Old Aug 09, 2012, 05:15 PM
Bivens is offline
Find More Posts by Bivens
Team 3DHS / Team JR
Bivens's Avatar
United States, TN, Knoxville
Joined Apr 2010
...After measuring I found that the rudder is slightly slanted at a verticle angle.....
Originally Posted by eschult View Post
...I found that the horizontal stab is completely warped. Not even sure if it can be corrected as the covering was so tight it seemed liked it had been ironed. I took a popsicle and went under the covering to release it from the balsa. Anyone know what I can do to fix this ??? The only way I can think of it by playing the iron game but I am not sure it would work. I am talking about a 1/4 difference when placing a t-square next to the stab.
Thanks for the info,
Eric
Ok...the Rudder/vertical stab....OR the horizontal stab (the one with elevators on it)...which one is out of place? Both? One post states rudder, the other states horizontal stab....
Bivens is offline Find More Posts by Bivens
Old Aug 09, 2012, 07:31 PM
eschult is offline
Find More Posts by eschult
FLYINGJUNKY
eschult's Avatar
USA, FL, Jacksonville
Joined Mar 2008
OOOPs!!! I meant the vertical stab. Horizontal would be an easy flix w/ a shim, but the vertical has me stumped. I took the landing gear off and placed the fuse on a flat table in hopes that the wheels might be off set but no luck. Any suggestions would be great!!!
Thanks, eric
eschult is offline Find More Posts by eschult
Old Aug 09, 2012, 07:44 PM
jimmy34256 is online now
Find More Posts by jimmy34256
Destructive Tester
jimmy34256's Avatar
Tampa, FL
Joined Apr 2008
CFG's work great!!!!!!!!! I noticed a big difference on an inverted harrier. i did come accross a problem with the rudder. I went to tighten up my tail wheel today and looking from the top of the plane i noticed that the rudder seems a little off. After measuring I found that the rudder is slightly slanted at a verticle angle. When I completed my build everything was perfect. I am sure that the fuse must be a little twisted by the hor. stab. I have built well over 20-25 planes and this is the first time I seen this happen. Not sure if the heat(from outside) made the balsa swell and then the stab shifted. Never hit it with an iron so i know that's its not the covering. I guess I will have to hit the hor. stab with some de-bonder and then try and open it up a little with an blade. funny part is I could not tell at all with 4 flights this morning. I just hope that I can give the stab a little wiggle room w/o having to remove the rudder hinges. any body ever had this happen????
Carefully run a box cutter blade down both sides of the stab into the joints. Then shim it square and hit with thin CA.
BTW I worked on the plane in your avatar (VF-84 USS Nimitz) GO NAVY !
jimmy34256 is online now Find More Posts by jimmy34256
Old Aug 09, 2012, 08:12 PM
eschult is offline
FLYINGJUNKY
eschult's Avatar
Joined Mar 2008
I already ripped it all apart. Took the elevator off also. I started using a blade to remove the stab and then thought of something else. I hit the joints with some debonder and then used 10 lb. fishing line and ran it through both sides. I then used the fishing line and used it like a saw to work through the ca. Not sure if the shim will work to correct the vert. stab.
Thanks,Eric
Old Aug 09, 2012, 08:35 PM
Bivens is offline
Team 3DHS / Team JR
Bivens's Avatar
Joined Apr 2010
If you were creative enough to remove them with little damage...I'm sure you'll be able to get them in place straight before it's all over...
Old Aug 09, 2012, 09:32 PM
eschult is offline
FLYINGJUNKY
eschult's Avatar
Joined Mar 2008
I am sure I will figure out a way. Just like to ask someone elses advice as maybe they have a better idea than what i might be thinking at the time. I think i am going to mix up some epoxy and add some micro baloon filler. I am gonna sleep on it and maybe in the morning I might have a better way.
Thanks for the help.
Eric
Old Aug 10, 2012, 06:58 AM
nebwake is offline
Find More Posts by nebwake
nebwake's Avatar
United States, NE, Lincoln
Joined Mar 2011
That fishing line trick is nice, it should be easier to ship planes with that one!
nebwake is offline Find More Posts by nebwake
Old Aug 10, 2012, 05:02 PM
eschult is offline
FLYINGJUNKY
eschult's Avatar
Joined Mar 2008
All fixed!!!!! Card stock and thin ca work the best for shims. Easier to work with than adding balsa shims. The ca turns the cardstock hard as a rock. Placed the horizontal stabilizer in the fuse and added a few shims to the top left and then a few to the bottom right. ( with the fuse laying flat on the table)Took some painters tape and ran one strip from the top of the vert. stap and stuck it to the side of the table and then did the same thing with the other side. This pulled the vert. stab into place. I then hit both sides of the fuse w/ an iron and then placed some thin ca in the joints of the horiz. stab. Let it sit for a minute and I had a perfectly straight rudder. No more twist in the back of the fuse!!!!!!!!!!! I could of let it go and left the rudder as is but everytime i put the edge in the air i would of been looking at that slant.
Thanks, Eric
Old Aug 10, 2012, 06:36 PM
keithy4129 is offline
Find More Posts by keithy4129
United States, NJ, Clayton
Joined Aug 2010
Thanks, Eric
congrats dude
keithy4129 is offline Find More Posts by keithy4129
Old Aug 10, 2012, 07:11 PM
nebwake is offline
nebwake's Avatar
Joined Mar 2011
Welp, after some hiccups like forgetting to glue in my aileron hinges and having to land that mess, the plane fly's awesome. I like it much better than the 59" slick. the SFG's do make a big difference but slows the roll rate. Overall I'm very happy and thrilled that it fly's so well.
Old Aug 10, 2012, 08:03 PM
eschult is offline
FLYINGJUNKY
eschult's Avatar
Joined Mar 2008
did you have to land w/o ailerons????
Old Aug 10, 2012, 08:21 PM
eschult is offline
FLYINGJUNKY
eschult's Avatar
Joined Mar 2008
That reminds me of a funny story. I taught myself to fly with a 3 chanel hobbyzone firebird and the v-tail was installed backwards at the factory. I flew that plane for about 2 months with the left and right pushrods on backwards. Everytime I crashed and had to re-build i installed them on backwards again. I had a freind come over and while i was flying it he asked for the tx to see how it flew. He had been lying for years and as soon as he pushed the stick left and the plane went right he throught the tx back in my hands and asked me what the hell i was doing flying the plane in reverse controls. I had to learn all over!!!!!!! About a year later i got my first balsa plane, greatplanes edge 51. I had gone to the feild one morning and a few guys were flying already. I started talking to them and w/o knowing I must have reversed the airelons on my dx5. I did not do a flight check and then took off. Holy #@%$% I relized what i had did and started to panic. I flew it up pretty high and started to get used to the directions. Because of that stupid hobbyzone being backwards when i first started i was able to fly the plane and land w/o a scratch on it!!!!!!!!!! Funny how things happen like that!!! LOL
Old Aug 10, 2012, 09:51 PM
bikeman is offline
Find More Posts by bikeman
bikeman's Avatar
United States, PA, Ephrata
Joined Dec 2005
Wow, that is a lot. I have nowhere near that much roll. I don't even mix out my edges. There has to be something going on with your setup if you are seeing that much roll....But I'm not sure what.
Yeah my thoughts as well. I'll have to look into it. I noticed on ailerons the centering seemed off on the servos. Or what I thought was servos. I wonder if I do have a warp and that would explain why at various speeds I'm always trimming ailerons. A couple days ago I had a mishap of the rudder servo arm backing off the servo output shaft during a hover (servo arm screw backed out in flight - a first for me). Plane yawed and when I hit the rudder I got nothing. Managed to roll it level before I belly flopped it down and tore out the gear mount. So, while it's being repaired I'll put a couple incidence meters on the wings and see if I have a warp.
bikeman is offline Find More Posts by bikeman
Old Aug 11, 2012, 09:32 AM
nebwake is offline
nebwake's Avatar
Joined Mar 2011
The left aileron got stuck in a downward position and I had to feed left hard right aileron in to keep it from rolling, which gave it about 30* of down flaps, I also had zero roll! it was a little harry but she came down in one piece.
Old Aug 13, 2012, 07:11 AM
Bivens is offline
Team 3DHS / Team JR
Bivens's Avatar
Joined Apr 2010
#1...Poorly centering servos are almost ALWAYS a problem...causing constant trim changes = not fun.
#2....Incidence on these ARFS is almost NEVER a problem. Sure, there can be a little warp in an aileron or elevator, rarely in the wing itself, and the laser-cut locating pin holes on the fuse are very consistent. THOUSANDS of the planes are out there, and almost nobody building and flying today even knows what an incidence meter is.
#3....It is possible that your elevator joiner is "twisted" somewhat and the elevator halves are a little off center....but even this rarely causes significant trouble.
Take care of the poorly centering servos first....and while you are at it, verify that you have no binding in any control linkages. Run the servos on their maximum allowable voltage too. Let us know what you find out...
Discussion 60 inch edge 540 vs 48 inch extreme flight extra 300 & edge 540 vs 3dhs slick 51 & 59 CRFan1 3D Flying 40 Mar 04, 2012 02:45 PM
Sold 3DHS Omega 130g NIB 58.00 Shipped boatdoc Aircraft - Electric - Power Systems (FS/W) 9 Aug 28, 2011 09:16 AM
Discussion 3dhs edge 41" edge as second ish) plane? Mr Bloppy 3D Flying 19 Aug 25, 2010 09:43 AM
Wanted Wanted - 47" - 58" 3DHS, EF or Sebart plane paintball_kidz Aircraft - Electric - Airplanes (FS/W) 0 Jan 02, 2010 11:12 PM
Wanted 47"-58" size 3DHS, Sebart or Extreme Flight paintball_kidz Aircraft - Electric - Airplanes (FS/W) 13 Jan 02, 2010 12:52 AM
