Portugal, Aveiro
Joined Apr 2012
Thanks everybody.
I was doing it right but moving the adjustments the other way, that’s why I never reached 100. Now I think I'm having trouble with the tail servo. It’s very slow. I know I need a faster servo but I’m not sure if the problem is from the one I mounted for testing purposes (E-MAX ES08D). I move the stick and the servo doesn’t respond immediately. It takes a while to react. That doesn’t happen with the cyclic servos (TG9). |
Joined Feb 2011
United States, KY, Springfield
Joined Jul 2011
no when the good servos are hooked to the cx1000 they work but if i plug in the bad one/ones it toasted none work ...when i plug in the servos directly to the rx or a different rx the good ones function as they should but the bad ones just go all the way one direction and wont move by stick inputs ...im pretty sure something in the cx burnt the servos cause i have never had any problems with them before and the hitecs are fairly new with very little use...i considered crossflashing the cx with the tarot firmware but i don't want to risk burning up more $$$ in servos...
Joined Jul 2011
i will open up the cx to see if anything looks obvious to have caused the servo burning but unless i find a giant red flag and can fix it im not going to use it anymore...prolly salvage the leads and toss it...really sux cause this is my first 3 axis unit other then using the walkera rx's with built in 3 axis and i must admit im very disappointed with it...makes me very leary of buying anymore of the cheaper units as they all just seem to be clones of each other...after loosing $$ on the servos it makes the high end 3x units seem not so expensive after all.
i have 3 Henge922 i can place on the cyclics and for the tail i have no idea what i will use but the ds420 it burnt up was a very good tail servo and the only one i had...might try to use one of the Exi213s i have in a different heli i don't fly anymore...so at least with putting the walkera rx back on i might be able to get it flying again but prolly not as good for the tail as it was... |
Joined Jul 2011
opened it up and used a magnifying glass to inspect it and nothing looked burnt or any loose connections, cold solder joints ect...tried to install the henge servos to replace the cyclics and they are to tall so im grounded till i get the $ to replace the burnt servos...
Anyway, keep us post and good luck. |
| Thread Tools | |
| Sold Darthdrk Drone CX Body for coax helis like the Blade CX etc. | Twmaster | Aircraft - Electric - Helis (FS/W) | 0 | Oct 08, 2011 07:31 PM |
| Multiplex mc V2 servo programming PC software | Thomas B | Radios | 3 | Jul 23, 2006 09:49 AM |
