Old Nov 20, 2012, 07:05 PM
Bivens is offline
Find More Posts by Bivens
Team 3DHS / Team JR
Bivens's Avatar
United States, TN, Knoxville
Joined Apr 2010
Originally Posted by cookci View Post
Ok I have the fuselage as long as it can be now (by having the cowel as far forward as possible)... this helps with tracking quite a bit
Great. Glad that worked out. A simple thing but it has more effect on this airframe than others in the 5x" class.
Bivens is offline Find More Posts by Bivens
Old Nov 21, 2012, 02:57 AM
cookci is offline
Find More Posts by cookci
Joined Jul 2011
Originally Posted by SteveT. View Post
Yes, but it is NIB...I have flown my 55" Edge quite a bit though....
SteveT
you don't need an addiction to learn to Harrier. This edge is the most stable model I have ever flown in a harrier... it almost does if for you
cookci is offline Find More Posts by cookci
Old Nov 21, 2012, 01:45 PM
SteveT. is offline
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
I know...I would just like to trash an addiction!! And wouldn't feel a bit bad about it when I did....
SteveT
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Nov 21, 2012, 01:50 PM
jimmy34256 is offline
Find More Posts by jimmy34256
Destructive Tester
jimmy34256's Avatar
Tampa, FL
Joined Apr 2008
SteveT
they are easily trashable......
jimmy34256 is offline Find More Posts by jimmy34256
Old Nov 21, 2012, 01:57 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
True that!!
SteveT
Old Nov 22, 2012, 08:01 AM
cookci is offline
Joined Jul 2011
Does anyone know the size (diameter) of the metal control rods as I would like to replace them all with fully threaded rod so I can get a ball joint at each end.
I could probably measure myself however I would be concerned I would get it slightly wrong
There is a little play on all of my controls.
Old Nov 22, 2012, 08:20 AM
Luv3d is offline
Find More Posts by Luv3d
Honeybadger don't care...
Luv3d's Avatar
United States, FL, Winter Park
Joined May 2010
2mm, I believe. The Ball links are 2mm, so the rod must be 2mm...
I am using 2-56 dubro ball links on both ends, and 2-56 threaded rod with a CF sleeve for the ailerons and elevator.
Luv3d is offline Find More Posts by Luv3d
Old Nov 22, 2012, 11:12 AM
cookci is offline
Joined Jul 2011
so this should do the job?
http://www.ebay.co.uk/itm/STAINLESS-...item3f105826b8
Old Nov 22, 2012, 11:20 AM
Luv3d is offline
Luv3d's Avatar
Joined May 2010
I would think that would work great! I would also caution the use of the threaded rod by itself. A short length might be ok, but like this ARF, a carbon sleeve would be a good choice on the elevator. A particularly cautious person might put some on the ailerons too....that's what I'm planning to do (if I have the space on the linkage).
Old Nov 22, 2012, 11:37 AM
cookci is offline
Joined Jul 2011
Or I guess it could be worth considering getting some threads put on the existing control rods but I have no idea how to do that
Old Nov 22, 2012, 12:46 PM
3DeltaFly is offline
Find More Posts by 3DeltaFly
Byron C
3DeltaFly's Avatar
Joined Apr 2011
That's what I did. Easy enough to do by soldering on 2-56 threaded brass couplers. 2mm threaded couplers work too.
3DeltaFly is offline Find More Posts by 3DeltaFly
Old Nov 22, 2012, 01:08 PM
cookci is offline
Joined Jul 2011
What do i need to thread the rod?
Old Nov 22, 2012, 01:25 PM
RCPilot1234 is offline
Find More Posts by RCPilot1234
Joined Jan 2012
Hi everyone
I'm gonna be sticking some Aurora RC Andromeda lights on this in January. I have two options: glue the lights to the SFGs and use the SFGs as the mounting method or have the lights and SFGs independent (this would mean the SFGs and lights couldn't be used at the same time).
So my question is... how much difference do the SFGs make on this?
Thanks!
RCPilot1234 is offline Find More Posts by RCPilot1234
Old Nov 22, 2012, 01:57 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
The ball links themselves are M2, but the rod diameter is M2.5.
SteveT
Old Nov 22, 2012, 02:10 PM
Byron C
3DeltaFly's Avatar
Joined Apr 2011
No need to thread the push-rod when using soldered on "threaded couplers". These fit the original metal push-rod's diameter, and also the DuBro 2-56 ball links. You'll use only one DuBro 2-56 ball link per push-rod since there's already a ball link on one end of the push-rod (if assembled as per build manual inst.)
http://www3.towerhobbies.com/cgi-bin...?&I=LXK088&P=7
Discussion 60 inch edge 540 vs 48 inch extreme flight extra 300 & edge 540 vs 3dhs slick 51 & 59 CRFan1 3D Flying 40 Mar 04, 2012 02:45 PM
Sold 3DHS Omega 130g NIB 58.00 Shipped boatdoc Aircraft - Electric - Power Systems (FS/W) 9 Aug 28, 2011 09:16 AM
Discussion 3dhs edge 41" edge as second ish) plane? Mr Bloppy 3D Flying 19 Aug 25, 2010 09:43 AM
Wanted Wanted - 47" - 58" 3DHS, EF or Sebart plane paintball_kidz Aircraft - Electric - Airplanes (FS/W) 0 Jan 02, 2010 11:12 PM
Wanted 47"-58" size 3DHS, Sebart or Extreme Flight paintball_kidz Aircraft - Electric - Airplanes (FS/W) 13 Jan 02, 2010 12:52 AM
