Old Aug 17, 2012, 05:58 PM
beenflying is offline
Find More Posts by beenflying
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Originally Posted by DerClown View Post
Thanks !
I have another question. How do you set the Tail Gain ? Via transmitter, or via PC software ? I can't get enough Tail Gain, when I set it with my Spektrum DX7. I put 100% but the tail doesn't hold, when I set it via PC at 100% then the tail has too much gain.
Leave the PC at 100% and then use your Tx to set the tail gain you want. It should be a similar setting to what most tail gyros have. Aim for an initial value in the PC monitor screen (first setup tab, bottom right slider) of around 30.
beenflying is offline Find More Posts by beenflying
Old Aug 17, 2012, 09:58 PM
soneebee is offline
Find More Posts by soneebee
Joined May 2006
should it be on 100% on the gyro so if you can do changes on the radio... it the gain on the gyro is not 100% then the set gain will be the one on the gyro and not on the radio
soneebee is offline Find More Posts by soneebee
Old Aug 18, 2012, 01:13 PM
Dr.M is offline
Find More Posts by Dr.M
Dr.M's Avatar
United States, WA, Issaquah
Joined May 2011
I'm not sure that's accurate. I run gains less than 100 on both my gyros and I can still control the gain from my DX6i. These are CX unnits x-flashed with ZYX 3.5
Dr.M is offline Find More Posts by Dr.M
Old Aug 18, 2012, 09:40 PM
VArchT is offline
Find More Posts by VArchT
SoCal
VArchT's Avatar
Joined Oct 2011
Sure the Tx gain is always a multiplier of the gyro gain,. One thing though, if the gyro is set at less than 100, say 70, the Tx can never achieve a gain of more than 70 only less. On the other hand if you know the total gain of 70 is too high then you can lower it in finer steps. Well that's how I understand it anyways.
VArchT is offline Find More Posts by VArchT
Old Aug 18, 2012, 11:43 PM
Dr.M is offline
Dr.M's Avatar
Joined May 2011
That's exactly how I interpret it as well.
Old Aug 19, 2012, 05:48 AM
PHMX is offline
Find More Posts by PHMX
Never trust laughing dolphins
Joined Feb 2011
Yes, this seems to be correct.
However, even with a setup gain of say only 30%, you'll definitely be able to change the gain. The Tx gain will always define the final gain value.
PHMX is offline Find More Posts by PHMX
Old Aug 19, 2012, 10:53 AM
mhills51 is offline
Find More Posts by mhills51
mhills51's Avatar
kansas city
Joined Feb 2007
I believe the gyro gain is for people without a free 5th channel. Like a lot of gyros you can adjust the gain on the gyro itself or with the free channel you can do it remotely. I would think a signal coming from the gain wire would over ride any setting in the gyro at least that is how all the others I have used work. So It really shouldn't matter what you have the program set for if using your transmitter. Of course this one could be the exception. lol!
mhills51 is offline Find More Posts by mhills51
Old Aug 19, 2012, 12:00 PM
PHMX is offline
Joined Feb 2011
Which would make no sense whatsoever as 6 channel helicopters usually really require six channels to fly.
If you check the tooltip hint in the 3.0 software, it states it's the 'tail rotor TOTAL gain'.
This essentially means it's the multiplier gain value for all other gain values (yaw P, I and D gain) in the 'advanced menu' tab.
It also states the 'switch yaw gain' feature provides adjustable gyro gain through the Tx as is commonly the case with HH gyros.
Old Aug 20, 2012, 02:14 PM
Tobiemanser is offline
Find More Posts by Tobiemanser
Need to understand!!
United Kingdom, Witham
Joined Mar 2012
I found that when using channel 5 to switch between modes 1 & 2 the total gain function came in very handy being that I couldent change it on the transmitter.
Tobiemanser is offline Find More Posts by Tobiemanser
Old Aug 23, 2012, 05:05 AM
PHMX is offline
Joined Feb 2011
Yes, if you're using the flight condition modes through the gyro switch, you can't adjust the gain through the radio. That definitely means the total gyro gain will be the actual gain set.
Old Aug 26, 2012, 11:18 PM
rahulgaba is offline
Find More Posts by rahulgaba
United States, TX, Dallas
Joined Jun 2011
I installed 1.16 john_nz software. I didn't see the update button anywhere. His website says 1.16 is the stable working version. An I supposed to still use 1.22 or something else for updating the software on my tarot zyx unit. Wanting to go to 3.5
rahulgaba is offline Find More Posts by rahulgaba
Old Aug 27, 2012, 02:36 PM
wc_wickedclown is offline
Find More Posts by wc_wickedclown
United States, CA, Signal Hill
Joined Aug 2009
ZYX
how do i trim the helicopter ? its drifting forward and to the right.
mechanically ? or with the software ?
wc_wickedclown is offline Find More Posts by wc_wickedclown
Old Aug 27, 2012, 03:23 PM
Busher is offline
Find More Posts by Busher
Joined Apr 2011
Originally Posted by wc_wickedclown View Post
ZYX
Mechanically, is best
Re check you have your swash level with a swash tool. also check your c of g is where it should be. These are the 2 main causes of drift with this unit. If you cannot stop the drift the chances are you are seeing vibration somewhere.
Busher is offline Find More Posts by Busher
Old Aug 27, 2012, 03:54 PM
Joined Aug 2009
Originally Posted by busher View Post
mechanically, is best
re check you have your swash level with a swash tool. Also check your c of g is where it should be. These are the 2 main causes of drift with this unit. If you cannot stop the drift the chances are you are seeing vibration somewhere.
thank you
Old Aug 27, 2012, 06:43 PM
Joined Aug 2009
Swash plate was unlevel
re-leveled all is perfect no more drift
12+ and 12-
Sold Darthdrk Drone CX Body for coax helis like the Blade CX etc. Twmaster Aircraft - Electric - Helis (FS/W) 0 Oct 08, 2011 07:31 PM
Multiplex mc V2 servo programming PC software Thomas B Radios 3 Jul 23, 2006 09:49 AM
