Old Dec 29, 2012, 05:34 PM
zmonster97 is offline
Find More Posts by zmonster97
Team Aztech Aeromodels!
zmonster97's Avatar
United States, PA, Allentown
Joined May 2011
I'm getting about 1400w and I love it!
zmonster97 is offline Find More Posts by zmonster97
Old Dec 29, 2012, 06:00 PM
Luv3d is offline
Find More Posts by Luv3d
Honeybadger don't care...
Luv3d's Avatar
United States, FL, Winter Park
Joined May 2010
Sweet spot?
Well...at 4.5 to 5.5 finished weight, and 200W per pound, I think between 900W and 1100W would be pretty sweet. I'm at about 1000W and the plane has respectable pull out of a hover. It's pretty fast on the 16x8 I run, and I'm only on 4S....
Luv3d is offline Find More Posts by Luv3d
Old Dec 29, 2012, 06:54 PM
nebwake is offline
Find More Posts by nebwake
nebwake's Avatar
United States, NE, Lincoln
Joined Mar 2011
I am pulling 1380 max on 4s and was 1475 on 6 s. It is insane....
nebwake is offline Find More Posts by nebwake
Old Dec 29, 2012, 07:05 PM
Trill is offline
Find More Posts by Trill
Trill's Avatar
United States, TN, Murfreesboro
Joined Oct 2008
Originally Posted by SteveT. View Post
5S here....
SteveT
What's your evaluation of the flight envelope on 5s? The motor I have in mind runs well on 5s or 6s.
Trill is offline Find More Posts by Trill
Old Dec 29, 2012, 07:12 PM
SteveT. is offline
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Originally Posted by cookci View Post
What's the power sweetspot for this model? 1200watts?
Depends on who you are talking too... For Losifanatic, it would be about 5000 watts!!
SteveT
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Dec 29, 2012, 07:16 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
Can't say for sure, as I had some really heavy 5S 4000mAH packs, that I had bought to also use in my 72" Sbach. The Sbach has been sold, so, I really thought those packs were too heavy, so, I sold them and have some 5S 45C 3850mAH Thunder Power packs, ordered..... So, my Edge has yet to be maidened. And....i am going t be using a Hacker A50-14XS, which should have a lot of power....It can swing a 15X8 or 16X7 prop!!
SteveT
Old Dec 29, 2012, 07:34 PM
Trill is offline
Trill's Avatar
Joined Oct 2008
Can't say for sure, as I had some really heavy 5S 4000mAH packs, that I had bought to also use in my 72" Sbach. The Sbach has been sold, so, I really though those packs were too heavy, so, I sold them and have some 5S 45C 3850mAH Thunder Power packs, ordered..... So, my Edge has yet to be maidened. And....i am going t be using a Hacker A50-14XS, which should have a lot of power....It can swing a 15X8 or 16X7 prop!!
SteveT
OK, thanks. Let us know what you think after a few flights.
Old Dec 29, 2012, 10:59 PM
wamsy55 is offline
Find More Posts by wamsy55
Fly Low
wamsy55's Avatar
Nashville , Tennessee
Joined Jan 2009
Originally Posted by 3DeltaFly View Post
Looks like your Edge is flying nice and light The Sky 4S 4000 packs you're using, are they 30C or 40C? There's about a 66 gram difference between the two.
30C Packs.
wamsy55 is offline Find More Posts by wamsy55
Old Dec 30, 2012, 10:44 AM
Trill is offline
Trill's Avatar
Joined Oct 2008
58" Edge, 59" Slick, and big gassers
Originally Posted by nebwake View Post
The idea that edges are not precise is a little too general. The only thing that modern airframe edges seem to not do as well as an extra are snaps. This is due to the wing. Another thing that some edges tend to do is roll out of heavy elevator moves like a wall. That said much of that has to do with using a little too much throw. If guys reduce their throw a little bit or have a middle rate for elevator this can be reduced. As far as being able to perform big smooth maneuvers, on low rates, this plane will keep up with my slick 1 for 1 and nearly as good as my big gassers.
Were you comparing the 58" Edge to the 59" Slick? What big gassers were you comparing the 58" Edge to?
I have the 87" Extra SHP on 12s with the recommended Hacker motor. For longer flight times I'm thinking about converting it to gas with a DA 60 or DA 70. What is your recommendation for an engine for the 87" SHP?
Old Dec 30, 2012, 01:54 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
Q80-8M...... More efficient than the "recommended" Hacker motor...
SteveT
Old Dec 30, 2012, 01:56 PM
Irg is offline
Irg
Find More Posts by Irg
Irg
ol' yellow eyes is back
Irg's Avatar
United States, NY, Alfred
Joined Apr 2009
maybe but you won't get any longer flight times.
Irg is offline Find More Posts by Irg
Old Dec 30, 2012, 02:21 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
With proper throttle management, I bet you would get longer flights than with the A60-18L....but no, not as long as with gas....that is true...
SteveT
Old Dec 30, 2012, 03:13 PM
Irg is offline
Irg
Irg
Irg's Avatar
Joined Apr 2009
what is proper throttle management? I'm just talking about the usual mix of 3D and precision that is sort of the middle ground for many here.
and no, I had both motors, flight times were the same.
Old Dec 30, 2012, 03:21 PM
rcbirk21 is offline
Find More Posts by rcbirk21
Barefoot Birkinsomething
rcbirk21's Avatar
United States, CA, Hayward
Joined Aug 2004
what us proper throttle management? I'm just talking about the usual mix of 3D and precision that is sort of the middle ground for many here.
been waiting to use this for a while hahahahaha
but on a serious note...what did you find the difference (if any) was? Did you feel like the q80 had more power with the same flight time, it was smooth, or anythign at all? considering a 50cc electric in the near future
rcbirk21 is offline Find More Posts by rcbirk21
Old Dec 30, 2012, 04:07 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
Hotay.....I haven't had both motors, so, I would have though that as hot as I have been told the A60-18L ran compared to the Q80, that the Q80 would have gotten a bit longer flying time, as heat is just wasted energy....
SteveT
Discussion 60 inch edge 540 vs 48 inch extreme flight extra 300 & edge 540 vs 3dhs slick 51 & 59 CRFan1 3D Flying 40 Mar 04, 2012 02:45 PM
Sold 3DHS Omega 130g NIB 58.00 Shipped boatdoc Aircraft - Electric - Power Systems (FS/W) 9 Aug 28, 2011 09:16 AM
Discussion 3dhs edge 41" edge as second ish) plane? Mr Bloppy 3D Flying 19 Aug 25, 2010 09:43 AM
Wanted Wanted - 47" - 58" 3DHS, EF or Sebart plane paintball_kidz Aircraft - Electric - Airplanes (FS/W) 0 Jan 02, 2010 11:12 PM
Wanted 47"-58" size 3DHS, Sebart or Extreme Flight paintball_kidz Aircraft - Electric - Airplanes (FS/W) 13 Jan 02, 2010 12:52 AM
