Old Jan 04, 2012, 03:40 PM
steamer68 is offline
Find More Posts by steamer68
Germany, RP, Simmern
Joined Sep 2011
New Steam Launch build from scratch
Hello,
i like to show you my new build steam launch. The boat was for the first time in the water today(due to the weather it was our bathtube)
I build the boat entire from scratch. It is 2mm pinewood on 4mm ply frames sealed with epoxy. It is about 75cm long.
I have also build the complete steam plant to my own design. It is a single cylinder oszi with 10mm bore and 15mm stroke.It is made from brass and steel. Piston is equipped with a teflon piston ring also to my own design.The boiler is a small pot boiler with 3 watertubes all silver soldered. It is very good insulated with wood and 4mm cork. Firing is with "Brennpaste" for Fondue similar to the new Regner Boilers. Running time today was approx.13 min than the fuel was empty and little water was left in the boiler.The engine runs like a dream and I can`t wait to test the boat on the lake.
The boat isn`t complete as you can see but I hope I will have it ready for the new season.The only comercial items I have used are the safty valve from Wilesco, andthe propshaft and prop from Graupner.
Sorry for my english.
Andreas
steamer68 is offline Find More Posts by steamer68
Old Jan 04, 2012, 04:15 PM
Kmot is offline
Find More Posts by Kmot
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
It's a beautiful little boat Andreas! And how fantastic that it is all your own design!
Your English is excellent, no worries!
Kmot is offline Find More Posts by Kmot
Old Jan 04, 2012, 07:03 PM
Hye's is offline
Find More Posts by Hye's
Hye's's Avatar
Portland OR USA
Joined Aug 2010
Awfully nice work. Great to see originality.
Hye's is offline Find More Posts by Hye's
Old Jan 04, 2012, 09:32 PM
Ed Crowell is offline
Find More Posts by Ed Crowell
Ed Crowell's Avatar
Southern Calif
Joined Dec 2005
Andreas,
Very nice work. Can you post some picture of the power plant and boiler.
Ed
Ed Crowell is offline Find More Posts by Ed Crowell
Old Jan 05, 2012, 01:25 AM
MILLERTIME is offline
Find More Posts by MILLERTIME
Taking care of the pond.
MILLERTIME's Avatar
United States, CA, Sanger
Joined Apr 2004
Nice build.
MILLERTIME is offline Find More Posts by MILLERTIME
Old Jan 05, 2012, 02:33 AM
Bernhard BB is offline
Find More Posts by Bernhard BB
Bernhard BB's Avatar
Denmark, Capital Region of Denmark, KBH
Joined May 2007
yes,,,look swett...nice one...
Regards Bernhard
Bernhard BB is offline Find More Posts by Bernhard BB
Old Jan 05, 2012, 02:38 PM
Reg Hinnant is offline
Find More Posts by Reg Hinnant
South Texas
Joined Jul 2003
Welcome Andreas,
The boat looks very good!
More pictures, please!
Reg Hinnant is offline Find More Posts by Reg Hinnant
Old Jan 05, 2012, 03:18 PM
Joined Sep 2011
Some more pictures
Thanks for the warm welcome! Here are some more pictures of the steam engine.At the last picture you can see a smaller V-Twin Version of my oszi. It is also double acting but with only 8mm bore and 12mm stroke. It is also a good runner.I will build a vertical boiler for it some day but at the moment I have to many projects on the start so I first have to finish a few before starting a new one.
All my engines are build from bar stock and scrap pieces.The cylinders are normaly made from brass or gunmetall depending on what is to hand.Pistons are also made from brass. If you like to see more pictures from my other steam stuff I can post some pictures if you like.
Andreas
Old Jan 05, 2012, 07:00 PM
Kmot is offline
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
Andreas
Oh yes! We LOVE pictures!!
Old Jan 05, 2012, 08:10 PM
Ed Crowell's Avatar
Southern Calif
Joined Dec 2005
Yes, post some more pictures.
Ed
Old Jan 06, 2012, 02:54 PM
Joined Sep 2011
My steam stuff
Here are some pictures of my other steam stuff. I hope it is OK that there are also a stationary engine and a Steam Loco. The last engine is a full size engine wich I have currently under construction. It is 2"x2" engine with a stuart No.1 cylinder build to a modified plan from the Netherlands.
The mill engine is 16,5mm bore and 25,4mm stroke from aheavy modified plan from the Net. It is also equipped with teflon piston ring.
The Loco is build to the Dacre plans from the Netherlands.
The V2 Oszi is my own design. It is a good runner but I have to rework the boiler.
So you can see why I don`t want to start another projekt at the moment. It is enough work for another year or two, or...
Andreas
Old Jan 06, 2012, 05:09 PM
Kmot is offline
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
Very nice 'stuff', all of it!
I like your CNC hacksaws and files.
Old Jan 06, 2012, 08:09 PM
Ed Crowell's Avatar
Southern Calif
Joined Dec 2005
You sure do have lots of projects going. Very nice.
Thanks for posting,
Ed
Old Jan 07, 2012, 01:19 AM
MILLERTIME's Avatar
Joined Apr 2004
Nice toys.
Old Jan 11, 2012, 03:14 AM
HS93 is offline
Find More Posts by HS93
Rainhill UK
Joined Sep 2007
HI I like ths small vertical single in the first picture have you some more info and didi you build it from plans.
Peter
HS93 is offline Find More Posts by HS93
Build Log r/c catapult launch glider scratch build scruffy1 Sailplane Talk 73 Feb 22, 2012 03:51 AM
Discussion New Member, looking to build from scratch. GreenHell Fuel Plane Talk 7 Sep 21, 2011 03:34 AM
Wanted Looking for and Steam Launch kit and Steam Engine *** Joe Pierson Boats (FS/W) 7 Aug 18, 2011 03:01 PM
Discussion "Fantine" (scratch-built steam launch) braves windy seas Rapidnadion Steam Boats 3 Apr 20, 2011 02:16 AM
Discussion WOODIES: Scratch built steam launch w/ two Midwest engines peconic steam Steam Boats 198 Jul 01, 2010 12:24 PM
