This thread is privately moderated by Gedexas, who may elect to delete unwanted replies.
Old Jan 03, 2012, 06:55 PM
CP heli ≠ 3D heli
Gedexas's Avatar
United States, NJ, Point Pleasant Beach
Joined Mar 2009
Esky Honey Bee King 4 RTF - first flight pre-flight. Warning: huge pictures.
I already have one of these and I like it so much that I decided to get another one.
Two things that need attention right away are belt tension and swash leveling. The belt was so tight on this one - the rollers were spread apart and angled. It is a matter of time before the belt rolls off of them and I pirouette to the ground.
Adjusting the belt on this heli requires the removal of the fuselage, I'm also planning to use the DX6i with it, so I will be taking the whole thing apart.
The fuselage is held on by the front skid mount, two canopy grommets and the tail box. First I removed the tail and carefully pushed the belt inside the tube - crimping the belt will probably weaken the threads in it.
Then I loosened the front skid mounts and pulled the front portion of the fuselage apart.
The canopy standoffs are two pieces threaded together, a 1.5mm hex takes care of that.
Next thing to go is the head assembly, removing it will make the rest of the process much simpler. All you do to take the head off is pop the servo-swash links, unscrew the antirotation pin and remove the jesus bolt.
Next, loosen the screws holding servos, remove servos, loosen screws holding the frame halves together, remove main gear with one way bearing (don't forget to lube it when reassembling), and split the frame. Don't bend the belt at any acute angles.
When I took my first HBK4 apart, I noticed that the belt rollers don't line up with the main belt pulley, as I mentioned above, this will cause the belt to slip off in flight. So this is a good time to fix it on this heli. Adjusting the main shaft pulley itself is only possible by drilling a new hole in the main shaft, I don't like the Idea of drilling the main shaft, so the rollers will need to be lowered.
Each roller has a bearing pressed in with a bolt going through it, a small washer above the bearing will lower the pulley and the alignment will be correct.
I then put the frame halves back together, lubed every bearing with tri-flow, greased one way bearing and reinstalled tail boom (get the belt twisted in the correct direction). This is a good time to reinstall the tail box and set belt tension correctly, I used a small zip tie to hold the rollers from separating under stress.
Now it's time to put the servos back on (center the horns), slide the swashplate back on and level it. I use tri-flow clear grease to minimize the wear on all ball links.
After the swash is level, I took the rest of the head assembly apart and lubed everything. The blade grips had no grease on thrust bearings and the dampeners needed some as well.
After assembling the head, balance blades, install the gyro and receiver, make all the wires look neat, track blades (paddles too), test fly, put the fuse back on and all is done.
Gedexas is offline Find More Posts by Gedexas
For Sale Esky Honey Bee V2 and Honey Bee King 2 plus LOTS of extras makenzie71 Aircraft - Electric - Helis (FS/W) 3 Oct 29, 2011 11:10 PM
Sold Esky Honey Bee King II drew3d Aircraft - Electric - Helis (FS/W) 2 Sep 18, 2011 06:43 PM
Sold Esky Honey Bee King II (HBK2) PNP homeytwist Aircraft - Electric - Helis (FS/W) 2 Jul 04, 2011 09:30 PM
Question Esky Honey Bee King 2? GCostanza Beginner Training Area (Heli-Electric) 18 Apr 16, 2011 01:51 AM
Sold Esky Honey Bee King 2 upgraded plus lots of parts! -Sold- Mr.EV Aircraft - Electric - Helis (FS/W) 5 Mar 26, 2011 12:13 AM
