Old Jul 19, 2012, 11:06 AM
eschult is offline
Find More Posts by eschult
FLYINGJUNKY
eschult's Avatar
USA, FL, Jacksonville
Joined Mar 2008
Originally Posted by SnowDog1974 View Post
I"m using 3S2800's in series with the Motrofly 4315 on my 58" Edge. Other than shorter flight times, those 3S2200's in series should work fine...only pulls 53amps max.
Should work fine with the a40-10s or were you refering to another motor. Thanks for the help
eschult is offline Find More Posts by eschult
Old Jul 19, 2012, 03:24 PM
SteveT. is online now
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
A40-10S motor is a 4S motor...not 6S....sure going to have to use a small prop for 6S....
SteveT
SteveT. is online now Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Jul 20, 2012, 01:28 PM
eschult is offline
FLYINGJUNKY
eschult's Avatar
Joined Mar 2008
SteveT
thanks. Ordered the motofly. Does this motor need weight on the front
Old Jul 20, 2012, 02:01 PM
SnowDog1974 is offline
Find More Posts by SnowDog1974
SnowDog1974's Avatar
United States, IL, Crystal Lake
Joined Jan 2009
which Motrofly did you get?
almost everyone has had to put some nose weight in this plane, or else shove the battery all the way up to the firewall, regardless of motor choice.
SnowDog1974 is offline Find More Posts by SnowDog1974
Old Jul 20, 2012, 02:45 PM
vhuang168 is offline
Find More Posts by vhuang168
United States, CA, Sunnyvale
Joined Mar 2011
Running a 4315/714kv on 4s. No nose weights and battery is still about 1/2" - 1" away from firewall. I put 2 4s2200mah in parallel.
Vincent
vhuang168 is offline Find More Posts by vhuang168
Old Jul 20, 2012, 02:52 PM
Joined Jan 2009
Vincent
cool...that's good to know.
Old Jul 20, 2012, 03:05 PM
eschult is offline
FLYINGJUNKY
eschult's Avatar
Joined Mar 2008
The 4315-480
Old Jul 20, 2012, 04:07 PM
eschult is offline
FLYINGJUNKY
eschult's Avatar
Joined Mar 2008
Also wondering if I need the spacers for this set up.
Old Jul 20, 2012, 04:50 PM
jimmy34256 is online now
Find More Posts by jimmy34256
Destructive Tester
jimmy34256's Avatar
Tampa, FL
Joined Apr 2008
Yup. You can get 1/2" nylon at Lowes
jimmy34256 is online now Find More Posts by jimmy34256
Old Jul 20, 2012, 04:57 PM
Destructive Tester
jimmy34256's Avatar
Tampa, FL
Joined Apr 2008
Have the 4315-500 and a 6s 3300 pack about 1.5in from the firewall
Old Jul 20, 2012, 07:34 PM
eschult is offline
FLYINGJUNKY
eschult's Avatar
Joined Mar 2008
Thanks for the info.
Got the plane a few minutes ago, NICE!!!!! What manual should i use and I see some are using a bec. I was going to use my quantum pro 70amp. and use 2s 2200 in series. Will not be going over 2800 mah in series. Should i also get a bec. Sending back the hacker Monday unless someone needs one for the 90.00 that i paid (save a few bucks) . This plane is going to be nice when I get it built.
Thanks again, Eric
Old Jul 20, 2012, 08:02 PM
Joined Jan 2009
Thanks again, Eric
If your ESC provides an acceptable voltage to the servos and receivers you can use it. Many people (including me) use a BEC simply to get better (higher) voltage to the servos. Also the safety of knowing you still get power to the rx and servos if your ESC dies.
You should be able to use the older 55" Edge build manual. If you would like, I can email you a version of that manual which I updated for this airframe. I am planning on sending it to 3DHS for their review (since they haven't done one that I'm aware of), but I just haven't had time. PM me your email address if you'd like to review my updated version.
Old Jul 20, 2012, 09:19 PM
eschult is offline
FLYINGJUNKY
eschult's Avatar
Joined Mar 2008
That would be great!!!!! I just finished a slick 51 and its looks to be similar. pm sent
Old Jul 21, 2012, 12:18 PM
eschult is offline
FLYINGJUNKY
eschult's Avatar
Joined Mar 2008
Just hit a roadblock. I was planning on using my hitec 5085. These servo trays are pretty big. I can mod the trays ro fit. Whats your opinion,mod the tray or go with different servos.
Old Jul 21, 2012, 12:25 PM
lammbn is online now
Find More Posts by lammbn
Hooked on 3DHS
lammbn's Avatar
United States, ID, Boise
Joined Nov 2009
different servos. those will die quickly and you will lose the plane. go with hs-225 for low end servos. savox 1250mg for high end digitals.
lammbn is online now Find More Posts by lammbn
Discussion 60 inch edge 540 vs 48 inch extreme flight extra 300 & edge 540 vs 3dhs slick 51 & 59 CRFan1 3D Flying 40 Mar 04, 2012 03:45 PM
Sold 3DHS Omega 130g NIB 58.00 Shipped boatdoc Aircraft - Electric - Power Systems (FS/W) 9 Aug 28, 2011 10:16 AM
Discussion 3dhs edge 41" edge as second ish) plane? Mr Bloppy 3D Flying 19 Aug 25, 2010 10:43 AM
Wanted Wanted - 47" - 58" 3DHS, EF or Sebart plane paintball_kidz Aircraft - Electric - Airplanes (FS/W) 0 Jan 03, 2010 12:12 AM
Wanted 47"-58" size 3DHS, Sebart or Extreme Flight paintball_kidz Aircraft - Electric - Airplanes (FS/W) 13 Jan 02, 2010 01:52 AM
