| Thread Tools |
| This thread is privately moderated by OmegaRedIsDMan, who may elect to delete unwanted replies. |
Joined Jul 2009
4G6 upgrade with v120D02S parts - part 2
Over the holidays I took my newly upgraded 4G6 to the field to finally get to test the new receiver out in a large open space. Everything was going fine at first. So I tried flipping it. It was one of my flights of the day. So the flip wasn't very smooth. Right after the flip the heli. started loosing power. Then it was lagging on responding to my inputs and it started going down. I fought it for a couple of seconds and then I decided to hit throttle hold while I was still a few feet off the ground, to prevent damage during the crash. Well that backfired. I saw something white go flying when the heli. hit the grass. When I went to pick it up I noticed one of the blades had broken off at the root. Also the pin holding the main gear had destroyed the part of the gear that was held in place on the main shaft by the pin. ![]() ![]() A couple of days later I had the heli back together with the new blades from the V120D02s. While putting it back together I noticed that the cyclic servos were binding at the ends of travel. I also had to replace one of the servos. I adjusted the servo travel to eliminate the binding. Then I swapped out the battery connectors for micro deans. I took the heli up for another hover. Here is what happened.
Again I hit throttle hold and to try to reduce damage. This time the new blades were fine. However, since they are heavier the force ended up being transfered to the main shaft and the main shaft pin destroyed another main gear. I think I'm going to have to look into making a shear pin that will break away to preserve the main gear. I can really tell the difference in power with the new micro deans connectors. However, the higher head speed seemed to increase the vibrations even more, causing the heli to spin around when in idle up mode. The next day I had the heli. fixed up again with my last main gear. I had to straighten the flybar by hand since I didn't have anymore spares. This time the flight went without incident. But the heli is still vibrating at high head speed, causing the tail to wag and be unstable. I think it's time to go ahead and convert the head to flybarless so that there are less parts to fix, and less things to balance to eliminate vibrations. |
Joined Apr 2009
Checkout my post on going 4G6 FBL here:
http://www.rcgroups.com/forums/showthread.php?t=1559714 I used some 0-80 screws and nuts from Ace hardware to make the connection from blade grips to control rods. An aluminum or copper shear pin is the way to go for the main shaft/gear. I get 18 ga aluminum wire at ACE hardware then just enlarge the hole in the main shaft just a little so it will slide in easily. Use a HSS drill bit and go slow by hand. I think I used a #60 or #59 drill bit. Good Luck, Don |
Joined Jul 2009
| Thread Tools | |
| Discussion Upgrade Options for Walkera 120CPs using V120D02S Parts | zadaw | Micro Helis | 224 | Jun 12, 2012 08:46 AM |
| Sold Walkera 4g3 and 4g6 heli plus lotta parts with two transmitters | Texasredrider | Aircraft - Electric - Helis (FS/W) | 1 | Dec 18, 2011 08:03 PM |
| For Sale 4G3/4G6 parts NIP main/tail motors,frames,UPGRADE CNC metal head etc.. | Z06 Tony | Aircraft - Electric - Helis (FS/W) | 3 | Oct 10, 2009 11:12 AM |
