Old Feb 14, 2012, 01:52 AM
SteveT. is offline
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Originally Posted by lammbn View Post
My both of my 3620-480 motors run 15x8 props. Come down cold, not even warm at all, every time. Even on a 6 min flight of nothing but high throttle KE passes. Do check your own wattage though. There is a possibility of the kv not being exactly 480.
Now we have a little more info...which is always good to know.....(knowledge is good)...
SteveT
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Feb 14, 2012, 06:05 AM
diggity2424 is offline
Find More Posts by diggity2424
Wingman II
diggity2424's Avatar
United States, KY, Louisville
Joined Sep 2011
Yes it is. Thanks for the reassurance guys!
diggity2424 is offline Find More Posts by diggity2424
Old Feb 14, 2012, 07:59 AM
Maxster is offline
Find More Posts by Maxster
Joined Oct 2006
are the HS5245 worth the extra expense over the HS225?
Maxster is offline Find More Posts by Maxster
Old Feb 14, 2012, 03:04 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
Digital servos usually hold better, and center better, at the cost of needing a better BEC to supply them. Most people using digital servos use an external BEC, which is a bit more weight, but not much.
SteveT
Old Feb 14, 2012, 05:34 PM
Joe_Wildcat is offline
Find More Posts by Joe_Wildcat
Joe_Wildcat's Avatar
United States, FL, Cocoa Beach
Joined Mar 2011
Anyone have shipping box dimensions on this bad boy?? Strange question i know but i am coming back to the states and want to pick one up and will have to bring it back on the plane, as checked baggage off course.
Joe_Wildcat is offline Find More Posts by Joe_Wildcat
Old Feb 14, 2012, 05:51 PM
ATCH is offline
Find More Posts by ATCH
AMA 1034020
ATCH's Avatar
United States, AL, Alexander City
Joined Jul 2011
46 inches Long
18 inches Wide
9 inches Tall
ATCH is offline Find More Posts by ATCH
Old Feb 14, 2012, 10:09 PM
Wingman II
Joined Sep 2011
What's a good CG to maiden this bad boy?? She's ready to rock!
Old Feb 14, 2012, 10:33 PM
mdv is offline
mdv
Find More Posts by mdv
mdv
United States, CA, San Diego
Joined Jun 2009
It would be a good idea to decided whether it's a he or a she. Otherwise, it'll get a complex or something.
mdv is offline Find More Posts by mdv
Old Feb 14, 2012, 10:39 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
Good aircraft are "things of beauty", therefore they are always a "She".....
SteveT
Old Feb 14, 2012, 10:50 PM
Wingman II
Joined Sep 2011
hahaha! She is a beaut...
Old Feb 15, 2012, 08:53 AM
SnowDog1974 is offline
Find More Posts by SnowDog1974
SnowDog1974's Avatar
United States, IL, Crystal Lake
Joined Jan 2009
Per Bivens:
I added 1.5 oz to the firewall and a castle BEC pro on the "Shelf" I built over my batts....a pair of 3s-2600s pushed to the firewall. I really like this CG now....a little noseheavy on the inverted test....just a tiny pitch couple on KE.....I checked my CG on the fingertips.....3.75 inches....same as fliprob.
SnowDog1974 is offline Find More Posts by SnowDog1974
Old Feb 15, 2012, 09:12 AM
Wingman II
Joined Sep 2011
Originally Posted by SnowDog1974 View Post
Per Bivens:
Thanks, I was figuring on adding 1 oz to the nose because I have a ton of 3s 2200s that I was going to run in series. Might have to do more. I will work with 3.75inches. thanks, again.
Old Feb 15, 2012, 09:15 AM
Joined Jan 2009
Sure, no problem....I decided to add an ounce or two of weight to the nose by putting in a 4315-480...but I have not mounted it yet or done any CG checking. I am planning on using 3s 2500's in series.
Old Feb 15, 2012, 10:25 AM
keithy4129 is offline
Find More Posts by keithy4129
United States, NJ, Clayton
Joined Aug 2010
congrats! I took off of work friday to start my build! can't wait!
keithy4129 is offline Find More Posts by keithy4129
Old Feb 15, 2012, 01:11 PM
lammbn is offline
Find More Posts by lammbn
Hooked on 3DHS
lammbn's Avatar
United States, ID, Boise
Joined Nov 2009
with the 3620 mounted as far out as the cowl will allow my plane balanced perfectly with two 3s 2200's against the firewall. but i could not come up with a good way to secure them so i added two ounces to the firewall and moved my batts back a couple inches. i would really like to see some pics of the "shelf" that some of you built to hold your batteries up front. there doesn't look like much to secure it too at the front of the motorbox. has anybody else noticed how open the front of the motor box looks on this plane vs other 3dhs planes?
lammbn is offline Find More Posts by lammbn
Discussion 60 inch edge 540 vs 48 inch extreme flight extra 300 & edge 540 vs 3dhs slick 51 & 59 CRFan1 3D Flying 40 Mar 04, 2012 03:45 PM
Sold 3DHS Omega 130g NIB 58.00 Shipped boatdoc Aircraft - Electric - Power Systems (FS/W) 9 Aug 28, 2011 10:16 AM
Discussion 3dhs edge 41" edge as second ish) plane? Mr Bloppy 3D Flying 19 Aug 25, 2010 10:43 AM
Wanted Wanted - 47" - 58" 3DHS, EF or Sebart plane paintball_kidz Aircraft - Electric - Airplanes (FS/W) 0 Jan 03, 2010 12:12 AM
Wanted 47"-58" size 3DHS, Sebart or Extreme Flight paintball_kidz Aircraft - Electric - Airplanes (FS/W) 13 Jan 02, 2010 01:52 AM
