Old Feb 25, 2012, 05:03 PM
zmonster97 is offline
Find More Posts by zmonster97
Team Aztech Aeromodels!
zmonster97's Avatar
United States, PA, Allentown
Joined May 2011
Also, there are washers that are in the landing gear bag. What are those used for?
zmonster97 is offline Find More Posts by zmonster97
Old Feb 25, 2012, 05:08 PM
SteveT. is offline
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Probably to be installed on the screws that hold the gear on....
SteveT
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Feb 25, 2012, 05:16 PM
zmonster97's Avatar
Joined May 2011
SteveT
Ok. Thats what I thought.
Old Feb 25, 2012, 06:28 PM
E-reevo is offline
Find More Posts by E-reevo
E-reevo's Avatar
Joined Aug 2010
What do the SFG bolts look like?
Thanks.
E-reevo is offline Find More Posts by E-reevo
Old Feb 25, 2012, 06:46 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
SFG bolts.....
But to answer your question, nylon screws I believe..
SteveT
Old Feb 25, 2012, 07:09 PM
zmonster97's Avatar
Joined May 2011
Two more questions,
1. 3DHS was selling props for $3 at the show today, so I was looking for a xoar 15x8 or 15x7 for this plane, but all I could find was a 15x6. So being that they were only $3, I bought it. How do you think it will work with a motrolfly 4315-480?
2. For the motrolfly 4315, what mount should I go with again? I'm not sure. The fiberglass lightweight mount or the regular mount?
Old Feb 25, 2012, 07:25 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
Two more questions,
Not enough prop...and fiberglass mount...
SteveT
Old Feb 25, 2012, 07:28 PM
zmonster97's Avatar
Joined May 2011
SteveT
So should I be going with a 15x8 or 15x7?
Old Feb 25, 2012, 07:31 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
Yes.....
I don't have that motor, but I would say start with the 15X8 and check the motor temp. If too warm, drop down to the 15X7...
SteveT
Old Feb 25, 2012, 07:33 PM
zmonster97's Avatar
Joined May 2011
Yes.....
SteveT
Gotcha. So the fiberglass x mount wont be too light? I might just wait until people balance this plane with the 4315 and 2200mah batteries to see what to buy.
Old Feb 25, 2012, 07:34 PM
Irg is online now
Irg
Find More Posts by Irg
Irg
ol' yellow eyes is back
Irg's Avatar
United States, NY, Alfred
Joined Apr 2009
yeah, steve, no offense but don't you think you should let someone with the plane and the motor comment? especially after all the discussion about adding weight to the nose? just sayin'!
Irg is online now Find More Posts by Irg
Old Feb 25, 2012, 07:38 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
Actually you are correct, I forgot about the balance issues with this plane...so...OK...aluminum mount then...
And no offense taken...when I'm wrong, I'll admit it (and I was)....was just trying to help..
SteveT
Old Feb 25, 2012, 09:27 PM
SnowDog1974 is offline
Find More Posts by SnowDog1974
SnowDog1974's Avatar
United States, IL, Crystal Lake
Joined Jan 2009
SteveT
The thing is...(and I have one of these planes)...the nose weight issue was based on the smaller 3620 motor, not the 4315. I bought the 4315-480 with the fiberglass mount which I felt was a good compromise between more weight in the motor but not too much weight. I'm also going to mount the motor as far forward as possible, leaving just enough room for overlap on the cowl. I was supposed to have this all done by now, but a last minute business trip out of town and two dishwasher installations (actually, an installation, a de-installation, and a new installation; and now, the new dishwasher is leaking - but not from the water inlet) have hacked away at my workshop time. So anyway, I'm going to log off this forum and get down to the workshop and do some building so I can answer that question directly. I think the 4315 with the fiberglass mount is going to be a good setup; I'll let you know asap. I'm also using 2x3s2800's for batteries.
SnowDog1974 is offline Find More Posts by SnowDog1974
Old Feb 25, 2012, 09:33 PM
Joined Jan 2009
Duplicate post
Old Feb 26, 2012, 07:08 AM
zmonster97's Avatar
Joined May 2011
Sorry for all the questions, but..
1. Will a 60a esc be enough for the 4315 on 6s?
2. Does the ZTW 6a external bec give you 6v? The 3a one does.
Discussion 60 inch edge 540 vs 48 inch extreme flight extra 300 & edge 540 vs 3dhs slick 51 & 59 CRFan1 3D Flying 40 Mar 04, 2012 02:45 PM
Sold 3DHS Omega 130g NIB 58.00 Shipped boatdoc Aircraft - Electric - Power Systems (FS/W) 9 Aug 28, 2011 09:16 AM
Discussion 3dhs edge 41" edge as second ish) plane? Mr Bloppy 3D Flying 19 Aug 25, 2010 09:43 AM
Wanted Wanted - 47" - 58" 3DHS, EF or Sebart plane paintball_kidz Aircraft - Electric - Airplanes (FS/W) 0 Jan 02, 2010 11:12 PM
Wanted 47"-58" size 3DHS, Sebart or Extreme Flight paintball_kidz Aircraft - Electric - Airplanes (FS/W) 13 Jan 02, 2010 12:52 AM
