Old Sep 21, 2012, 10:35 PM
Mackshot is offline
Find More Posts by Mackshot
Australia, QLD, Yeppoon
Joined Jul 2011
Android software preview at Infinity is up. Not sure if this previously posted but here is the link. http://www.infinity-hobby.com/main/n...ewsdesk_id=795 hope there is an english version.
Mackshot is offline Find More Posts by Mackshot
Old Sep 22, 2012, 03:48 PM
Scarman is offline
Find More Posts by Scarman
Clovis CA
Joined Dec 2004
Interesting. I wondered if someone would doing this. English and an iPhone version would be great.
Scarman is offline Find More Posts by Scarman
Old Sep 25, 2012, 01:59 PM
tonyastro is offline
Find More Posts by tonyastro
3D VFX Artist
tonyastro's Avatar
USA, CA, Monrovia
never mind
tonyastro is offline Find More Posts by tonyastro
Old Sep 27, 2012, 02:08 AM
John_NZ is offline
Find More Posts by John_NZ
New Zealand, Taranaki, New Plymouth
Joined Jan 2012
I had purchased a Printrbot+ 3D printer and just for fun I printed a quadcopter frame with it (design care of swepet on thingiverse.com).
I ordered a multiwii controller to run it from GoodLuckBuy and a load of motors and ESC's from HobbyKing. All the stuff from Hobby King arrived, but haven't seen the controller board from GoodLuckBuy yet (maybe the name is a hint?).
Keen to get it flying, it occurred to me that I still have a ZYX-S kicking around, so I upgraded it to the 3.5 firmware, set it into quadcopter mode and was pleasantly surprised that it works!
This is my first experience with a quadcopter so I am glad to say it worked first time.
Will be interesting to see whether the MultiWii board does a better job of controlling it than the ZYX-S.
John_NZ is offline Find More Posts by John_NZ
Old Sep 27, 2012, 07:58 AM
VArchT is offline
Find More Posts by VArchT
SoCal
VArchT's Avatar
Joined Oct 2011
Cool, did you back the Printrbot on kickstarter? I almost did. I want a 3D printer pretty bad
GoodLuckBuy is pretty slow to get stuff in the mail, I ordered some mini-quad stuff from them almost a month ago and it just got here this week. I've ordered from them a few times, always got here... eventually...
VArchT is offline Find More Posts by VArchT
Old Sep 27, 2012, 08:28 AM
450flyer is offline
Find More Posts by 450flyer
Joined Sep 2012
hey im having a few problems with my tarot ZYX-S gyro. I programmed it through my computer with the usb cable and everything seemed to be working fine, so i closed the program and then turned off and disconnected my gyro.
The problem is now when i power it back up, the 3 LEDS just stay solid and dont blink or change at all.. I can hold the set button and the LED will start to blink yellow however, and if i hold it again the led then goes solid red and i can connect it to my computer, but the gyro isnt receiving any signal from the rx for some reason..
Ive reflashed it and updated it to 3.5 again and it still seems to be doing the exact same thing.. the 3 leds just go solid the moment i power my gyro up, and stay solid the whole time its powered up unless i hold the set button.
any help would be greatly appreciated cheers
450flyer is offline Find More Posts by 450flyer
Old Sep 27, 2012, 09:55 AM
450flyer is offline
Joined Sep 2012
hey i just got a zyx-s 3 axis unit and i got the usb cable with it, but im wondering how you program the gyro through your android phone? is it via bluetooth or do you need another sort of usb converter so the phone can be plugged into the usb cord? any info on the topic would be great, cheers
Old Sep 27, 2012, 10:17 AM
wlee1017 is offline
Find More Posts by wlee1017
wlee1017's Avatar
Joined Jul 2011
3 LEDs stay solid means gyro is waiting for rx signal. make sure you hook up all cables from gyro to rx properly and bind to tx. Do not hook up servos to gyro until you finish setup servo types inside software.
wlee1017 is offline Find More Posts by wlee1017
Old Sep 27, 2012, 04:02 PM
John_NZ is offline
Joined Jan 2012
Yep, I signed up as a backer for the Printrbot+ on kickstarter. It was a rather long journey , but the poor guy thought he would be making 50 of them, not 1800.
Great machine though. Replaced most of the dodgy bits and it goes great. Glad I bought the bigger version (8" bed) as I have needed it for many prints.
Since having the printrbot, if you want to get one cheap, you only need to buy the controller board, motors and hotend from Printrbot and you can source the other stuff yourself as it is all open source.
Thanks for the heads up on GoodLuckBuy, I will just have to wait for it to grind through the Chinese post system.
Old Sep 27, 2012, 07:36 PM
3D VFX Artist
tonyastro's Avatar
USA, CA, Monrovia
I've been trying to setup my 3x1000 on my 250 and everything looks good but my tail servo travel range got smaller (it was longer when it was flybarred) even if I max out the tail limits A and B. I don't want to move the servo hole further out as it's specified in the manual to keep it at 4.5mm from the servo screw. What part of the software can I adjust to maximize my tail travel?
Old Sep 27, 2012, 08:55 PM
VArchT is offline
SoCal
VArchT's Avatar
Joined Oct 2011
I have mine at the middle hole, about 5.5mm I think , seems to work well, for sport flying anyways.
Old Sep 27, 2012, 09:16 PM
2Doggs is offline
Find More Posts by 2Doggs
Two helis flying
2Doggs's Avatar
North West Louisiana
Joined Nov 2009
All you can do is set the A and B limits, from the Tail Setup menu. If those are maxed out without the slider reaching the physical limits, your only option is to move the linkage ball out on the arm.
As a matter of interest, what gyro were you using when the heli was FB?
2Doggs is offline Find More Posts by 2Doggs
Old Sep 28, 2012, 12:13 PM
3D VFX Artist
tonyastro's Avatar
USA, CA, Monrovia
Thanks Zr_Flyer. If nothing else works I'll have to go this route.
Thanks 2Doggs. I was using a G401B gyro. The weird thing is the servo itself is physically capable of much more range. I'm using a D922MG servo.
Old Sep 28, 2012, 12:51 PM
2Doggs is offline
Two helis flying
2Doggs's Avatar
Joined Nov 2009
I think I still have an old 401b to hand, so I might do some test to see if I can replicate this servo throw difference - though I have no intention of going back to flying FB with a 401b!
Old Sep 28, 2012, 12:56 PM
3D VFX Artist
tonyastro's Avatar
USA, CA, Monrovia
Is servo throw determined by the servo or gyro?
Sold Darthdrk Drone CX Body for coax helis like the Blade CX etc. Twmaster Aircraft - Electric - Helis (FS/W) 0 Oct 08, 2011 07:31 PM
Multiplex mc V2 servo programming PC software Thomas B Radios 3 Jul 23, 2006 09:49 AM
