Old Jan 05, 2012, 03:30 AM
SHK V1 is offline
Find More Posts by SHK V1
United Kingdom
Joined Feb 2007
Decals for 1/12th scale Jets
Does anybody know where i can get decals for a 1/12th scale phantom? i was hoping to finish it as 56squadron based at RAF Wattisham.
Also, same question, but for a 1/12 scale Eurofighter. I have the freewing version, but i dont really want it in German Colours, any ideas on where i can find RAF Markings for one?
I know this is a longshot and im going to guess you will say to make my own, so if that is the case, any ideas on making them?
Thanks in advance
Pete
SHK V1 is offline Find More Posts by SHK V1
Old Jan 05, 2012, 10:47 AM
drumbum is offline
Find More Posts by drumbum
United States, CA, Mill Valley
Joined Feb 2010
http://www.callie-graphics.com/aboutus.php
callie will make any markings in any scale you ask for. good quality too, just send her a pic.
DB
drumbum is offline Find More Posts by drumbum
Old Jan 06, 2012, 03:25 AM
dro56595@bigpo is offline
Find More Posts by dro56595@bigpo
dro56595@bigpo's Avatar
Australia, ACT, Symonston
Joined Aug 2008
If you have an inket printer, you can make your own decals.
You will need some inkjet waterside decals. They come in clear and white.
I search the net for artwork or do my best at creating it on the PC. I use MS Powerpoint to assemble the images and take a guess at the correct size. Print some drafts on plain paper and hold them against the model, resize on the computer if necessary, re-print a draft to check, then print the final images to the decal sheets.
Allow the ink to dry overnight, then coat with a spray-on acrylic photo sealer (3 light coats, allowing to dry between coats).
Cut out images, soak in cool tap water, slide them on. Or you could get Callie to do a great job for you without the hassle of DIY.
A quick Google should find the decals and sealer in your locality.
Cheers,
Dan.
dro56595@bigpo is offline Find More Posts by dro56595@bigpo
Old Jan 06, 2012, 04:13 AM
SHK V1 is offline
United Kingdom
Joined Feb 2007
Thanks Guys,
Thats brilliant. I will go with both options, just incase i screw up the DIY ones. Now just to try and find pictures and markings for a RAF Phantom of 56 squadron.
Thanks once again.
Pete
For Sale Tam 1/12th scale F-16 bedowinn Aircraft - Electric - Jets (FS/W) 7 Nov 04, 2011 09:53 PM
Wanted PICA 1/12th scale P51 4dogspete Aircraft - Electric - Airplanes (FS/W) 7 Oct 08, 2011 01:39 PM
1/12th scale Fokker Dr.1 and Sparrow II Free Flight and 1/14th scale Albatros DII AerodromeRC Scale Kit/Scratch Built 3 Aug 29, 2005 04:22 PM
1/12th scale Fokker Dr.1 and Sparrow II Free Flight and 1/14th scale Albatros DII AerodromeRC Scratchbuilt Indoor and Micro Models 0 Aug 28, 2005 07:26 PM
AerodromeRC 1/6th scale Fokker EIII and GWS powered 1/12th scale Fokker DR.1 AerodromeRC Scale Kit/Scratch Built 1 Aug 23, 2005 09:30 PM
