Old Jan 22, 2012, 05:04 PM
wc_wickedclown is offline
Find More Posts by wc_wickedclown
United States, CA, Signal Hill
Joined Aug 2009
Originally Posted by beenflying View Post
No you don't. You only need to be in rate mode when initially setting the servo center and tail pushrod length.
thank you
for some reason i cant get the tail limit to work properly
any suggestions ?
i can tail heading hold is working and the tail is moving in the proper positions but i have to much throw my tail push rod bulges out .
how to i program the limit with the zyx programming software ?
sorry i should make my own thread
hope you don't mind the couple questions we all share the same unit .
wc_wickedclown is offline Find More Posts by wc_wickedclown
Old Jan 22, 2012, 05:11 PM
John_NZ is offline
Find More Posts by John_NZ
New Zealand, Taranaki, New Plymouth
Joined Jan 2012
Ok, I have shifted the download files on http://fbl.net.nz to rapidshare for the time being.They should be available again, I will find a more permanent home for them soon.
John_NZ is offline Find More Posts by John_NZ
Old Jan 22, 2012, 05:19 PM
rahulgaba is offline
Find More Posts by rahulgaba
United States, TX, Dallas
Joined Jun 2011
Do you have a link for rapid share yet?
rahulgaba is offline Find More Posts by rahulgaba
Old Jan 22, 2012, 05:22 PM
Busher is offline
Find More Posts by Busher
Joined Apr 2011
Originally Posted by exblade View Post
Hey Basher,
Isn't the software great! John and BF have done an amazing job!
If running a positive range in the gyro would make you feel better, you can reverse the PIT (channel 6) in your transmitter. Same effect. But no need to, as that is what all the + - settings are for. Remember the transmitter is in 90 degree mode so pit is actually pitch, not one of the cppm servos.
Terry
thanks for that,and to all the others that responded and gave me a bit more confidence in my set up. I tried reversing the pitch at the beginning of the setup but i changed it back as the software notes seemed to push you towards getting the movement sense in the right direction at the first stage. I don,t mind it being negative now i know it dosent matter
Thanks for your help
Busher is offline Find More Posts by Busher
Old Jan 22, 2012, 05:26 PM
John_NZ is offline
Joined Jan 2012
The links are on the site fbl.net.nz, you may need to refresh the page on your browser.
Old Jan 22, 2012, 05:28 PM
beenflying is offline
Find More Posts by beenflying
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Originally Posted by wc_wickedclown View Post
thank you
any suggestions ?
On the setup tab "Tail Setup", start off by setting the limit A and B to say 40. You then have to hold the rudder stick full left or right and find out which limit slider has an effect on the position. Then repeat with the rudder stick full the opposite way and adjust the other slider.
beenflying is offline Find More Posts by beenflying
Old Jan 22, 2012, 07:34 PM
Joined Aug 2009
thank you
Old Jan 22, 2012, 08:26 PM
v823515 is offline
Find More Posts by v823515
United States, OK, Claremore
Joined Nov 2007
Had a question about non-mixing CCPM mode. I have a FlySky CT6B. Do I need to select Model Type - Heli 90 to get to the non-mixing CCPM mode? Also, I am building a FBL Esky Belt CPX and the swash plate is 120 CCPM but the elevator is in the front as opposed to the back as pictured in the manual, with this be an issue, i.e. have to swap channel1 and channel2? Thanks for all your help and keep up the fine work.
v823515 is offline Find More Posts by v823515
Old Jan 22, 2012, 08:49 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Yes, Heli 90 sounds like the correct setting.
The reverse swashplate in no problem. I'd start by swapping ch1 and ch2. At the end of the day it will only affect the setup options (what you have to reverse). As long as everything at the end moves and tilts in the right direction it will fly fine.
Old Jan 22, 2012, 08:56 PM
danger_mouse is offline
Find More Posts by danger_mouse
danger_mouse's Avatar
Australia, QLD, Gatton
Joined Jan 2007
The Tarot app is expecting a DPI setting of 96. If you've increased the Windows font size (which changes the DPI setting) the app will not fit in the frame.
Yep, that fixed it. Thanks.
Might be worth mentioning it in the first post.
danger_mouse is offline Find More Posts by danger_mouse
Old Jan 22, 2012, 10:30 PM
Joined Jun 2011
John...
The tarot original software would save the agility settings and mode (3d extreme or beginner or whatever) for me at all.
Is that something you fixed in your software . ?
Anyone else had that problem?
Old Jan 23, 2012, 01:50 AM
John_NZ is offline
Joined Jan 2012
Originally Posted by IFHELI View Post
I have been going thru the program on all of my Gyros and have notice three things. I have all of my gyros rc deadband set for 10 but with new install of FBL program (1.08,1.09,.1.10) they go back to 40 & 60 on the first hookup to computer but after that they will always be 10. All the other settings except in the monitoring screen will always be what they should be when first hooked up to new FBL program.
I cannot replicate this.
If I load the program and check the advanced menu the RC Deadband values
are both 0.
I then cancel the window, connect to the gyro and go back into the advanced
menu and both the RC deadband values are 10 as stored in my gyro.
I don't see 60 and 40 at all.
Let me know if you have steps that will replicate the fault.
With every new install of FBL program the sub trims and travel adjustments on monitor screen will be off from 3 to 5 points here and there. It is not off on all of them just a few. This could be my TX (JR X9303) doing this with each new FBL program install.
This will be something to do with the gyro or TX. The values on the monitor
page are purely what the gyro sends the program.
The other thing is on the tail comp with my ZYX. It is set for -5 to have correct movement but in the box is shows 251 but it did originally show -5 instead of 251. In the ini. file it shows -5. This is the only gyro that has a -5 setting and the only one that will do this. This is with version 1.10. On version 1.09 it showed 251 in ini. file and -5 in box on advance menu. All the other saved ini. files for other gyros show the correct information and will display the correct information when open back up.
Otherwise everything is working great.
I hadn't noticed that the compensate values could be negative. I have fixed this and added some extra bound checking for all the advanced parameters.
Old Jan 23, 2012, 06:34 AM
jockstrap is offline
Find More Posts by jockstrap
jockstrap's Avatar
Joined May 2011
@John_NZ - was using the latest software (as i havn't used it for a little while) and noticed the following setup screen is not in it - Yet I think I remember using it as i only have the copterx version and not the tarot.. But it seems it's no longer in your software..
Was it removed or am i imagining things - lol
PS: It's a fantastic feature - any chance it can be added to your software.. i know it may be a hard ask but it's probably the single most impressive feature of the tarot version - and the idea probable came from the vbar software. I am of course referring the othe arrowed setup option on the right of the display..
anyway - if there's any way this can be added - that would be fantastic as it allows everything to be setup and tuned in one hit..
Update: I just discovered it was in this version of software "CX3X_2.1_EN.exe" - was that your early version of it or someone else's ?
jockstrap is offline Find More Posts by jockstrap
Old Jan 23, 2012, 07:56 AM
2Doggs is offline
Find More Posts by 2Doggs
Two helis flying
2Doggs's Avatar
North West Louisiana
Joined Nov 2009
Inhibit Pitch Trim
The default one servo heli model in the JR will have the pitch trim lever enabled by default - and you may want to inhibit it in the system setup menu of the TX.
I found my servo trim was out, and traced it to my not inhibiting the trim lever, and the lever not being all the way down.
2Doggs is offline Find More Posts by 2Doggs
Old Jan 23, 2012, 10:58 AM
costasp is offline
Find More Posts by costasp
Greece, Attica, Athens
Joined Jan 2011
Usb ttl
can I use http://shop.fyetech.com/product_info...4079e110487c5f with your software?
Constantinos
costasp is offline Find More Posts by costasp
Sold Darthdrk Drone CX Body for coax helis like the Blade CX etc. Twmaster Aircraft - Electric - Helis (FS/W) 0 Oct 08, 2011 07:31 PM
Multiplex mc V2 servo programming PC software Thomas B Radios 3 Jul 23, 2006 09:49 AM
