Old Mar 04, 2012, 05:24 PM
CooHead is offline
Find More Posts by CooHead
Don't watch this...
CooHead's Avatar
Northern IL
Joined Oct 2003
I have used the foam puck battery stay system for years.
Works faster and better than the defacto velcro straps.
I have a strip of velocro on the pack and on the battery tray like always.
insert the battery all the way to the firewall and then compress and jamb the foam puck in there ontop of it. Holds, with pressure, the battery to the tray velcro. Has never moved a mm.
Some airplanes you need to put a "ceiling" on the motor box to hold against. Most have an "X" member up there already.
I can swap batteries in my Edge with gloves on. Wish all my planes could use this system. But many of my planes the battey is somewhere in the middle of the tray like it's suppossed to be. And then and there the strap system worsk fine (kind of hard to do with gloves on tho).
But if a plane needs packs against the firewall....this is the best system around.
Coo
CooHead is offline Find More Posts by CooHead
Old Mar 04, 2012, 07:30 PM
E-reevo is offline
Find More Posts by E-reevo
E-reevo's Avatar
Joined Aug 2010
Originally Posted by UDO999 View Post
Yeah, I put a piece of plywood on the fire wall that holds it down up front. I'm going to make some long aluminum thumbscrews to hold the back down.
Can you go into a little more detail on how you hold the front of the tray down or maybe even a picture?
E-reevo is offline Find More Posts by E-reevo
Old Mar 04, 2012, 07:50 PM
UDO999 is offline
Find More Posts by UDO999
UDO999's Avatar
United States, MN, Cottage Grove
Joined Jul 2010
Firewall
I just epoxied a piece of ply to the firewall that is 3/32" off the floor of the battery tray (thickness of the ply tray). You could always slot the firewall and make a "tounge" on the ply tray itself to lock it in. I tried to attach an image but got an error.
UDO999 is offline Find More Posts by UDO999
Old Mar 06, 2012, 03:19 PM
E-reevo is offline
E-reevo's Avatar
Joined Aug 2010
Ok thanks.
Old Mar 06, 2012, 05:11 PM
zmonster97 is offline
Find More Posts by zmonster97
Team Aztech Aeromodels!
zmonster97's Avatar
United States, PA, Allentown
Joined May 2011
Does it matter which way the output gear on the rudder servo faces?
zmonster97 is offline Find More Posts by zmonster97
Old Mar 06, 2012, 05:29 PM
Eagle34 is offline
Find More Posts by Eagle34
TEAM HILLBILLY
Eagle34's Avatar
Pass Christian, MS
Joined Jan 2010
I wouldn't think so but IPS Motors says gear to the rear.
Eagle34 is offline Find More Posts by Eagle34
Old Mar 06, 2012, 05:34 PM
SnowDog1974 is offline
Find More Posts by SnowDog1974
SnowDog1974's Avatar
United States, IL, Crystal Lake
Joined Jan 2009
The 3DHS Build Manuals for the 51" Slick and the 57" Extra say the same thing...gears to the rear.
SnowDog1974 is offline Find More Posts by SnowDog1974
Old Mar 06, 2012, 05:46 PM
zmonster97's Avatar
Joined May 2011
Ok. That's what I thought. And the ailerons and elevator have the gear to the front, right?
Old Mar 06, 2012, 05:56 PM
Joined Jan 2009
You can use the 57" Extra build manual to build the 58" Edge.
Ailerons and Elevator -- gear to the front is correct.
Old Mar 06, 2012, 05:59 PM
zmonster97's Avatar
Joined May 2011
Ok thanks. I didn't know if that manual applied to the edge.
Old Mar 06, 2012, 06:07 PM
Joined Jan 2009
well enough to answer the general questions that you are asking...
Old Mar 07, 2012, 08:38 PM
Joined Jan 2009
I had a chance to test the power system tonight! The Motrofly 4315-480 shows 1221 watts and 55amps with a 15x8 APC-E prop and 2x3s2800 30C value hobby batteries fully charged. I really had to hold this thing down to test...can't wait to have some decent weather for a maiden. Still need to fine tune the control surfaces and add dual rates, etc.
Old Mar 07, 2012, 08:50 PM
ronbo111 is offline
Find More Posts by ronbo111
lazy 3D specialist
ronbo111's Avatar
United States, OH, Canal Winchester
Joined May 2007
yep my test with Torque 4016/500, 1257 watts with 15x8 apc 2x3s 2650 30c ,about the same
ronbo111 is offline Find More Posts by ronbo111
Old Mar 07, 2012, 08:52 PM
Mr Big Head is offline
Find More Posts by Mr Big Head
Mr Big Head's Avatar
United States, CA, Redding
Joined Feb 2011
When you say gear to the rear do you mean that the servo arm should be towards the nose of the plane?
Mr Big Head is offline Find More Posts by Mr Big Head
Old Mar 07, 2012, 08:56 PM
Joined Feb 2011
OK I just brought up the 57 build manual and gear to the rear seems to mean servo arm towards the rear. It must make zero difference as the 59 build videos say exactly the opposite!
Discussion 60 inch edge 540 vs 48 inch extreme flight extra 300 & edge 540 vs 3dhs slick 51 & 59 CRFan1 3D Flying 40 Mar 04, 2012 02:45 PM
Sold 3DHS Omega 130g NIB 58.00 Shipped boatdoc Aircraft - Electric - Power Systems (FS/W) 9 Aug 28, 2011 09:16 AM
Discussion 3dhs edge 41" edge as second ish) plane? Mr Bloppy 3D Flying 19 Aug 25, 2010 09:43 AM
Wanted Wanted - 47" - 58" 3DHS, EF or Sebart plane paintball_kidz Aircraft - Electric - Airplanes (FS/W) 0 Jan 02, 2010 11:12 PM
Wanted 47"-58" size 3DHS, Sebart or Extreme Flight paintball_kidz Aircraft - Electric - Airplanes (FS/W) 13 Jan 02, 2010 12:52 AM
