Old Jan 03, 2012, 05:29 AM
Zaitsevsky is offline
Find More Posts by Zaitsevsky
Zaitsevsky's Avatar
Vilnius, Lithuania (EU)
Joined May 2009
New Product
Inertial camera stabilization
The first model of Ecilop aircraft (2 min 45 sec)
The key advantages of Ecilop drones compared to other commercial light multi-copters (the list was compiled at the end of 2011):
1. The use of an onboard battery as a counterweight for the camera unit enhances the stabilization effect.
2. The use of a counterweight enables the implementation of a compact, lightweight and rigid rotation mechanism.
3. The relocation of the battery to the stabilized platform produces a favorable effect on the maneuverability of the drone.
4. Absence of a hard connection with the servo-unit prevents camera jerks and jitter.
5. Adjustable fixtures make it possible to easily obtain accurate balancing of the camera gimbal in three dimensions.
6. Precise balancing of the camera mount makes it possible to use lightweight and fast servo-units.
7. Electronic gyroscopes are installed on the stabilizable part of the camera mount and prevent swaying.
8. Soft shock absorbers suppresses vibrations in a wide range of frequencies.
9. Shock absorbers are installed on the same level with rotation axis, which prevents camera swaying during maneuvering.
10. Onboard electronics is installed on the platform with shock absorbers. The increased weight of the platform makes it more stable.
11. Autopilot accelerometers are better protected from vibrations and therefore produce more accurate results.
12. The matching of the vertical center of mass of the drone with the rotor rotation plane decreases drone swaying during maneuvering.
13. The leaning of rotor blades towards of the drone's center improves stability and widens the camera's viewing angle.
14. The camera is fastened using a lens clamp. This type of fixture is more reliable, compact and weighs less than an underlying platform.
Zaitsevsky is offline Find More Posts by Zaitsevsky
Site Sponsor
Old Jan 03, 2012, 05:47 AM
gundamnitpete is offline
Find More Posts by gundamnitpete
Team White Llama!
gundamnitpete's Avatar
United States, TX, Houston
Well, you've already got a camera on it, where are the onboard shots?
gundamnitpete is offline Find More Posts by gundamnitpete
Old Jan 03, 2012, 05:59 AM
Zaitsevsky's Avatar
Joined May 2009
need some free time and a good weather. Temporary data will not be demonstrated.
Site Sponsor
Old Jan 03, 2012, 06:02 AM
timecop is offline
Find More Posts by timecop
Joined Dec 2010
Finally, some innovation.
What about flight control electronics? Also custom?
timecop is offline Find More Posts by timecop
Reply With Quote  (Disabled)
Old Jan 03, 2012, 07:04 AM
Zaitsevsky's Avatar
Joined May 2009
It was tested with Arduino, MK and one new "no_name" controller.
Site Sponsor
Old Jan 03, 2012, 07:27 AM
Hypam is offline
Find More Posts by Hypam
Joined Jul 2011
This is Steadycam for copter, and Steadycam Patents expired in the 90`.
Do you have a link to your registration, I would like to see what
exactly has been patented.
Hypam is offline Find More Posts by Hypam
Old Jan 03, 2012, 08:06 AM
Zaitsevsky's Avatar
Joined May 2009
Inertial camera stabilization system was invented one century ago. Stedycam is a brand only. They patented a body supported mount. Priority date for my invention is 2011 june. It is published in lithuanian only. PCT patent (WO) must be published in 2012. Invention - haw to combine inertial and active stabilization.
Site Sponsor
Old Jan 03, 2012, 08:17 AM
Tarro is offline
Find More Posts by Tarro
Long Island, New York
Joined Jun 2008
Obviously impressive, where the heck are the aerial shots from the copter?
How much$$$$$?
Tarro is offline Find More Posts by Tarro
Old Jan 03, 2012, 09:53 AM
Zaitsevsky's Avatar
Joined May 2009
price
How much$$$$$?
Price for the first commercial model will be known in march. I'm not planing to monopolize this technology. Licensed production will be allowed.
Site Sponsor
Old Jan 03, 2012, 09:56 AM
Tarro is offline
Joined Jun 2008
Great, I will be looking for it.
Old Jan 03, 2012, 10:24 AM
chris24g is offline
Find More Posts by chris24g
United States, CA, Hayward
Joined Apr 2006
Agreed, it uses the same principles implemented in gimbal type stabilizers (steadicam, glidecam, etc...)
Advantage:
I already can tell the footage will be smoother than anything out there currently. I have a steadicam, and that's how a correctly balanced gimbal will behave.
Disadvantage:
Camera setup and balancing is going to be a PITA. You have to dedicate a camera and battery weight combination. Change anything, and you will be out of balance and have to rebalance.
It shouldn't be too expensive, since it relies on good mechanics and physics application rather than software or electronics. I'd say sub-$500 is definitely possible.
chris24g is offline Find More Posts by chris24g
Old Jan 03, 2012, 10:36 AM
Tarro is offline
Joined Jun 2008
I don't know about sub $500, you have to use that copter frame as well so you are buying the whole system. Not just the camera mount.
timecop is offline
Joined Dec 2010
I really dig that frame. For many reasons. Infact I think I'll make one myself for a next project.
Old Jan 03, 2012, 10:39 AM
AlanFlorida is offline
Find More Posts by AlanFlorida
AlanFlorida's Avatar
USA, FL, Palm Harbor
Joined Jul 2004
http://vimeo.com/34380349
Optimization of the construction is still under way. Material shot in motion will be added soon.
Absolutely BRILLIANT!!!! Your creativity and engineering skills are amazing!!
AlanFlorida is offline Find More Posts by AlanFlorida
Old Jan 03, 2012, 10:40 AM
chris24g is offline
Joined Apr 2006
ok, add the cost of 6 pieces of aluminum tubing and some screws
Discussion The BIG camera stabilization question elmesito Aerial Photography 7 Oct 03, 2011 11:03 AM
For Sale FY-20A Inertial Flight Stabilization System skyking1 FPV Equipment (FS/W) 7 Sep 19, 2011 05:50 PM
Sold NEW FY-20A Inertial Flight Stabilization System blively FPV Equipment (FS/W) 2 Aug 22, 2011 02:00 PM
Sold NEW FY-20A Inertial Flight Stabilization System blively Aircraft - General - Miscellaneous (FS/W) 2 Aug 21, 2011 12:00 PM
Sold FY-20A Inertial Flight Stabilization System alexedit FPV Equipment (FS/W) 2 Jul 31, 2011 02:46 PM
