Old Feb 26, 2012, 01:47 PM
SnowDog1974's Avatar
United States, IL, Crystal Lake
Joined Jan 2009
Originally Posted by zmonster97 View Post
Sorry for all the questions, but..
1. Will a 60a esc be enough for the 4315 on 6s?
2. Does the ZTW 6a external bec give you 6v? The 3a one does.
I went with the 85A ZTW just to be sure; I'm not sure the 60a will give you any headroom.
Yes, the ZTW 6a external BEC gives you 5, 5.5, or 6v.
http://www.quantumhobby.com/ZTW_6A_S.../ztwubec6a.htm
Now, back to the workshop! Got the motor mounted, and tail surfaces on; need to start working on the servos and then the cowl.
Have I mentioned before how much I like the way this plane is built?
SnowDog1974 is online now Find More Posts by SnowDog1974
Old Feb 26, 2012, 06:12 PM
Flyin' low
zmonster97's Avatar
United States, PA, Allentown
Joined May 2011
I might go with a 60a. The most amps this plane pulls is around 55a.
zmonster97 is online now Find More Posts by zmonster97
Old Feb 26, 2012, 06:14 PM
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Not much head room....will run warmer, and higher amperage ESCs give better power due to lower resistance (usually)...
SteveT
SteveT. is online now Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Feb 26, 2012, 06:22 PM
Flyin' low
zmonster97's Avatar
Joined May 2011
SteveT
Yeah, now that I think about it, I'll go higher. I was looking at the ZTW 70a esc paired with a ZTW 6a ubec.
Old Feb 26, 2012, 06:26 PM
Wingman II
diggity2424's Avatar
United States, KY, Louisville
Joined Sep 2011
I'm using a 80amp esc with 10amp bec. Comes down cool as the other side of the sheets.
diggity2424 is offline Find More Posts by diggity2424
Old Feb 26, 2012, 07:34 PM
Hooked on 3DHS
lammbn's Avatar
United States, ID, Boise
Joined Nov 2009
Im running an ice 75 with full heatsink on my 6s setup for plenty of headroom and programability. CC 10a bec for added overkill
lammbn is offline Find More Posts by lammbn
Old Feb 26, 2012, 07:52 PM
Flyin' low
zmonster97's Avatar
Joined May 2011
Will this esc be enough?
http://www.hobby-lobby.com/erc_65a_b...35809_prd1.htm
Also will the bec in that esc be enough on 6s?
Old Feb 26, 2012, 08:21 PM
Hooked on 3DHS
lammbn's Avatar
Joined Nov 2009
the "specs" say its enough. but at $50 i would ask if you trust $500 in plane and other equipment to it? Your next cheapest option that i would suggest is something proven like a hobby wing or ZTW. with those still i would suggest an external bec. a good used Ice 75 can be picked up one the classifieds here for $65-75 shipped and i would trust the internal bec for this plane. just my opinion.
Old Feb 26, 2012, 08:25 PM
Flyin' low
zmonster97's Avatar
Joined May 2011
I've read some good reviews on it. I don't know what I'll get. I'm still looking around.
Old Feb 26, 2012, 08:44 PM
Hooked on 3DHS
lammbn's Avatar
Joined Nov 2009
I dont mean to be a downer but i learned the hard way that everybody was right. Get the good stuff to begin with and save yourself the heartache. $20 now could save you hours of problems and hundreds in crashes.
Old Feb 26, 2012, 11:48 PM
E-reevo's Avatar
Joined Aug 2010
I have a APC 15x6 on it now because that was all that I had but do you think it is worth me ordering a Xoar 15x7 with a Hacker A40 10s?
E-reevo is offline Find More Posts by E-reevo
Old Feb 26, 2012, 11:49 PM
E-reevo's Avatar
Joined Aug 2010
SFG bolts.....
But to answer your question, nylon screws I believe..
SteveT
Are they the bolts that just look like small wing bolts?
Thanks.
Old Feb 27, 2012, 01:06 AM
Hooked on 3DHS
lammbn's Avatar
Joined Nov 2009
Thanks.
there should be four small 3mm white nylon screws with a round head. if you have a 7x plane they will look just like the ones that are included for the optional canopy securing mounts.
Old Feb 27, 2012, 07:22 AM
Joined Jan 2009
Thanks.
yes - small, round head nylon "thumb screw" wing bolts...they are packaged with the other aileron equipment in the same bag...two aileron control horns, control rods, ball link rods, etc. Each bag has the equipment for a single component, which I appreciate.
Old Feb 27, 2012, 07:19 PM
E-reevo's Avatar
Joined Aug 2010
I found 3 out of the 4 bolts but I will just take one of the canopy bolts from my 72" Extra. Also you said the SFG bolts for 7X planes are different so what do those look like?
Discussion 60 inch edge 540 vs 48 inch extreme flight extra 300 & edge 540 vs 3dhs slick 51 & 59 CRFan1 3D Flying 40 Mar 04, 2012 02:45 PM
Sold 3DHS Omega 130g NIB 58.00 Shipped boatdoc Aircraft - Electric - Power Systems (FS/W) 9 Aug 28, 2011 09:16 AM
Discussion 3dhs edge 41" edge as second ish) plane? Mr Bloppy 3D Flying 19 Aug 25, 2010 09:43 AM
Wanted Wanted - 47" - 58" 3DHS, EF or Sebart plane paintball_kidz Aircraft - Electric - Airplanes (FS/W) 0 Jan 02, 2010 11:12 PM
Wanted 47"-58" size 3DHS, Sebart or Extreme Flight paintball_kidz Aircraft - Electric - Airplanes (FS/W) 13 Jan 02, 2010 12:52 AM
