I didn't, but with the way this plane snaps and tumbles, I have no doubt it will do them very well. The weather is supposed to change for the worse here in a few days, and I think a lot of guys came out to get some flights in while the weather was nice....And....we had four guys with over powered 1/4 scale Cubs playing "follow the leader", and were basically in the way as the were doing lots of side slips, low medium speed passes down the run way, and other various things spaced out to where you couldn't really fly between them...and of course the had 2 gallon gas tanks in them....And of course as we have six flight stations, when you have three or four guys doing that....there isn't a lot of time to fly....
SteveT. |
Latest blog entry: My hangar...
If using hitec servos....the stock plastic hitec's that come with their 7955 and other giant scale servos work very well....probably near 1" or so with holes down through 5/8" on a fairly tight spacing......
Sorry I have no better answer here....but typically I have LOTS of these arms just laying around from giant scale where we don't use em....and they work so well on this size of plane. When using Futaba servos, you would need something about as long as the "large-circular" plate with no holes.....probably 7/8" or so of length should get you close... If neither of those answers work out for you....Dubro has some "heavy-duty" aftermarket servo arms in two lengths.....the longer set is perfect. I'd measure mine...but it's out in the trailer on the top shelf. Anybody else got a good answer here? |
Large Dubro for me....but then I don't think I actually used the outermost hole, so maybe the smaller ones will work.
SteveT. |
http://www3.towerhobbies.com/cgi-bin...&I=LXD669&P=ML |
Latest blog entry: Zach & Dan 3DHS 71" Slicks Duo...
could you explain plz?
Im trying to use the power setup from this plane http://www.horizonhobby.com/products...arf-EFL4125#t2 |
I think you'll also have a little trouble getting the plane to balance - you'd certainly have to do a push/pull rudder instead of pull/pull which wouldn't be a big deal. |
United Kingdom, London
Joined Jul 2011
| Thread Tools | |
| Discussion 60 inch edge 540 vs 48 inch extreme flight extra 300 & edge 540 vs 3dhs slick 51 & 59 | CRFan1 | 3D Flying | 40 | Mar 04, 2012 02:45 PM |
| Sold 3DHS Omega 130g NIB 58.00 Shipped | boatdoc | Aircraft - Electric - Power Systems (FS/W) | 9 | Aug 28, 2011 09:16 AM |
| Discussion 3dhs edge 41" edge as second ish) plane? | Mr Bloppy | 3D Flying | 19 | Aug 25, 2010 09:43 AM |
| Wanted Wanted - 47" - 58" 3DHS, EF or Sebart plane | paintball_kidz | Aircraft - Electric - Airplanes (FS/W) | 0 | Jan 02, 2010 11:12 PM |
| Wanted 47"-58" size 3DHS, Sebart or Extreme Flight | paintball_kidz | Aircraft - Electric - Airplanes (FS/W) | 13 | Jan 02, 2010 12:52 AM |
