Old Mar 02, 2012, 07:33 PM
6L6Amp is offline
Find More Posts by 6L6Amp
6L6Amp's Avatar
Northern Indiana
Joined Jan 2009
Originally Posted by zmonster97 View Post
Because snowdog said he still needed nose weight with his. And I will be using 2x3s 2200mah batteries so they are pretty light.
Gotcha. Since both motors make the same amount of power, I'd get the lightened one and add nose weight if needed. My thinking is that you may want to put the motor in a different airframe some day and the extra weight may be unnecessary.
6L6Amp is offline Find More Posts by 6L6Amp
Old Mar 02, 2012, 07:35 PM
zmonster97 is offline
Find More Posts by zmonster97
Team Aztech Aeromodels!
zmonster97's Avatar
United States, PA, Allentown
Joined May 2011
Yeah, that makes sense. Now I don't know what I should do.
zmonster97 is offline Find More Posts by zmonster97
Old Mar 02, 2012, 07:43 PM
6L6Amp is offline
6L6Amp's Avatar
Northern Indiana
Joined Jan 2009
Just get the lightened one and be done with it. You can make it work, no problem. It's capable of making way more power than the 58" needs, so no worries there either.
Old Mar 02, 2012, 07:47 PM
zmonster97's Avatar
Joined May 2011
What weights would you use with that? I've never had to add weight. Do you use ones with a sticky back? Could someone provide a link? Thanks.
Old Mar 02, 2012, 07:51 PM
SnowDog1974 is offline
Find More Posts by SnowDog1974
SnowDog1974's Avatar
United States, IL, Crystal Lake
Joined Jan 2009
http://www3.towerhobbies.com/cgi-bin...&I=LXK204&P=ML
6L6Amp has a good point - if you get the lightened motor, you have more flexibility down the road.
Adding weight is no big deal, especially since this motor does have more than enough power...but you have smaller (therefore lighter) batteries, so you may have to add a bit more nose weight, or get heavier batteries.
SnowDog1974 is offline Find More Posts by SnowDog1974
Old Mar 02, 2012, 08:17 PM
zmonster97's Avatar
Joined May 2011
Thanks. I'll probably get the lightened motor mount. For the weights, would i put them at the front of the motor box?
Old Mar 02, 2012, 08:21 PM
Joined Jan 2009
yes; I'm going to the workshop now to do that very thing; I'll take some pics.
As far forward as possible, so you only have to add a small amount.
Old Mar 02, 2012, 08:22 PM
zmonster97's Avatar
Joined May 2011
K, thanks.
Old Mar 03, 2012, 10:56 AM
UDO999 is offline
Find More Posts by UDO999
UDO999's Avatar
United States, MN, Cottage Grove
Joined Jul 2010
Battery tray
I had some free time last night and played around with making a removable battery tray. I'm new to this stuff so please tell me what you think, good or bad. I don't have a scale to weigh it, but it is pretty light. Do you guys think this would add too much weight?
UDO999 is offline Find More Posts by UDO999
Old Mar 03, 2012, 12:32 PM
diggity2424 is offline
Find More Posts by diggity2424
Wingman II
diggity2424's Avatar
United States, KY, Louisville
Joined Sep 2011
Not bad!! Looks like you have to screw the battery tray in every time or no?
diggity2424 is offline Find More Posts by diggity2424
Old Mar 03, 2012, 12:40 PM
UDO999 is offline
UDO999's Avatar
Joined Jul 2010
Yeah, I put a piece of plywood on the fire wall that holds it down up front. I'm going to make some long aluminum thumbscrews to hold the back down.
Old Mar 03, 2012, 01:04 PM
SteveT. is offline
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Good job... That is "SOP" (standard operating procedure) for many planes. The Great Planes "Revolver" has a similar design from the factory...
SteveT
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Mar 03, 2012, 02:14 PM
UDO999 is offline
UDO999's Avatar
Joined Jul 2010
SteveT
Yeah, I got the idea from an 89" Slick that had one.
Old Mar 03, 2012, 06:07 PM
zmonster97's Avatar
Joined May 2011
What size wires should I be using on this with 6s? Will 14 gauge work?
Old Mar 03, 2012, 06:17 PM
keithy4129 is offline
Find More Posts by keithy4129
United States, NJ, Clayton
Joined Aug 2010
alright guys, here are some numbers, gens ace 6s 2500 25c batteries, motrolfly 4315 500kv, 15x7 prop, hacker x-70 esc 1495 watts (fully charged and on the ground) at around 64-65amps, do you think this will be enough power? also whats the recommended CG? thanks!
keithy4129 is offline Find More Posts by keithy4129
Discussion 60 inch edge 540 vs 48 inch extreme flight extra 300 & edge 540 vs 3dhs slick 51 & 59 CRFan1 3D Flying 40 Mar 04, 2012 02:45 PM
Sold 3DHS Omega 130g NIB 58.00 Shipped boatdoc Aircraft - Electric - Power Systems (FS/W) 9 Aug 28, 2011 09:16 AM
Discussion 3dhs edge 41" edge as second ish) plane? Mr Bloppy 3D Flying 19 Aug 25, 2010 09:43 AM
Wanted Wanted - 47" - 58" 3DHS, EF or Sebart plane paintball_kidz Aircraft - Electric - Airplanes (FS/W) 0 Jan 02, 2010 11:12 PM
Wanted 47"-58" size 3DHS, Sebart or Extreme Flight paintball_kidz Aircraft - Electric - Airplanes (FS/W) 13 Jan 02, 2010 12:52 AM
