Old Aug 30, 2012, 04:58 PM
Busher is offline
Find More Posts by Busher
Joined Apr 2011
Originally Posted by TX_Winds View Post
Has anyone tried putting the ZYX-S firmware on a non -S unit? I am wanting to try out the airplane mode.
Has anyone tried cross flashing the Tarot programmer update to a CX programmer?
I am not 100% sure here but, I believe you can use the zyx gyro in a plane so long as you update the gyro to the latest firmware 3.5 using the version 3 software. That is how I am going to use the zyx in a plane when i get round to it.
What I would like to know is can you also use a satellite with the zyx (non s version) if you use the latest firmware 3.5 and program it with the version 3 software.
Busher is offline Find More Posts by Busher
Old Aug 30, 2012, 08:39 PM
Grawyl is offline
Find More Posts by Grawyl
United States, IL, Plainfield
Joined Dec 2010
Thanks Dr.M
Yay! I'm connected to John-nz software.
Tx setup was set to
Roll 45 / 36
Pitch 45 / 35
Yaw left/ right 40
Tail gain at 100 (set by tx)
Main rotor PID 80/80/30
Acceleration 125
Deceleration 55
Rc dead band 40
Gyro dead band 4
Tail rotor PID 80/50/30
Accel R/L 125
Decel R/L 25
RC dead band 60
Gyro dead band 4
Tail comp -cyclic to tail 0
Tail comp -collective to tail -2
My only complaint is the RC dead band on the tail and i remeber somthing about the value being backwards or something. Is that still the case or can i reduce thsi to a lower number to reduce the actual dead band?
Grawyl is offline Find More Posts by Grawyl
Old Aug 30, 2012, 09:04 PM
Grawyl is offline
Joined Dec 2010
And now I have a cx running zyx3.5 firmware. Much easier to understand and do the update with everything running and the really cool thing is all of the settings have remained the same. This rocks!
And another question; should i lower the roll and pitch gain to 10? Thought i read that as well.
Old Aug 31, 2012, 01:28 AM
MikeHRC is offline
Find More Posts by MikeHRC
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
Reduce the D gains on the main rotor AILand ELE PID gains to 10
MikeHRC is offline Find More Posts by MikeHRC
Old Aug 31, 2012, 11:37 AM
Grawyl is offline
Joined Dec 2010
Thanks Mike and Dr.M for the help. Now its a waiting game for the last few parts needed to finish the rebuild. Package has been in Kearny NJ for 4 days and I am beginning to think they are building a heli there and needed the parts...
Old Aug 31, 2012, 02:31 PM
Dr.M is offline
Find More Posts by Dr.M
Dr.M's Avatar
United States, WA, Issaquah
Joined May 2011
Nice! Another ZYX is born. You're gonna love the new FW.
Dr.M is offline Find More Posts by Dr.M
Old Aug 31, 2012, 04:13 PM
Grawyl is offline
Joined Dec 2010
Hope so. I liked the way if flew with the cx firmware. Not surenhow it could be better.
Old Aug 31, 2012, 05:04 PM
tonyastro is offline
Find More Posts by tonyastro
3D VFX Artist
tonyastro's Avatar
USA, CA, Monrovia
I'm new to the whole fbl software thing. I went the manual route and my heli is flying great:
Tarot ZYX 3-Axis Gyro Setup & Programming (40 min 1 sec)
Can anyone tell me how using the software is better (besides it being easier)? Is my heli actually going to fly better using the software? Are there settings you can't change manually?
tonyastro is offline Find More Posts by tonyastro
Old Sep 01, 2012, 01:30 AM
MikeHRC is offline
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
Tony,
I can't remember if you get access to all of the advanced settings using the sticks, but to me the big advantages of the sofyware are that you can actually see the values of the settings, save them to your PC, share and compare with others and easily change and reset back to previous settings.
Generally much easier to use.
Old Sep 01, 2012, 02:26 AM
3D VFX Artist
tonyastro's Avatar
USA, CA, Monrovia
Originally Posted by MikeHRC View Post
Tony,
Thanks Mike. I'll do it. Anyway I can always save my current settings before I try changing anything.
Old Sep 01, 2012, 02:35 AM
DerClown is offline
Find More Posts by DerClown
DerClown's Avatar
Lithuania
Joined Mar 2009
Please tell me, why my tail doesnt hold during tic-tocs? I get a constant tail blow out counterclockwise.
I set the tail gain via transmiter to the point where tail starts to shake a bit, but none setting via transmiter helps to eliminate this blowout.
Thanks.
DerClown is offline Find More Posts by DerClown
Old Sep 01, 2012, 08:09 AM
Grawyl is offline
Joined Dec 2010
Thanks.
How bad is the blow out?
If your heli is belt drive, it could be slipping under the added load???
Have you checked the linkage rod; to piro clockwise does the servo push the linkage rod? If it does, maybe its flexing under the load and not allowing the tail to maintain enough pitch?
Have you tried adding some collective / tail compensation?
Old Sep 01, 2012, 09:43 AM
DerClown is offline
DerClown's Avatar
Lithuania
Joined Mar 2009
With tha same machanics just flybared it was flying like a dream.
No I didn't try the colective compensation.
This ZYX gyro setup makes me nervous after Futaba Gy401 ((
Old Sep 02, 2012, 01:18 PM
PHMX is offline
Find More Posts by PHMX
Never trust laughing dolphins
Joined Feb 2011
You definitely need to set up about +10 to +15 tail to collective compensation in the Advanced settings. You state it's going counterclockwise, so you'll totally need positive value compensation. Mine is set at + 12, but don't increase too much.
It's really the only way to get rid of the tic toc tail blow-outs. Of course, don't increase too much or your tail will start to wag.
PHMX is offline Find More Posts by PHMX
Old Sep 02, 2012, 03:13 PM
DerClown is offline
DerClown's Avatar
Lithuania
Joined Mar 2009
Thanks, I'll try that !
P.S.
Before going flybarless I though this is the real deal, no need to change many parts after crash, the whole setup is much easier, in other words just positive against flybared. But I was wrong, the whole setup is so complicated. Also I have to carry my laptop to the field to make adjustments. This takes so much time... And that Align DFC head was freaking me out. It is so sensitive to anything ! And caused a lot vibrations....
I don't know if I would able to choose FBL vs FB which one would I choose now..
Sold Darthdrk Drone CX Body for coax helis like the Blade CX etc. Twmaster Aircraft - Electric - Helis (FS/W) 0 Oct 08, 2011 07:31 PM
Multiplex mc V2 servo programming PC software Thomas B Radios 3 Jul 23, 2006 09:49 AM
