Old Jan 05, 2013, 02:50 PM
Luv3d is offline
Find More Posts by Luv3d
Honeybadger don't care...
Luv3d's Avatar
United States, FL, Winter Park
Joined May 2010
Wing tube failed on the 2nd flight in a pretty gentle parachute. About 7 total minutes of life for that airframe.
Luv3d is offline Find More Posts by Luv3d
Old Jan 05, 2013, 03:41 PM
nebwake is offline
Find More Posts by nebwake
nebwake's Avatar
United States, NE, Lincoln
Joined Mar 2011
That is crazy, I put mine through hell every time it sees the air.
nebwake is offline Find More Posts by nebwake
Old Jan 05, 2013, 05:14 PM
SteveT. is offline
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Originally Posted by Brownie433 View Post
Wow, folks weren't kidding about this bird being a tail heavy build. I have the 4315-714 (with 1/2" spacers), ICE 100 (on the motor box), and the 4S battery is almost completely under the cowling at 3.75" CG.
I hate to add dead weight, but I need to access the battery better for strapping down. I rather add weight than eject a battery.
That's why I went with a 5S system and a heavier motor....but I am waiting on my new packs.
SteveT
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Jan 05, 2013, 05:50 PM
Luv3d is offline
Luv3d's Avatar
Joined May 2010
Surprised the heck out of me too- the tube had no visible damage when I inserted it, and it was not damaged in shipping. Bummed me out.
Originally Posted by nebwake View Post
That is crazy, I put mine through he'll every time it sees the air.
Old Jan 05, 2013, 08:17 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
How old is the plane?
SteveT
Old Jan 05, 2013, 08:42 PM
Luv3d is offline
Luv3d's Avatar
Joined May 2010
Garage sale edge from october this past year.
Old Jan 05, 2013, 09:06 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
Perhaps Noll would do something about this???
SteveT
Old Jan 05, 2013, 10:05 PM
Luv3d is offline
Luv3d's Avatar
Joined May 2010
I gave them the opportunity to help, but they declined. Not sure if my message was handled by Noll or someone else.
SteveT
Old Jan 06, 2013, 03:34 AM
cookci is offline
Find More Posts by cookci
Joined Jul 2011
Did you show them the picture you showed us? Thats quite clearly a wing tube failure and not your fault.
cookci is offline Find More Posts by cookci
Old Jan 06, 2013, 05:50 AM
RCPilot1234 is offline
Find More Posts by RCPilot1234
Joined Jan 2012
Sorry to see that happen to the tube! Hopefully you'll be up in the air soon
RCPilot1234 is offline Find More Posts by RCPilot1234
Old Jan 06, 2013, 07:04 AM
Luv3d is offline
Luv3d's Avatar
Joined May 2010
Thanks for the well-wishes.
Old Jan 07, 2013, 01:22 AM
marksextra is offline
Find More Posts by marksextra
Once u go yak u never go back
marksextra's Avatar
Erie, PA
Joined Mar 2005
Just wondering the same thing. Dang. Even the wingtips are in tact.
marksextra is offline Find More Posts by marksextra
Old Jan 07, 2013, 05:29 AM
Luv3d is offline
Luv3d's Avatar
Joined May 2010
Yes.
Old Jan 07, 2013, 10:35 AM
Rhondas is offline
Find More Posts by Rhondas
Rhondas's Avatar
usa
Joined Dec 2004
540 edge Barn door ailerons
say I have the same model only its the 41 " version its my first real wood and balsa 3d plane, I have the foam Typhoon how ever its nothing like this baby.
I watched the flying video and its very impressive showing the hands on sticks.
T first I set it up to specs on the trows, and test flew it and stalled it on landing and had to replace the nose cowl. so I looked up other same size 540 edge models and noticed the throws and specs are 1/2 of the recommended settings on the model I have like in the video except its the 41 inch version . I'm definitely not a 3D pilot .just sport and pattern. and that's all I'm looking for in this model. OK so in a video on the same model I have the pilot comes in for a landing and says do not move your ailerons just use rudder and flare with your elevator with power slightly on ,well I Noticed in this here video the pilot did use his ailerons on landing , so my question is should I or shouldn't I use the ailerons on landing, because on all my sport planes I always had to correct almost all my landings with some aileron input?
Rhondas is offline Find More Posts by Rhondas
Old Jan 07, 2013, 11:12 AM
Luv3d is offline
Luv3d's Avatar
Joined May 2010
All landings with any type of crosswind or turbulent air will require minor corrections with the ailerons to keep the wings level. There are various crosswind techniques, but certainly in the flare, the ailerons must be leveled- which will require some type of input.
Discussion 60 inch edge 540 vs 48 inch extreme flight extra 300 & edge 540 vs 3dhs slick 51 & 59 CRFan1 3D Flying 40 Mar 04, 2012 02:45 PM
Sold 3DHS Omega 130g NIB 58.00 Shipped boatdoc Aircraft - Electric - Power Systems (FS/W) 9 Aug 28, 2011 09:16 AM
Discussion 3dhs edge 41" edge as second ish) plane? Mr Bloppy 3D Flying 19 Aug 25, 2010 09:43 AM
Wanted Wanted - 47" - 58" 3DHS, EF or Sebart plane paintball_kidz Aircraft - Electric - Airplanes (FS/W) 0 Jan 02, 2010 11:12 PM
Wanted 47"-58" size 3DHS, Sebart or Extreme Flight paintball_kidz Aircraft - Electric - Airplanes (FS/W) 13 Jan 02, 2010 12:52 AM
