Old Nov 26, 2012, 06:51 PM
SteveT. is online now
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Ok....Easily made 58" Edge SFG's. The original ones seem to be made of Liteply, which unless you are going to have them laser cut, would be a bit more difficult to make. I can do a drawing of them, but as this is a product that I believe 3DHS would normally sell. I would be infringing on their design.
So....as noted, the center piece will be made from 1/8" Liteply, and the frame from 1/8"X1/2" hard balsa. As you see, the front hole is in the balsa area, so make sure you harden that area with CA glue.
Unfortunately, the .pdf file comes out too large to be saved here, but you can PM me with your email address and I will most happily send it to you.
Once you get the .pdf file, you can print it onto full sheet stick on label material, ans use it as a template to cut your pieces. Make sure that you set your printer to print at full size (I.E. not to enlarge or reduce) You may also be able to do this with the .jpeg file, but I have never had good luck getting .jpeg files to print at the correct size. If you do just want to try to scale the .jpeg file, then the over-all length of the SFG is 7.75"
Ignore the vertical line on the right hand side, it was just a reference line that I forgot to erase...
SteveT
SteveT. is online now Find More Posts by SteveT.
Old Nov 27, 2012, 02:52 PM
RCPilot1234 is offline
Find More Posts by RCPilot1234
Joined Jan 2012
Thanks so much Steve, much much appreciated!
As a Christmas present for your generosity on RCGroups over this year, I just ordered you those Grasmere Gingerbreads you asked for - "Hand-crafted wooden box containing 12 pieces of gingerbread and 170g/6oz traditional Cumberland Rum Butter". More details in the PM
Once again thanks!
RCPilot1234 is offline Find More Posts by RCPilot1234
Old Nov 27, 2012, 04:03 PM
SteveT.'s Avatar
San Jose, CA
Outstanding Sir!! And I really do appreciate your kindness in doing so...
SteveT
Latest blog entry: My hangar...
Old Nov 27, 2012, 04:07 PM
Joined Jan 2012
SteveT
Thanks It's the very least I can do!
Old Nov 30, 2012, 09:25 PM
SteveT.'s Avatar
San Jose, CA
Once again thanks!
SteveT
Got it!! And already shared some with my wife!! Very Good!!
Thanks again my friend!!
SteveT
Old Dec 01, 2012, 04:30 AM
Joined Jan 2012
SteveT
More than welcome! The delivery was certainly a lot quicker than I thought, haha!
Old Dec 01, 2012, 02:14 PM
Komet ME163 is offline
Find More Posts by Komet ME163
Komet ME163's Avatar
E TN
Joined Jan 2003
successful madien today plus one more flt. Wow this airplane has some elevator authority. My setup is motrofly 3620-464, apc15 x 8, cc ice 100, and bec pro, skylipo 2650's (2ea for 6s) did battery shelf mod and gear mod. ADC vinly turned out cool. Will try to post pics if I can figure it out.
Bill
Komet ME163 is offline Find More Posts by Komet ME163
Old Dec 01, 2012, 02:46 PM
SteveT.'s Avatar
San Jose, CA
I guess it's because things don't have to go through a customs inspection like it does in England...we also don't have to pay any customs fees....
SteveT
Old Dec 01, 2012, 04:06 PM
3DeltaFly is offline
Find More Posts by 3DeltaFly
Byron C
3DeltaFly's Avatar
United States, TN, Knoxville
Joined Apr 2011
Bill
Sounds good. I'm running the EF Torque 4016T/500 Mk-II, Xoar 16x8, Sky 4000's, 5S. This plane would make a good pylon racer Great speed for precision, but slows down nicely for in close 3D. 7:30 minute flight times of mixed speed precision and post stall 3D, and the 5S pack comes down at 3.88 volts per cell. I'm liking it
See that you're in E. TN. I'm just N. of Knoxville out in the boonies. By chance do you fly at HMRC?
Byron
3DeltaFly is offline Find More Posts by 3DeltaFly
Old Dec 01, 2012, 04:48 PM
Joined Jan 2012
SteveT
Damn that's awesome! Only way we get no customs is if it comes from within the EU... Otherwise then BAM, your next day delivery turns into a month delivery, haha!
Old Dec 01, 2012, 06:15 PM
E TN
Joined Jan 2003
hey 3delta i fly at HMRC ocassionaly, live in Maryville, so BCMA is regular flying field. Like wide openness at house but Blount co is 5 min from house.
Bill
Old Dec 01, 2012, 07:23 PM
SteveT.'s Avatar
San Jose, CA
Got mine well on the way to being done, then realized I am one "Spot-on" servo arm short....ARGGGHHHHH!!!!
SteveT
Old Dec 03, 2012, 05:14 AM
Byron C
3DeltaFly's Avatar
Joined Apr 2011
Bill
Ah, very good. I checked and found the BCMA website. Good looking flight field you all have, and super nice runway.
Byron
Old Dec 03, 2012, 07:59 AM
E TN
Joined Jan 2003
Yea and we added another 50 ft to it. It does seem winder up on the hill though and you do get good at crosswind landings. Come down sometime
Bill
Old Dec 09, 2012, 09:04 PM
SteveT.'s Avatar
San Jose, CA
Finished up my Edge today..... balanced perfectly with the A50-14XS and 5S 4000mAH packs with the back end of the battery right at the end of the back of the motor box. These packs might be a bit heavy for some, but as I am not an accomplished 3D Pilot, they will do until I can get some 3600's or something like that. Right now I have a Xoar 15X8 on it, but may try a Xoar 16X7, both of these props are the sizes of props suggested by Aero-Model (though they actually suggested APC)....so we'll see....
SteveT
Discussion 60 inch edge 540 vs 48 inch extreme flight extra 300 & edge 540 vs 3dhs slick 51 & 59 CRFan1 3D Flying 40 Mar 04, 2012 02:45 PM
Sold 3DHS Omega 130g NIB 58.00 Shipped boatdoc Aircraft - Electric - Power Systems (FS/W) 9 Aug 28, 2011 09:16 AM
Discussion 3dhs edge 41" edge as second ish) plane? Mr Bloppy 3D Flying 19 Aug 25, 2010 09:43 AM
Wanted Wanted - 47" - 58" 3DHS, EF or Sebart plane paintball_kidz Aircraft - Electric - Airplanes (FS/W) 0 Jan 02, 2010 11:12 PM
Wanted 47"-58" size 3DHS, Sebart or Extreme Flight paintball_kidz Aircraft - Electric - Airplanes (FS/W) 13 Jan 02, 2010 12:52 AM
