Jun 2012
Paul B.
I have the cx1000 on my 450 pro and it has just worked from day 1. My ZYX, now 3.5, on my 500 has given me more problems, albeit some were mechanical. But there's no way I will flash my cx1000 to zyx 3.5 since it does always everything I tell it too. I've considered putting it on my 500...but don't fi what ain't broke!
Daddy. is offline Find More Posts by Daddy.
Old Oct 09, 2012, 04:03 AM
MikeHRC is online now
Find More Posts by MikeHRC
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
Paul B.
Paul,
I have both and prefer the Tarot firmware - easier to get rid of the oscilations without having to drop the gains too low and just flies better. There has been a problem emerged recently with FFF into strong winds causing a sudden nose-up attitude, but it is easily avoidable and Tarot seem to be more supportive in new releases of the firmware etc.
I have recently cross flashed 2 of my CX1000s to Tarot firmware - but be aware that not all of them can.
Cheers,
MikeHRC is online now Find More Posts by MikeHRC
Old Oct 09, 2012, 07:39 AM
geekystar is offline
Find More Posts by geekystar
Joined Jul 2012
Hi since the communication protocol has been reverse engineered, has any one managed to build a Arduino programmer for the zyx for programming in the fields? Shouldn't be too difficult I think?
Or if the protocol is documented somewhere i may have a try at coding it myself.
geekystar is offline Find More Posts by geekystar
Old Oct 09, 2012, 08:58 AM
OlliW is online now
Find More Posts by OlliW
OlliW
Joined Sep 2009
I didn't do but seriously considered this...
however, programming boxes are available,
also because of the many parameters it would be a pain when using only a 16x2 lcd display (and it wouldn't beat the price of teh available boxes), hence a graphical display with reasonable resolution would be highly desirable... but such Arduino shields are quite expensive and the alternative of DIY is not the easiest route... so I think, currently one is better of with an ebook or the available boxes
(I would however wonder about a smart phone app extension... simple serial BT adapters are cheaply available)
OlliW is online now Find More Posts by OlliW
Old Oct 09, 2012, 09:34 AM
Joined Jul 2012
I agree. Bluetooth board cost less than £5 delivered and should be a direct connection to the 4 pins. All is needed is then a simple Android program. I think it would be more troublesome with iPhone due to its locked down Bluetooth stack?
But the Arduino box still sounds good as I was hoping to build a multifunction box for programming the gyro, testing servos, and also display Frsky telemetry data, and 9x tx AVR programmer. Maybe some other function integrated too.
Old Oct 09, 2012, 09:41 AM
Joined Jul 2012
Just had another thought. Since the zyx uses ttl sonit maybe able to connect to the 9x and so the programming on it. A new firmware is needed and hardware need to be modded but should be achievable nonetheless. Should be no more difficult than adding the code for Frsky telemetry support.
Old Oct 09, 2012, 10:06 AM
Daddy. is offline
Daddy.'s Avatar
Joined Jun 2012
I would provide (modest) $ support for anyone reverse engineering the firmware. Specifically allowing mod'ed firmware to leverage CX1000 and ZYX best features and possibly new (adaptive?) algorithms. and vibe analysis. There is memory available if only 1 condition used.
Cheers,
Ken
Old Oct 09, 2012, 10:41 PM
beenflying is offline
Find More Posts by beenflying
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Unfortunately the firmware is encrypted (probably AES), which requires a 8, 12 or 16 byte key to decrypt it. Only the manufacturer and the bootloader in the gyro, know what this key is. Also the ZYX and ZYX-S use different keys.
beenflying is offline Find More Posts by beenflying
Old Oct 09, 2012, 11:14 PM
Daddy. is offline
Daddy.'s Avatar
Joined Jun 2012
Yes, a challenging task indeed.
Old Oct 10, 2012, 10:01 AM
SAK_080981 is offline
Find More Posts by SAK_080981
Indonesia, Tangerang Selatan, Pondok Cabe
Joined Sep 2010
Align 3GX USB Adapter
Hi all, I just bought a ALZRC 3GYS module for my ALRC 450 Pro, I'm ordering the USB adapter and it seems very long till it's arrived in indonesia. My friend using 3GX module for his Trex 450 Pro, can I use the 3GX USB adapter to programming my ALZRC 3GYS module?
SAK_080981 is offline Find More Posts by SAK_080981
Old Oct 11, 2012, 11:12 AM
branflake12 is offline
Find More Posts by branflake12
Cereal Killer.
branflake12's Avatar
USA, IA, Iowa City
Joined Jun 2009
Originally Posted by MikeHRC View Post
Paul,
Cheers,
Very nice. Something that might be helpful is linking to the proper .bin files in your description, like you linked to the software in the two methods. I may get brave and try again this winter
branflake12 is offline Find More Posts by branflake12
Old Oct 16, 2012, 02:07 PM
tonyastro is offline
Find More Posts by tonyastro
3D VFX Artist
tonyastro's Avatar
USA, CA, Monrovia
I'm thinking of installing my CX gyro upside down. What do I need to reverse in the tx, gyro settings?
tonyastro is offline Find More Posts by tonyastro
Old Oct 16, 2012, 02:54 PM
Black_heart is offline
Find More Posts by Black_heart
Texas NewB
Black_heart's Avatar
United States, MD, Princess Anne
Joined Dec 2011
Nothing in the TX but in the gyro you well need to change the compensations for tail and rotor and I thing peroite or at least check it to make sure.
Black_heart is offline Find More Posts by Black_heart
Sold Darthdrk Drone CX Body for coax helis like the Blade CX etc. Twmaster Aircraft - Electric - Helis (FS/W) 0 Oct 08, 2011 08:31 PM
Multiplex mc V2 servo programming PC software Thomas B Radios 3 Jul 23, 2006 10:49 AM
