Old Dec 20, 2012, 03:58 PM
zmonster97 is offline
Find More Posts by zmonster97
Team Aztech Aeromodels!
zmonster97's Avatar
United States, PA, Allentown
Joined May 2011
I'm selling 4 hs-225mg servos if anybody is interested.
http://www.rcgroups.com/forums/showthread.php?t=1792569
zmonster97 is offline Find More Posts by zmonster97
Old Dec 20, 2012, 04:33 PM
SteveT. is offline
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Originally Posted by keithy4129 View Post
i thought I had read somewhere that on the ice with the logging enabled, you would get less power, that could of been a firmware fix or something, maybe there is no logging to keep the price down, I think its pretty cheap considering you no longer need a seperate bec.
No, it doesn't cause a power loss that I am aware of (but that just may mean I'm not aware of it), however, what it can do if you turn the sampling rate up, the logging can cause the CPU in the ESC to overload, and cause the ESC to lose synchronization of the commutation with the motor, causing a knocking sound, which might, if bad enough, possibly cause some loss of power...but only if the logging is set to high...I set it for one or two samples per second..
SteveT
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Dec 22, 2012, 01:18 AM
Aklik is offline
Find More Posts by Aklik
Aklik's Avatar
United States, OH, Sidney
Joined Feb 2011
Originally Posted by Luv3d View Post
If you don't need speed, go with a 16x7. Great flight times and a nice sized disk. Did I mention RIDICULOUS power??? You'll think the plane has gone plaid (Spaceballs, anyone....)
ludicrous!! lol
Aklik is offline Find More Posts by Aklik
Old Dec 23, 2012, 08:43 PM
JimTMich is offline
Find More Posts by JimTMich
God is my pilot
JimTMich's Avatar
United States, MI, Kalamazoo Township
Joined Aug 2006
Edge arrived safe and sound
JimTMich is offline Find More Posts by JimTMich
Old Dec 24, 2012, 05:00 PM
zmonster97's Avatar
Joined May 2011
I just replaced the hs-225mg servos I had in this plane with some Spektrum A5040 servos. Boy are they awesome! They sound great and are fast! And now I can take advantage of the 11ms mode of my dx8 with these digital servos!
One step closer to flying again!
Old Dec 24, 2012, 05:15 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
What servo arms did you use with those servos?
SteveT
Old Dec 24, 2012, 05:18 PM
zmonster97's Avatar
Joined May 2011
The DUB-671 arms.
http://www3.towerhobbies.com/cgi-bin...&I=LXD669&P=ML
zmonster97's Avatar
Joined May 2011
Double post.
Old Dec 24, 2012, 05:27 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
Originally Posted by zmonster97 View Post
Ok...JR compatible then...
SteveT
Old Dec 24, 2012, 07:19 PM
zmonster97's Avatar
Joined May 2011
SteveT
Yup!
Old Dec 26, 2012, 09:10 AM
Trill is offline
Find More Posts by Trill
Trill's Avatar
United States, TN, Murfreesboro
Joined Oct 2008
Best all around 57" to 64" 3D plane
Originally Posted by wamsy55 View Post
http://www.youtube.com/watch?v=5KnZtIuIbBo
Video of my 58" Edge.
Motrofly 4315-714 on 4s.
Originally Posted by losifanatic
The 60 edge is not a high energy plane.
The 58edge to ne is easier to harrier than the mxs and is more violent. The 58 edge is freakin awesome.
Now I want both a 58" Edge and a 64" MXS! But if I can have only one, do I get the 58" Edge or the 64" MXS? l'm told that the 58" Edge has rudder and elevator authority as good as that of the MXS.
What is your experience with the flight envelopes of the two planes?
Trill is offline Find More Posts by Trill
Old Dec 26, 2012, 01:38 PM
Luv3d is online now
Find More Posts by Luv3d
Honeybadger don't care...
Luv3d's Avatar
United States, FL, Winter Park
Joined May 2010
The only way I could answer this is to ask another question....do you care much about precision flying? The MXS does it pretty well; Edge's are notorious for being a bit less 'precise'. I can attest to the pitch rate of the edge, and I think it's close to the MXS, but not better than the MXS. If it's hard core 3D only...either one is a winner for you. If it's precision- my preference would be to look at the MXS, for that small edge in it's airframe DNA.
Just my $.02
I own one of these, but have flown both....I am happy with how this flies, but have only flown it once or twice...
Luv3d is online now Find More Posts by Luv3d
Old Dec 26, 2012, 06:31 PM
edf_rookie is offline
Find More Posts by edf_rookie
edf_rookie's Avatar
Australia, QLD, Brisbane
Joined Mar 2011
[QUOTE=wamsy55;23559914]Not sure of length as of right now. I will check sometime today. .
Hey wamsy, did you manage to get a chance to look at what length spacers you needed on the motrofly?
edf_rookie is offline Find More Posts by edf_rookie
Old Dec 26, 2012, 07:25 PM
nebwake is offline
Find More Posts by nebwake
nebwake's Avatar
United States, NE, Lincoln
Joined Mar 2011
The idea that edges are not precise is a little too general. The only thing that modern airframe edges seem to not do as well as an extra are snaps. This is due to the wing. Another thing that some edges tend to do is roll out of heavy elevator moves like a wall. That said much of that has to do with using a little too much throw. If guys reduce their throw a little bit or have a middle rate for elevator this can be reduced. As far as being able to perform big smooth maneuvers, on low rates, this plane will keep up with my slick 1 for 1 and nearly as good as my big gassers.
nebwake is offline Find More Posts by nebwake
Old Dec 26, 2012, 07:32 PM
rcbirk21 is offline
Find More Posts by rcbirk21
Barefoot Birkinsomething
rcbirk21's Avatar
United States, CA, Hayward
Joined Aug 2004
hows the centering on them? seem to be very close spec wise (although not identical) to the savox 1250mg, but less than half the cost. would be a great budget option if they center well. also, are you running them on 6v?
rcbirk21 is offline Find More Posts by rcbirk21
Discussion 60 inch edge 540 vs 48 inch extreme flight extra 300 & edge 540 vs 3dhs slick 51 & 59 CRFan1 3D Flying 40 Mar 04, 2012 02:45 PM
Sold 3DHS Omega 130g NIB 58.00 Shipped boatdoc Aircraft - Electric - Power Systems (FS/W) 9 Aug 28, 2011 09:16 AM
Discussion 3dhs edge 41" edge as second ish) plane? Mr Bloppy 3D Flying 19 Aug 25, 2010 09:43 AM
Wanted Wanted - 47" - 58" 3DHS, EF or Sebart plane paintball_kidz Aircraft - Electric - Airplanes (FS/W) 0 Jan 02, 2010 11:12 PM
Wanted 47"-58" size 3DHS, Sebart or Extreme Flight paintball_kidz Aircraft - Electric - Airplanes (FS/W) 13 Jan 02, 2010 12:52 AM
