Jan 05, 2012, 06:32 AM
Okay...here is the result. Reversing the sequencer connections simply makes the functions work opposite each other, e.g. the doors close FIRST, then the wheels want to come up against the closed doors. No surprise here. Back to the original problem...the retract struts are working to an opposite signal (reversed) from that of the original retracts that came with the plane. When the gear are down, the doors close, and when the doors open, the gear go up. A work around to this is to disconnect the sequencer and plug the doors separately into another channel (6). This will require a Tx/Rx that is more than the 5 channel that comes with the plane, and separate actions (remembering of course which one comes first) to 1 - open doors, and 2-lower gear and vice versa. Why should I have to do this? Replacement retracts should be the same as the original. I paid over $60 for the parts and shipping for something that does not work right. It would appear there is no technical solution to this problem. Nitro Planes - please advise.
