Old Oct 18, 2012, 10:37 AM
keithy4129 is offline
Find More Posts by keithy4129
United States, NJ, Clayton
Joined Aug 2010
Originally Posted by H.D. View Post
The yellow 58" Edge will be back in stock mid November.
I have the 41" and 48" Edge and will be getting the 58" Edge in Yellow.
Congrats!
keithy4129 is offline Find More Posts by keithy4129
Old Oct 21, 2012, 01:31 AM
SnowDog1974 is offline
Find More Posts by SnowDog1974
SnowDog1974's Avatar
United States, IL, Crystal Lake
Joined Jan 2009
58" Yellow Edge's rock! I'm going to fly mine in the morning!
SnowDog1974 is offline Find More Posts by SnowDog1974
Old Oct 21, 2012, 02:28 PM
Joined Aug 2010
brought the edge to the club yesterday, this thing rocks, the crazy amount of elevator authority inspires confidence, so awesome!
Old Oct 21, 2012, 03:31 PM
H.D. is offline
Find More Posts by H.D.
ride hard and fly low
H.D.'s Avatar
Joined Aug 2011
great flying yesterday, KE spins, mixers, flat spins, rollers, what can't you do with that plane????????????????????
H.D. is offline Find More Posts by H.D.
Old Oct 21, 2012, 04:36 PM
Joined Aug 2010
you forgot about "tumblers" lol
Old Oct 22, 2012, 08:09 AM
lowkeylaidback is offline
Find More Posts by lowkeylaidback
Custom Crasher
lowkeylaidback's Avatar
USA, FL, Jacksonville
Joined Jan 2010
Wanted 3dhobbyshop 48" EPP Extra 330 Starboard main wing
Each post of this request was meant to target buyers of models from 3DHS that may like most have more then one model from that vendor as many here and do not use the classified adds this seem to be the only way to reach the buyers of this brand. A little dog not mine ruined my wing and I have not gotten a response from 3DHS since 10/9 about getting a new wing, as the wing is the only part that is damaged I am searching for a replacement
I need the starboard main wing for a 3dhobbyshop 48" EPP Extra 330, if you have one I am in the market, please send me a PM
lowkeylaidback is offline Find More Posts by lowkeylaidback
Old Nov 01, 2012, 08:26 PM
Luv3d is online now
Find More Posts by Luv3d
Honeybadger don't care...
Luv3d's Avatar
United States, FL, Winter Park
Joined May 2010
58" Edge Ultracote
3DHS just replied to a note I sent asking for the colors on this plane (just to confirm):
Red Edge uses True Red ultracote: HANU866
Yellow Edge uses Bright Yellow ultracote: HANU872
Both use White ultracote: HANU870
....and Black ultracote: HANU874
Luv3d is online now Find More Posts by Luv3d
Old Nov 11, 2012, 12:53 PM
cookci is offline
Find More Posts by cookci
Joined Jul 2011
Hello,
I own one of the edges and very impressed with it for 3D however sometimes it doesn't feel all that precise... is it just me?
I have spotted the extreme flight 60" EXP, will this be much more precise for drawing some lines?
cookci is offline Find More Posts by cookci
Old Nov 11, 2012, 01:39 PM
nebwake is offline
Find More Posts by nebwake
nebwake's Avatar
United States, NE, Lincoln
Joined Mar 2011
If it seems sloppy, move the CG forward a bit. That said it is not as precise as the slicks or vipers
nebwake is offline Find More Posts by nebwake
Old Nov 11, 2012, 01:47 PM
cookci is offline
Joined Jul 2011
its as far forward as i can get it... I will measure to be sure.
So its not as precise as the slicks but presumably its precise enough for most fliers or is it best to keep this one to 3D only? Is there a big enough difference to justify owning an Extra 60" EXP also?
Old Nov 11, 2012, 02:23 PM
Luv3d is online now
Luv3d's Avatar
Joined May 2010
The answer to that depends on what you want to do. If you want an all-out 3D machine, this Edge is probably better for you. If you want something that is more Hybrid-like (meaning does great 3D and has a 'bend' towards precision), the EF Extra is fantastic. I can't speak to the Edge, because I haven't flown mine yet (but it's an EDGE- it will be spectacular in 3D, right!!!). I have flown the EF Extra (48" and 60").
Old Nov 11, 2012, 02:28 PM
cookci is offline
Joined Jul 2011
I want to able to perform a mixture in my flights.
The 3D part is ok however I currently struggle a bit with the precision however the edge is massively still more precise than my goldwing Yak 54 30cc.
On the flip side my edge doesn't seem as precise as my sebart sukhoi 30E on 3 cell!!
Old Nov 11, 2012, 02:31 PM
Luv3d is online now
Luv3d's Avatar
Joined May 2010
Setup "properly"- and I'm not sure I am the person to define that- I'm sure this Edge will draw some pretty nice lines for the precision work, but again- I am not flying mine yet...
Old Nov 11, 2012, 02:42 PM
cookci is offline
Joined Jul 2011
I could probably gain upto another centimeter in length by pulling forward the cowl and extending using some washers the motor mount.
Do you think a cm would make any difference or is it length behind the wings which helps with precision?
Old Nov 11, 2012, 03:19 PM
Luv3d is online now
Luv3d's Avatar
Joined May 2010
I think that is really about what feels good for you. Nose heavy, or extremely nose heavy reduces the model's reaction to inputs. Neutral to even a slightly tail-heavy CG is good for 3D. I'm not a precision guy, per se, but I do enjoy flying sequences- and the challenge that they present. For that, I prefer my CG to be just forward of neutral. I want to hold just a bit of up trim to maintain level inverted flight, but that is just my personal preference.
Length behind the wing for battery (or any other weight) will not help precision, but it will affect the way the plane reacts to inputs- the more tail-heavy it is, the more pitch and roll sensitive it will become.
Discussion 60 inch edge 540 vs 48 inch extreme flight extra 300 & edge 540 vs 3dhs slick 51 & 59 CRFan1 3D Flying 40 Mar 04, 2012 03:45 PM
Sold 3DHS Omega 130g NIB 58.00 Shipped boatdoc Aircraft - Electric - Power Systems (FS/W) 9 Aug 28, 2011 10:16 AM
Discussion 3dhs edge 41" edge as second ish) plane? Mr Bloppy 3D Flying 19 Aug 25, 2010 10:43 AM
Wanted Wanted - 47" - 58" 3DHS, EF or Sebart plane paintball_kidz Aircraft - Electric - Airplanes (FS/W) 0 Jan 03, 2010 12:12 AM
Wanted 47"-58" size 3DHS, Sebart or Extreme Flight paintball_kidz Aircraft - Electric - Airplanes (FS/W) 13 Jan 02, 2010 01:52 AM
