Old Jan 03, 2012, 07:30 PM
AJWoods is online now
Find More Posts by AJWoods
Aircraft Designer Guy
AJWoods's Avatar
United States, CA, Santa Clara
Joined Jul 2005
The Xperiment, something different...
I got surprised by a day off yesterday, so I decided to try and draw up a new plane. Looking at the trends in newer F3p planes it seemed like there was a drive towards more fuse area over the CG, and in most cases semi or fully symmetric fuse profiles.
This is great as coupling is all but gone, and knife edge should behave more like wings level flight. But even if fuse area was increased to match wing area, because of the difference in aspect ratios, you'd still need to fly at a higher angle of attack in KE, compared to wings level. To get the plane to approach complete neutrality, the fuse starts to look like the wing.
So that's what I tried, a completely cruciform plane. And to get it to be able to land somewhat like a normal plane, I shifted the wing from 0/90 to 45/45, while leaving the tail group at 0/90. This keeps the rudder/elevator in normal plane axes, and gives a sort of conventional stance on the ground without the need for some sort of ridiculous gear. To make determining the orientation easier I painted the top and bottom to look like the top and bottom of a regular plane, and the sides to look like a conventional fuselage. In the air it still takes a bit of getting used to ( I think a dark color on the fuselage side would help)
Not wanting to draw up completely new profiles, I modded a set of Sultimate parts I had already cut, decreasing the chord, tail group, and control surface sizes. I used a set of UMX beast electronics.
I test flew it in the parking garage this evening, and it is very neutral. Now that I know it flies, I think I'll draw up an original profile sized for regular F3p gear.
Thought/comments? Has anybody else tried something along these lines?
-Adam
AJWoods is online now Find More Posts by AJWoods
Latest blog entry: F-Zero Hovercraft
Old Jan 03, 2012, 08:42 PM
wparsons is online now
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Looks pretty wild!
wparsons is online now Find More Posts by wparsons
Old Jan 03, 2012, 08:58 PM
hpapilot is offline
Find More Posts by hpapilot
Oly crap.. Deese ease not gud!
hpapilot's Avatar
USA, NC, Kernersville
Joined Nov 2006
I thought about doing something just like this many years ago, but never did try it. I basically decided that other airplanes could perform the maneuvers just as well (probably better considering maneuvers are designed for normal airplanes), feel more natural, and present MUCH better.
I do think it's a very interesting idea from an experimental standpoint!
hpapilot is offline Find More Posts by hpapilot
Old Jan 03, 2012, 09:24 PM
AJWoods's Avatar
Joined Jul 2005
I agree that the presentation is probably the biggest challenge. It looks plane bizarre doing rolls. Pitch and yaw felt like a normal plane, although rudder was much more effective.
I want to try some different paint layouts on the side to see I I can get it looking more like a plane. A 0/90 set up would probably look more natural. I did a lot of work on non planar wings a few years back, so I've got an unusual fondness for weird configurations. BTW I really dig your new Decathlon, I love when planes can do things they're not supposed to!
I'll see if I can shoot some video tomorrow.
-Adam
Old Jan 03, 2012, 10:36 PM
tele1974 is offline
Find More Posts by tele1974
tele1974's Avatar
USA, OH, Olmsted Falls
Joined Feb 2007
Video!!!
tele1974 is offline Find More Posts by tele1974
Old Jan 04, 2012, 02:25 PM
AJWoods's Avatar
Joined Jul 2005
Video:
The Xperiment (2 min 18 sec)
It was pretty tight in the parking garage, but you get the picture. Very fun.
-A
Old Jan 04, 2012, 02:55 PM
BryanEW710 is online now
Find More Posts by BryanEW710
BryanEW710's Avatar
United States, OH, Cincinnati
Joined Sep 2010
Wow...never seen anything like that!
BryanEW710 is online now Find More Posts by BryanEW710
Old Jan 04, 2012, 02:59 PM
numanair is offline
Find More Posts by numanair
numanair's Avatar
United States, WA, Kirkland
Joined Sep 2010
It flies like some sort of fish. Cool.
numanair is offline Find More Posts by numanair
Old Jan 04, 2012, 03:07 PM
AJWoods's Avatar
Joined Jul 2005
The Xperiment Alt (2 min 28 sec)
one more, starting to work on more rolling stuff at the end. John G. flying this time.
Old Jan 04, 2012, 04:23 PM
Sixinarow is offline
Find More Posts by Sixinarow
Addicted
United States, CO, Parker
Joined Dec 2011
Very cool! Makes my little guy look a little basic!
"Span"?
AUW?
Sixinarow is offline Find More Posts by Sixinarow
Old Jan 04, 2012, 04:38 PM
AJWoods's Avatar
Joined Jul 2005
Thanks!
22 inches true, 16in projected. 60-65g depending on the battery
-A
Old Jan 04, 2012, 05:23 PM
BryanEW710's Avatar
Joined Sep 2010
That is so cool!
Old Jan 04, 2012, 06:41 PM
Razors edge 29 is offline
Find More Posts by Razors edge 29
QuAd FaNaTiC
Razors edge 29's Avatar
Canada
Joined Aug 2009
Very cool
Have you tried a GWS 6030 prop using the Beast motor?
Works good and gives more thrust
Razors edge 29 is offline Find More Posts by Razors edge 29
Old Jan 04, 2012, 06:48 PM
AJWoods's Avatar
Joined Jul 2005
Originally Posted by Razors edge 29 View Post
Very cool
Haven't tried that yet, but sounds good. I've been having some issues with the eflite packs sagging on the stock prop. What's the hot battery of choice? I've switched all my single cell stuff to TP packs already.
-A
Old Jan 04, 2012, 06:51 PM
QuAd FaNaTiC
Canada
Joined Aug 2009
Hyperions I would think are the best.
I've been using 2 1S nano tech 160 OR 2 Nanotech MCPX lipos.
BUT
Would make more sense to use a hyperion 2S 180 or 240
-A
Discussion Something different. jofro Foamies (Scratchbuilt) 20 Jan 21, 2012 10:18 PM
Discussion something different foufly Flying Wings 1 Nov 17, 2011 10:11 AM
Discussion And Now for Something Completely Different Highflight Life, The Universe, and Politics 14 Oct 17, 2011 09:13 PM
Discussion Something different your club can do! jccrall Club Talk 0 Sep 08, 2011 12:11 PM
