Old Mar 01, 2012, 09:30 AM
SnowDog1974 is offline
Find More Posts by SnowDog1974
SnowDog1974's Avatar
United States, IL, Crystal Lake
Joined Jan 2009
Originally Posted by SteveTtoooo View Post
When I mounted my Motrofly motor with the fiber mount, I ended up using a "rat-tail" file to file the holes to a little bit of and angle so the the bolts went in at and angle then straightened out once they were in. And, I had to put all four in at a time instead of one at a time....
SteveT
I was able to get mine mounted last night without having to use a rat tail file, but I did have to install them all four at once. I was able to place the motor as far forward as possible and still have about 1/4" overlap on the cowl...not sure I could get it any farther forward. My spacers ended up being 1/2" in length. Just need to do the wings (servos and connectors) and then I should be able to check the CG. Was hoping to be done with this thing aready, but I've only been able to get an hour here and there to work on it.
SnowDog1974 is offline Find More Posts by SnowDog1974
Old Mar 01, 2012, 12:09 PM
heritageflyer is offline
Find More Posts by heritageflyer
Time to Fly AJ's Best!
heritageflyer's Avatar
Hills of Eastern Ohio
Joined Nov 2008
Ok, now that a few of you have them flying, what's the popular choice Motrolfly motor model that is working on this plane, Balancing easily and producing 1200-1300 Watts?
heritageflyer is offline Find More Posts by heritageflyer
Old Mar 01, 2012, 12:42 PM
Joined Jan 2009
I'll let you know this weekend; I've got the 4315-480, almost ready to balance, just need to get the servos in the wings. Going with 2x3s2800 batteries...hoping I don't have to jam them all the way up to the firewall. Might try 2x3s3300's if I need more weight.
Old Mar 01, 2012, 02:11 PM
Joined Nov 2008
Since the recommended Hacker A40-10S V2 (if I remember right) weighs in at 210g/7.43oz (I think), was considering the Motrolfly 3620-750 @ 230g/8.1oz. (4S)
But I thought I read here packs having to be shoved up against the firewall and I don't want that.
So then was thinking 4315-714 @ 267g with Fiberglass X, coming out around 300g/10oz if I remember right from the Cart last night.
Just don't want to add 3oz over recommended motor weight to the airframe, especially sitting up front that far out.
Old Mar 01, 2012, 02:16 PM
Joined Jan 2009
Almost everyone who has built this plane (at least with the Motrofly 3620) has had to push their batteries all the way to the firewall to get it balanced at 3.75. I'm betting that the heavier motor will not be a problem and will in fact make it easier for me to balance. I'd rather add motor weight than lead to the nose. I want to be able to swap batteries without having to resort to wrist gymnastics and causing carpal tunnel. Bivens posted some pics showing a battery tray that he made that helped with swapping and securing batteries. I don't think the 3oz is going to cause problems.
Old Mar 01, 2012, 03:56 PM
Capt. Rex A Lott is offline
Find More Posts by Capt. Rex A Lott
United States, TX, Round Rock
Joined Mar 2011
I am running a Eflite Power 46 on 4S with a 15x8 prop.
I get around 1100 watts and it balances perfect.
As long as you are not wanting to go 6S it is a great setup.
Capt. Rex A Lott is offline Find More Posts by Capt. Rex A Lott
Old Mar 01, 2012, 04:30 PM
lammbn is offline
Find More Posts by lammbn
Hooked on 3DHS
lammbn's Avatar
United States, ID, Boise
Joined Nov 2009
+1! with my 3620 i have two ounces of lead in the nose of my plane and still have a little "wrist gymnastics" i have to do to change packs. i would much rather have motor weight. i'm kinda waiting to see how SnowDog's 4315 balances to decide if i want to sell the 3620 and upgrade. i already have more power than i need though and its already installed and ready to fly.... maybe not but who knows
lammbn is offline Find More Posts by lammbn
Old Mar 01, 2012, 08:39 PM
zmonster97 is offline
Find More Posts by zmonster97
Team Aztech Aeromodels!
zmonster97's Avatar
United States, PA, Allentown
Joined May 2011
What other servos are you guys using other than the hitecs? I don't really want to spend the money for them. So was wondering if there are any good, cheaper alternatives.
zmonster97 is offline Find More Posts by zmonster97
Old Mar 01, 2012, 08:42 PM
theKM is offline
Find More Posts by theKM
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
for this size plane, the Hitec's are about the cheapest way to go with a reliable servo...
theKM is offline Find More Posts by theKM
Latest blog entry: Updated Hatcam - Apr2016
Old Mar 01, 2012, 08:43 PM
zmonster97's Avatar
Joined May 2011
Yeah it seems like it. I was going to go with the spektrum a5040's but they're out of stock.
Are hyperion servos any good?
Old Mar 01, 2012, 09:36 PM
XXLBMXER is offline
Find More Posts by XXLBMXER
Team 3DHS
XXLBMXER's Avatar
Los Alamos CA .
Joined Jan 2009
Just got mine flying yesterday, put 10 packs through it and I really like this one. Here is what I put in mine and my batts are one inch back from the front of the motor box. Next time out I will pull them back a little more, maybe another 1/2'' or so then I will do some mixin.
Motrolfly 4315 700
Sky lipo 4s 4000
Extreme Flight 80 Amp ESC
APC 15x7
Futaba s9650 servos
XXLBMXER is offline Find More Posts by XXLBMXER
Old Mar 01, 2012, 11:48 PM
Bivens is offline
Find More Posts by Bivens
Team 3DHS / Team JR
Bivens's Avatar
United States, TN, Knoxville
Joined Apr 2010
225's in mine....and they're pretty cheap while still getting it done.....some will say they don't center as well as more expensive servos...but they're still the best bang for the buck...and I don't fly this plane straight anyway....
Bivens is offline Find More Posts by Bivens
Old Mar 01, 2012, 11:59 PM
lammbn is offline
Hooked on 3DHS
lammbn's Avatar
Joined Nov 2009
align DS510m's are the same size and would work great if you could pick up a few used from the heli guys. maybe check the classifieds over at helifreak. i have gotten some great deals on some DS610's for my 7X planes
Old Mar 02, 2012, 12:08 AM
Mr Big Head is online now
Find More Posts by Mr Big Head
Mr Big Head's Avatar
United States, CA, Redding
Joined Feb 2011
How many amps is that?
Mr Big Head is online now Find More Posts by Mr Big Head
Old Mar 02, 2012, 12:13 AM
Joined Mar 2011
Around 75.
This is way more than the 46 is rated for but it has never come down hot.
I would not have considered this setup except that every flyer at the field swore the Eflite could be run way over specs without issue.
Turns out they are right.
Discussion 60 inch edge 540 vs 48 inch extreme flight extra 300 & edge 540 vs 3dhs slick 51 & 59 CRFan1 3D Flying 40 Mar 04, 2012 02:45 PM
Sold 3DHS Omega 130g NIB 58.00 Shipped boatdoc Aircraft - Electric - Power Systems (FS/W) 9 Aug 28, 2011 09:16 AM
Discussion 3dhs edge 41" edge as second ish) plane? Mr Bloppy 3D Flying 19 Aug 25, 2010 09:43 AM
Wanted Wanted - 47" - 58" 3DHS, EF or Sebart plane paintball_kidz Aircraft - Electric - Airplanes (FS/W) 0 Jan 02, 2010 11:12 PM
Wanted 47"-58" size 3DHS, Sebart or Extreme Flight paintball_kidz Aircraft - Electric - Airplanes (FS/W) 13 Jan 02, 2010 12:52 AM
