Old Jul 29, 2012, 01:09 PM
jmanopla is offline
Find More Posts by jmanopla
Joined Dec 2009
can someone SENDme the manual of the Plane
jmanopla is offline Find More Posts by jmanopla
Old Jul 29, 2012, 01:24 PM
SteveT. is online now
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
I don't believe there is one, use the manual for the 57" Extra found here, and check out all the photos in the thread by clicking on the "thread tools" tab, then the "show attachments in this thread" tab....this will point out any differences in the build of the plane. As to CG...it looks like 3.75" is the sweet spot.
SteveT
SteveT. is online now Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Jul 29, 2012, 02:34 PM
keithy4129 is offline
Find More Posts by keithy4129
United States, NJ, Clayton
Joined Aug 2010
still no manual? mine has been built for months incredible.
keithy4129 is offline Find More Posts by keithy4129
Old Jul 29, 2012, 03:08 PM
SteveT.'s Avatar
San Jose, CA
None shown on the 3DHS site....
SteveT
Old Jul 29, 2012, 04:26 PM
Joined Aug 2010
SteveT
wow.....
Old Jul 29, 2012, 05:22 PM
jimmy34256 is offline
Find More Posts by jimmy34256
Destructive Tester
jimmy34256's Avatar
Tampa, FL
Joined Apr 2008
Manual ????
1) Open box, take stuff out.
2) Install landing gear
3) Cut holes in fuse.
4) Install stablizer, glue hinges
5) Install rudder, glue hinges
6) Install tailwheel
7) Install wings, glue hinges
8) Install servos, control horns and arms
9) Install motor and ESC
10 Install receiver, battery and bind
11) Trim all surfaces
12) Install canopy and cowl
13) Install prop and go fly
c/g has already been covered here....
jimmy34256 is offline Find More Posts by jimmy34256
Old Jul 29, 2012, 05:25 PM
Joined Aug 2010
12) Install canopy, cowl and fly
That works well for those of us who have built a few, but for someone with limited experience a manual is would be helpful because it has pictures.
Old Jul 29, 2012, 06:10 PM
nebwake is offline
Find More Posts by nebwake
nebwake's Avatar
United States, NE, Lincoln
Joined Mar 2011
They only use one manual for each size, use the one for the 57" extra, they will go together the same
nebwake is offline Find More Posts by nebwake
Old Jul 29, 2012, 07:33 PM
Joined Aug 2010
?? 57" extra, 59" slick have there own manual, my 46" yak, 47"shp, 48" vr-1 have manuals as well, even a pdf manual that someone can print would be fine, what if somebody who doesnt use rcg wants to build there 58" edge, then they dont even have cg info to get it balanced after they figure out how to build. just my opinion.
Old Jul 29, 2012, 08:37 PM
SteveT.'s Avatar
San Jose, CA
Old Jul 29, 2012, 09:16 PM
jmanopla is offline
Joined Dec 2009
Thankss built its not a problem
i can built with close eyes
Old Jul 29, 2012, 11:23 PM
eschult is offline
Find More Posts by eschult
FLYINGJUNKY
eschult's Avatar
USA, FL, Jacksonville
Joined Mar 2008
SteveT
I have a manual. I am sure the person I got it from would not mind me giving out a copy. Pm me your email as its in a pdf file.
eschult is offline Find More Posts by eschult
Old Jul 30, 2012, 09:43 AM
SnowDog1974 is offline
Find More Posts by SnowDog1974
SnowDog1974's Avatar
United States, IL, Crystal Lake
Joined Jan 2009
Eric,
If you did not find any glaring errors in the manual that I created, I will go ahead and send it to 3DHS for their consideration.
Let me know, thanks.
-Mike
SnowDog1974 is offline Find More Posts by SnowDog1974
Old Jul 30, 2012, 12:08 PM
eschult is offline
FLYINGJUNKY
eschult's Avatar
Joined Mar 2008
It worked great for me but I have built alot of planes. I am sure a newby would have no problem following the set up. Only thing I would change is instal the control horns before you mount rudder and stab. I am a little concerned with my thrust angle. Does not see to be much but my other 3dhs birds do not have much either. Thanks again.
Old Jul 30, 2012, 12:15 PM
Joined Jan 2009
The order of steps is the same as the 55" Edge, I did not feel it was my place to change the established installation order. Never had to worry about thrust angles on any 3DHS bird....it is always built in to the motor box.
Thanks for the feedback.
Discussion 60 inch edge 540 vs 48 inch extreme flight extra 300 & edge 540 vs 3dhs slick 51 & 59 CRFan1 3D Flying 40 Mar 04, 2012 03:45 PM
Sold 3DHS Omega 130g NIB 58.00 Shipped boatdoc Aircraft - Electric - Power Systems (FS/W) 9 Aug 28, 2011 10:16 AM
Discussion 3dhs edge 41" edge as second ish) plane? Mr Bloppy 3D Flying 19 Aug 25, 2010 10:43 AM
Wanted Wanted - 47" - 58" 3DHS, EF or Sebart plane paintball_kidz Aircraft - Electric - Airplanes (FS/W) 0 Jan 03, 2010 12:12 AM
Wanted 47"-58" size 3DHS, Sebart or Extreme Flight paintball_kidz Aircraft - Electric - Airplanes (FS/W) 13 Jan 02, 2010 01:52 AM
