Old Jan 09, 2012, 05:37 PM
timnilson is offline
Find More Posts by timnilson
timnilson's Avatar
United States, FL, Sarasota
Joined Nov 2010
Originally Posted by leadfeather View Post
Prizes!! Yeahhh!
At this point, one copter could be in first place for every category for 2012
That's right! All we need are submissions!! Come claim your spot. It's probably best to be specific though about which category you are entering -- almost each category requires a purpose built craft, I think. I am personally planning to better my 2011 'duration' record of 28:30. Just don't know yet how I am going to do that
timnilson is offline Find More Posts by timnilson
Site Sponsor
Old Jan 09, 2012, 05:44 PM
saabguyspg is offline
Find More Posts by saabguyspg
saabguyspg's Avatar
Calgary Canada
Joined Jun 2006
tim that flight time is super awesome and confirms my thoughts that the less arms you have the more efficient the setup....
I have a very big client meeting tomorrow so I can't risk any machines right now but after tomorrow I hope to do some long range fpv stuff.... "long range" however I am not sure how I could ever compete with your 28 min tricopter!!!! you could go for a long distance!
Steve
saabguyspg is offline Find More Posts by saabguyspg
Old Jan 09, 2012, 09:01 PM
timnilson's Avatar
Joined Nov 2010
Steve
Thanks! The best part of my 28:30 set-up is that it still has plenty of lift/thrust. I could theoretically fly out for 13 minutes or so and then turn around to come back. You could cover a good distance in 13 minutes. I am guessing around 5km going about 25km/hour. Have to find a way to try this.
Site Sponsor
Old Jan 09, 2012, 09:29 PM
Bmr4life is offline
Find More Posts by Bmr4life
30 RC's and counting
Bmr4life's Avatar
United States, GA, Tucker
Joined Mar 2005
Tim man, you're going to have to really bring it. I'm sure you saw the 51 minute video that was posted today.
Bmr4life is offline Find More Posts by Bmr4life
Old Jan 09, 2012, 10:24 PM
saabguyspg's Avatar
Calgary Canada
Joined Jun 2006
^^^ whaaaaaaaaaaaat?
link please
Old Jan 09, 2012, 10:35 PM
Bmr4life is offline
Bmr4life's Avatar
Joined Mar 2005
link please
http://www.rcgroups.com/forums/showthread.php?t=1570880
Going to be hard to beat. Only weighs 1520g with 3s8000mah lipo. Handmade carbon fiber props, 4 in 1 esc, etc.
Old Jan 10, 2012, 12:00 AM
timnilson's Avatar
Joined Nov 2010
No, had not seen it before you mentioned it. That is truly amazing. Tony uses amazing high end components. I put him in first place in the all out time duration category. That will be very hard to beat.
Site Sponsor
Old Jan 10, 2012, 12:12 AM
timnilson's Avatar
Joined Nov 2010
I did some math and i could use the same 3s set up: 4 2200 mah 3s lipos in parallel for a total of 8800 mah. That would be about 800g in lipo weight for a total auw of around 1600g for my tri. Total thrust with my HK-4008 motors on 3s and 10x4.7 props would be about 2100g. So I should get airborne, but it would be close. The question is if 3 motors running at 3/4 throttle would consume more or less energy than 4 motors running at 1/2 throttle.
Site Sponsor
Old Jan 13, 2012, 02:27 AM
paulthepilot_5 is offline
Find More Posts by paulthepilot_5
Brisbane, Australia
Quick question, Is the Mr. Lifter contest limited to electric power?
paulthepilot_5 is offline Find More Posts by paulthepilot_5
Old Jan 13, 2012, 06:21 AM
leadfeather is offline
Find More Posts by leadfeather
Winging it >
leadfeather's Avatar
Joined May 2006
That is an interesting question. With 4 motors there is the extra weight of the 4th motor/esc/arm. So is this extra weight offset by operating at a higher efficiency due to lower power per motor?
I think the best way to determine this is to get one of the motors on a test stand and measure power consumption vs thrust. With the power consumption measured for each operating point ( 3 vs 4 motor build required thrust) it should be easy to determine which is best.
leadfeather is offline Find More Posts by leadfeather
Old Jan 13, 2012, 07:22 AM
timnilson's Avatar
Joined Nov 2010
Good idea. I have never created such a power consumption curve. I have a watt meter, which I guess is what you'd use to generate a watt curve like that. What's a good way to measure thrust?
Site Sponsor
Old Jan 13, 2012, 07:23 AM
timnilson's Avatar
Joined Nov 2010
No, it's only limited to multi-rotors
Which category are you thinking about?
Site Sponsor
Old Jan 13, 2012, 07:32 AM
Winging it >
Joined May 2006
You can measure thrust directly with a scale. Also if you have a tachometer and can measure rpm you can look up thrust for a particular propeller.
Old Jan 13, 2012, 05:56 PM
timnilson's Avatar
Joined Nov 2010
Thank you -- I like your simple test stand!
Site Sponsor
Old Jan 14, 2012, 10:42 AM
Winging it >
Joined May 2006
The scale I use measures -ve weight too. Usually I just mount the prop to push down, but I added double sided tape between the scale and the stand and I can measure with the prop pulling up too.
Discussion Dreaming about Multi Rotor setup : Multi+GoPro+eagle tree everything? crashtested Aerial Photography 11 Apr 10, 2015 10:18 PM
Contest Mr. Lifter 2011; Walter Lafouine takes over heaviest lift!! . leadfeather Multirotor Talk 364 Sep 05, 2014 02:29 AM
Discussion Multi rotor contest game event in Taiwan samwei1950 Multirotor Talk 0 Oct 04, 2011 07:00 AM
Sold Multi Rotor Flight Controllers - FY90Q & Multi Wii Tahoe Ed Aircraft - Electric - Multirotor (FS/W) 3 Sep 28, 2011 05:29 PM
Suggestion Sticky thread in Multi-rotor-helis thread has nothing to do with multi-rotors timecop Site Suggestions / Complaints 2 Apr 03, 2011 08:56 AM
