Old Jul 21, 2012, 12:34 PM
jimmy34256 is offline
Find More Posts by jimmy34256
Destructive Tester
jimmy34256's Avatar
Tampa, FL
Joined Apr 2008
Originally Posted by jimmy34256 View Post
Have the 4315-500 and a 6s 3300 pack about 1.5in from the firewall
Maidened today. 2 clicks aileron and rock and roll. Pulling 1350 watts @ 50A.
Awesomeness!
jimmy34256 is offline Find More Posts by jimmy34256
Old Jul 21, 2012, 09:50 PM
Bivens is offline
Find More Posts by Bivens
Team 3DHS / Team JR
Bivens's Avatar
United States, TN, Knoxville
Joined Apr 2010
For sure....put in bigger servos than the 5085's....those should go in a 51 or Byper! Not enough here.
Bivens is offline Find More Posts by Bivens
Old Jul 22, 2012, 06:40 AM
eschult is offline
Find More Posts by eschult
FLYINGJUNKY
eschult's Avatar
USA, FL, Jacksonville
Joined Mar 2008
I ordered new ones and moved the 5085 to my slick 51. will be putting my set of hs 85mg Up
for sale today. They should move pretty fast as they are only a month or so old.
eschult is offline Find More Posts by eschult
Old Jul 23, 2012, 06:21 PM
eschult is offline
FLYINGJUNKY
eschult's Avatar
Joined Mar 2008
Anyone know the address of 3d hobby. Need to send this motor back and can not get in touch with anyone. I have the address that came on the box. 1006 lancaster pike PA. but when i ran a search it came back as a Bike store????
Thanks,Eric
Old Jul 23, 2012, 07:34 PM
SnowDog1974 is offline
Find More Posts by SnowDog1974
SnowDog1974's Avatar
United States, IL, Crystal Lake
Joined Jan 2009
Thanks,Eric
I think that is the correct address...send a pm to noll smith (Horton on rcg) to double check.
SnowDog1974 is offline Find More Posts by SnowDog1974
Old Jul 24, 2012, 06:36 AM
jsmith285 is offline
Find More Posts by jsmith285
jsmith285's Avatar
Fort Wayne
Joined Feb 2009
1006 Lancaster Pike
Quarryville, PA, 17566
jsmith285 is offline Find More Posts by jsmith285
Old Jul 24, 2012, 08:38 AM
eschult is offline
FLYINGJUNKY
eschult's Avatar
Joined Mar 2008
Originally Posted by jsmith285 View Post
1006 Lancaster Pike
Old Jul 24, 2012, 09:05 AM
jmanopla is offline
Find More Posts by jmanopla
Joined Dec 2009
i just buy the plane plan to install a rimfire 55 , with 6s batteries what you think?
jmanopla is offline Find More Posts by jmanopla
Old Jul 24, 2012, 10:01 AM
Joined Jan 2009
Yep, that motor should work just fine, although the watt rating of the motor seems odd...my Motrofly 5315-480 on 6S pulls around 1200 watts:
SPECS: Motor Diameter: 1.7" (42mm)
Motor Length: 2.4" (60mm)
Shaft Diameter: .20" (5mm)
Shaft Length: .67" (17mm)
Lead Length: 3" (76mm)
Connectors: Bullet type, 4.0mm diameter
Max. Constant Current: 45A
Max. Surge Current: 80A
Max. Constant Watts: 830W
Burst Watts: 1850W
No Load Current: 1.5A
Input Voltage: 18.5-22.2V (5-6S LiPo)
RPM/V (kV Rating): 480
Weight: 9.5oz (268g)
Suggested Propeller Size: 13x10E - 15x8E
Old Jul 24, 2012, 01:48 PM
jmanopla is offline
Joined Dec 2009
Burst Watts: 1850W
thanks alredy i order the Rimfire 55 ,,,, im plan to Use 2x3s 2200mah 40c to get 6s , how much flying time ???? using 14x7 and 15x6 prop.... i order too 2 6s 3000mah
Old Jul 24, 2012, 02:02 PM
Joined Jan 2009
sorry...those specs I posted were for the Rimfire 55, not the Motrofly.
I have a 6S2800 setup and I get 5-7 minutes of flight time, depending on throttle control/battery consumption.
Did you say you were going with 6S2200 (very low) or 6S3000?
Old Jul 24, 2012, 02:06 PM
lammbn is offline
Find More Posts by lammbn
Hooked on 3DHS
lammbn's Avatar
United States, ID, Boise
Joined Nov 2009
my 6s 2200's give me 7:30 of flight time before i even begin my landing sequence. still come down with 3.7v and I only put about 70-75% capacity back in them for a full balance charge. i have no problems taking a pack down 80% like they where designed to be.
lammbn is offline Find More Posts by lammbn
Old Jul 24, 2012, 04:20 PM
jmanopla is offline
Joined Dec 2009
with both the 3000mah batteries are 1 PACK 6S
The 2200mah batteries are 2 packs of 3S IN Series to get 6s
Old Jul 24, 2012, 04:21 PM
jmanopla is offline
Joined Dec 2009
wich motor are you Using
im gonna use a Rimfire 55 with 14x7 and 15x6 prop
Joined Jan 2009
got it...didn't realize you had two different types of battery packs/power systems.
Discussion 60 inch edge 540 vs 48 inch extreme flight extra 300 & edge 540 vs 3dhs slick 51 & 59 CRFan1 3D Flying 40 Mar 04, 2012 02:45 PM
Sold 3DHS Omega 130g NIB 58.00 Shipped boatdoc Aircraft - Electric - Power Systems (FS/W) 9 Aug 28, 2011 09:16 AM
Discussion 3dhs edge 41" edge as second ish) plane? Mr Bloppy 3D Flying 19 Aug 25, 2010 09:43 AM
Wanted Wanted - 47" - 58" 3DHS, EF or Sebart plane paintball_kidz Aircraft - Electric - Airplanes (FS/W) 0 Jan 02, 2010 11:12 PM
Wanted 47"-58" size 3DHS, Sebart or Extreme Flight paintball_kidz Aircraft - Electric - Airplanes (FS/W) 13 Jan 02, 2010 12:52 AM
