This thread is privately moderated by Maxthrottle, who may elect to delete unwanted replies.
Old Jan 03, 2012, 05:19 PM
Maxthrottle is offline
Find More Posts by Maxthrottle
You are a "go" for reentry
Maxthrottle's Avatar
High Orbit.....
Joined Jun 2009
Build Log
Freewing Eurofighter EF2000 Typhoon 2009.06 V1 to V2 and 3 mods
Reserved for build log, Specs, mods, characteristics and observations.
Manufacturer: FREEWING
Make/Model: Eurofighter, Typhoon, EF2000
Vendor: Hobby Lobby (V2 Frame only)
Foam type: EPS Wingspan:
Wing Area:
Wing Load:
Wing MAC/Foil %:
Length:
Weight:
Factory Dry Weight:
AUW:
CG:
Max: ###mm
Static AC:
Dynamic AC:
NP:
Detachable Wings:
Rudders:
Elevatons:
Twin Thrust Vectoring: FW 360 (Pitch, Roll, Yaw) 60mm ID
Drive System:
ExtremeRC Wemo MidiPro
Battery:
22.2V/6S
29.4V/8S
5000mAh 45C Li-Polymer to XT150 6mm bullet
Power Connection:
XT150 6mm bullet paralleled to
(1) 22awg wire with 2.5mm Banana connector to (A)
(2)10AWG ###mm to (B)
(A) BEC: External 10A CC BEC to RX
(B) ESC: 80-120A (12AWG ESC-Motor) ###mm 4mm connectors
EDF/Fan/Motor:
Wemo MidiPro's
Wemo Fan 90mm,
Motors:
Dia : 36mm
Length : mm
Shaft Dia. : 5mm
Weight : grams
No load current(lo) : Internal resistance:
KV :
Poles:
Max Current: A
Max efficiency: %
Power Nominal:
Watts on 6 cells
Advance timing :
Middle
PWM: 16 Khz
Radio: 9Ch
(1) Throttle:
(2) LEvn:
(3) REvn:
(4) Rudder: Y, Steering & Rudder
(5) Gear: Turnigy (A) door and (B) gear (C) Lighting Sequencer
(A) Retract Servoless retract system PZ15091-Metal AKA HK514
(B) Door servo
(C) Lighting Mains
(6) Canard: Flap control setting
neutral 2
3D 12
Alpha/Landing 20
Brake 70
(7) TV L: Ail>Aux2/Elv>Aux3
(8) TV R: Ail>Aux2/Elv>Aux3
(9) Lighting or TV Yaw
Landing Gear:
Strut:
Nose Gear Strut and Wheel Height_###mm_, Wheel Dia. _##mm_
Main Gear Strut and Wheel Height_###mm_, Wheel Dia._##mm_
Maxthrottle is offline Find More Posts by Maxthrottle
Build Log Eurofighter Typhoon from Red Leader bidule Electric Ducted Fan Jet Talk 25 Mar 04, 2012 06:06 PM
Mini-HowTo ripmax freewing eurofighter typhoon jet RAY.PEACOCK Radios 0 Apr 17, 2011 06:57 PM
Mini-Review Art-Tech's Black EF2000 Eurofighter Typhoon 64mm EDF RC Jet w/ FPV-CAM by NightFlyyer nitroplanes Nitro Planes 1 Aug 04, 2009 05:03 PM
Sold NIB Sapac EF2000 Eurofighter Typhoon efether Aircraft - Electric - Jets (FS/W) 14 Nov 22, 2008 10:27 AM
Discussion Desert camo Eurofighter Typhoon ef2000 from bigglesjets plans rbishoff Pusher Prop Jet Models 1 Jan 18, 2008 01:31 AM
