Old Jan 05, 2012, 05:21 PM
beenflying is offline
Find More Posts by beenflying
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
PC Software for Setup/Programming the CX-3X1000, 3GYS, TG-1, ZYX etc.
I've just finished the testing of the PC software for the CX-3X1000 and 3GYS (patched ZYX software). As far as I can see it all works well, even all of the PC setup screens.
*** HOT ***
CX-3X1000 & CX-3X2000 firmware v2.1: http://www.rcgroups.com/forums/showp...postcount=2304
Android app for the CX3X1000: http://www.rcgroups.com/forums/showp...postcount=2684
Patched Tarot Applications:
For the ALZRC 3GYS: http://codeguys.rpc1.org/utilities/3GYS_2.1_EN.zip
For the Helicox TG-1: http://codeguys.rpc1.org/utilities/TG-1_2.1_EN.zip
For the CopterX CX-3X1000: http://codeguys.rpc1.org/utilities/CX3X_2.5_EN.rar
Patched CopterX Applications:
For the Tarot ZYX: http://codeguys.rpc1.org/utilities/TarotZYX_1.2_EN.rar
You just have to unzip it to it's own folder, like the Tarot/CopterX software. I've included all of the files that come with the Tarot/CopterX version.
Currently this has only been tested with the Tarot USB link:
http://www.ac-rc.com/product_info.php?products_id=1392
Thanks to John_NZ for working out the comms protocol.
John_NZ's Application:
John_NZ has written an excellent application that will work with all of the low cost gyros. You can get the latest version of his application here:
http://fbl.net.nz/
Tarot Bluetooth adapter for Android and PC Interface:
http://www.infinity-hobby.com/main/p...oducts_id=8962
http://www.hobbyrover.com/tarot-3axi...ter_p1355.html
http://www.oomodel.com/tarot-zyx12-g...t-p-64098.html
Pairing code: 5782 (Thanks Zr_Flyer)
Android app:
http://tarot-rc-heli.com/Tarot-RC-Software
http://www.infinity-hobby.com/main/d...yx_3.0.apk.zip
Android app for CX3X1000 (thanks doctorj46920)
Home made Bluetooth for PC Interface (not for the Android app):
http://www.rcgroups.com/forums/showp...&postcount=359
Spektrum/JR Rx connections:
http://www.rcgroups.com/forums/showp...&postcount=796
Flashing the ZYX Program Box:
http://www.rcgroups.com/forums/showp...postcount=5443
Cross Flashing:
http://www.rcgroups.com/forums/showp...&postcount=621
Guides:
Arey's getting started tips: http://www.rcgroups.com/forums/showp...postcount=3286
sp00fman's basic beginners steps: http://www.rcgroups.com/forums/showp...postcount=5795
Dr.M's advanced tuning and troubleshooting: http://www.helifreak.com/showthread.php?t=485789
Note: The Tarot app and the apps above require the Windows DPI setting to be set to 96. If you've increased the Windows font size (which changes the DPI setting), the app will not fit in the frame.
Official Software:
Tarot ZYX version:
v2.1: http://www.infinity-hobby.com/main/d...d/ZYX2.1EN.zip
v2.5: see attached ZYX2.5EN.zip file
v3.50: http://www.kingwjg.com/zyx/zyx%203.50.rar - Please read this also: http://www.rcgroups.com/forums/showp...postcount=4039
v4.01: http://www.0577mx.com/news_view.asp?id=273
Tarot ZYX-S version:
v3.0: http://www.infinity-hobby.com/main/d...d/ZYX3.0EN.rar
v3.02: http://www.infinity-hobby.com/main/d.../ZYX-S-302.bin
v3.50: http://www.kingwjg.com/zyx/zyx-s%203.50.rar - Please read this also: http://www.rcgroups.com/forums/showp...postcount=4039
CopterX CX-3X1000 version:
v1.2: http://www.ky-model.com/copterx/CX-PB002-3X1000.zip
v2.1: http://www.walkera-heli.com/manual/CX-3XX000v2-1.zip
Firmware updates:
Tarot ZYX: Attached below
Tarot ZYX-S: Attached below
Tarot Program Box: Attached below
Original firmware:
CopterX CX-3X1000 v1: http://www.ky-model.com/copterx/CX-3X1000v1-0.bin
CopterX manual:
http://www.ky-model.com/copterx/cx-3x1000_manual.pdf
Advanced Manual: (thanks to Dave Settle and Jaakko Haavisto)
http://fbl.net.nz/files/fblmanual.pdf
Links:
Tarot USB Link: http://www.infinity-hobby.com/main/p...oducts_id=7935
Tarot Program Box: http://www.infinity-hobby.com/main/p...oducts_id=7853
beenflying is offline Find More Posts by beenflying
Last edited by beenflying; Jul 12, 2014 at 07:06 PM. Reason: Added CX-3X1000 & CX-3X2000 firmware v2.1
Old Jan 05, 2012, 05:58 PM
2Doggs is offline
Find More Posts by 2Doggs
Two helis flying
2Doggs's Avatar
North West Louisiana
Joined Nov 2009
Catch up eHirobo!
Great work! Now if only I could download the USB link!
2Doggs is offline Find More Posts by 2Doggs
Old Jan 05, 2012, 06:15 PM
danger_mouse is online now
Find More Posts by danger_mouse
danger_mouse's Avatar
Australia, QLD, Gatton
Joined Jan 2007
Good stuff!
Just ordered the Tarot USB adapter.
danger_mouse is online now Find More Posts by danger_mouse
Old Jan 05, 2012, 06:40 PM
ewoodcox is offline
Find More Posts by ewoodcox
Axes & Blades-Cutlery & Helis
West Monroe NY
Joined Feb 2009
very cool is there an advantage to using this over the programming box?
ewoodcox is offline Find More Posts by ewoodcox
Old Jan 05, 2012, 07:21 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
It's cheaper, very easy to use and makes setup much easier as well.
Old Jan 05, 2012, 07:41 PM
Joined Jan 2007
This software/USB link will be much better for setting up on the bench.
I can see I will still throw the programming box in my pocket for quick tuning adjustments when flying.
Old Jan 05, 2012, 07:59 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Yes, the program box is nice for taking to the flying field, unless you're happy to take a laptop. Also for $5 plus shipping (for the USB link), it helps to make this gyro a good low cost option as well, without the limitations of the Tx programming.
Old Jan 06, 2012, 12:01 AM
Dimitris K is offline
Find More Posts by Dimitris K
Dimitris K's Avatar
Athens, Greece
Joined Mar 2008
BF, thanks for your effort and time to patch
this software to work with the CX-3x1000.
Enjoy your flights !!
Dimitris K is offline Find More Posts by Dimitris K
Old Jan 06, 2012, 12:12 AM
tdriver is offline
Find More Posts by tdriver
tdriver's Avatar
Athens GR
Joined May 2003
will the firmware upgrade feature work ??
tdriver is offline Find More Posts by tdriver
Old Jan 06, 2012, 12:30 AM
VArchT is offline
Find More Posts by VArchT
SoCal
VArchT's Avatar
Joined Oct 2011
Thanks!
VArchT is offline Find More Posts by VArchT
Old Jan 06, 2012, 12:34 AM
bwoollia is offline
Find More Posts by bwoollia
bwoollia's Avatar
United States, CO, Colorado Springs
Joined May 2008
Cable ordered, woohoo! Take the bounce out of my tail!
bwoollia is offline Find More Posts by bwoollia
Site Sponsor
Latest blog entry: Crash Compilation
Old Jan 06, 2012, 01:28 AM
MikeHRC is offline
Find More Posts by MikeHRC
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
The original Tarot software (so hopefully BF's version) has the ability to save the set-up to disk so you can keep a back-up of known good set-ups.
BF - thank you very much for this.
Cheers,
MikeHRC is offline Find More Posts by MikeHRC
Old Jan 06, 2012, 03:55 AM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
You're welcome, guys. To answer a couple of questions:
1/ Yes, saving/loading the model setup as a file works fine.
2/ Not sure about the firmware update, but can't see why not at this stage.
Old Jan 06, 2012, 04:02 AM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
My ALZRC 3GYS PC software is now released (patched ZYX version). See the first post for the download.
Old Jan 06, 2012, 04:06 AM
tdriver is offline
tdriver's Avatar
Athens GR
Joined May 2003
if you keep this up we won't find a cable for months to buy.....lol
Sold Darthdrk Drone CX Body for coax helis like the Blade CX etc. Twmaster Aircraft - Electric - Helis (FS/W) 0 Oct 08, 2011 07:31 PM
Multiplex mc V2 servo programming PC software Thomas B Radios 3 Jul 23, 2006 09:49 AM
