Old Oct 04, 2003, 11:21 PM
corndog is offline
Find More Posts by corndog
Registered boozer
corndog's Avatar
davis, ca.
Joined Sep 2002
best 4 stroke for a newbie?
i have been very into the electrics for a while now. i have had 2 stints with gas. 1st- i bought a sig somethin extra kit and a tower .46 engine. i folowed the directions to the letter. i use work instructions and prints everyday with my job, so believe me when i say i followed them. the engine would not stay running and went through glow plugs like crazy. i eventually found a thread discussing how much they suck and have air leak problems. i never flew it and ended up selling them both on ebay, sad. 2nd- i bought a ripmax alienator and an ap .15 engine. that worked out pretty well. the plane flew good. i dont think i ever achieved max rpm for some reason. i read about some others having similar problems. perhaps i didnt ever really break it in. less than a dozen flights. both experiences were very messy and not very much fun. well, now im ready to try again. this time im going to get a four stroke. i wouild like to know of any good, reliable, powerful four strokes. something a beginner is likely to be successful with. i will buy a plane to fit the engine, but want a 40-60 size plane. im also a tightwad. ive seen a few magnums and thunder tigers at tower for less than 200 bucks. are those ant good? if not what would any of you guys suggest? thanks for the help-cd
corndog is offline Find More Posts by corndog
Old Oct 05, 2003, 08:38 AM
DaveSawers is offline
Find More Posts by DaveSawers
Canada, NS, Lunenburg
Joined Oct 1999
If you didn't have much success with 2-strokes, you're unlikely to fare better with 4-strokes.
4-strokes have more things to go wrong and are more sensitive to needle settings. They're also more expensive and less powerful. In general, in this game you get what you pay for. Cheap 2-strokes and cheap 4-strokes will cause you grief.
To run a 2-stroke successfully, there are some things you need to know that are not in the instructions. Firstly, many cheap engines are built carelessly and not in a clean environment. First thing you need to do is strip them down and flush out all the swarf that will almost certainly be in the crankcase. This is one cause of blowing glow plugs in a new motor.
The other main causes of blowing plugs are: Running them too lean (which wrecks them quite quickly) or overcompression which means you need to add an extra head shim. Most inexperienced modellers run their motors too lean. It take experience to set them properly.
The other problem you need to know how to solve is getting rid of air leaks. There is some discussion around here about this problem on various motors.
DaveSawers is offline Find More Posts by DaveSawers
Old Oct 05, 2003, 03:08 PM
Hammer is offline
Find More Posts by Hammer
United States, NC, Harrisburg
Joined Mar 1999
I would go with an OS 52, or a 70 if you want to overpower a 40 size model.IMHO OS 4 strokes run more reliably and are easier to adjust than Saitos.Saitos also like higher nitro fuel than OS.You might also consider Enya,which are high quality good running engines that don't get much publicity for some reason.My only experience with an Enya 4 stroke engine is running a 1.20 on the bench,where it ran great. The YS engines are powerful and run great,but might be too complicated for beginner use.I would steer clear of the "less expensive" 4 strokes.
Oh,and like Dave said,run it rich,the vast majority of engine problems come from running too lean.
Caution:All the above is my opinion,formed from my experiences.I'm sure everyone doesn't agree.
Hammer is offline Find More Posts by Hammer
Old Oct 05, 2003, 09:23 PM
Joined Oct 1999
That of course goes for all the "opinions" posted on this discussion board. Caveat emptor!
Old Nov 02, 2003, 12:29 AM
Dauntae is offline
Find More Posts by Dauntae
Dauntae's Avatar
New Bedford, Ma. USA
Joined May 2001
I used to be a 2-stroke junkie right up till I got a 4-stroke, I have OS YS and a magnum and all of them run well but the YS is a bit complex to set up and more apt to issues with fuel systems so I would not recomend them as the first 4-stroke, However one of the less exspensive ones is the Magnum and Mine and the guys at the club all will say that they are trouble free and just as easy to tune as a 2-stroke, Heck mine gives me less grief than some of my 2-strokes and always starts on the first flip.
Dauntae
Dauntae is offline Find More Posts by Dauntae
Old Nov 04, 2003, 11:09 PM
swooper is offline
Find More Posts by swooper
gravity-challenged
swooper's Avatar
Victor, Idaho
Joined Sep 2003
Get a Thunder Tiger .46 2stroke and learn to adjust it so when the plane is held with the nose straight up and the throttle wide open, the engine continues to run strong without sagging. Otherwise it's too lean.
Why the Thunder Tiger? Because it's one of the best quality-per-dollar deals around.
Why a .46? Because really small engines are fussier and really big ones are expensive and more deadly. 46's provide strong power for any .40-sized airplane, run great, and don't cost too much.
Why the 2stroke? Because they are typically ABC construction which tolerates poor adjustment (learner's mistakes) better than the ringed construction 4strokes have. It's much easier to ruin a 4stroke quickly by leaning it out. Get experienced with a 2stroke before investing in a 4stroke.
swooper is offline Find More Posts by swooper
Old Nov 05, 2003, 01:48 PM
flyingflying60 is offline
Find More Posts by flyingflying60
northamptonshire
Joined Nov 2003
i would completly dissagree with a thunder tiger engine i think they are the most rubbish engine on the market i btought one for my ripmax trainer 40 when i first started i had no end of trouble with it like not enough power and kept on dead sticking i put 3 planes into the ground because of my thunder tiger engine. if you have the money pay a few quid extra and get an irvine or os theyre great
flyingflying60 is offline Find More Posts by flyingflying60
Old Nov 06, 2003, 03:51 PM
Mr. Wiz is offline
Find More Posts by Mr. Wiz
Time for me to Fly...
Mr. Wiz's Avatar
United States, MI, Fenton
Joined Jan 2000
See the following post for my recomendation. My opinion is the same for the entire range of O.S. 4-cycle engines..... except the .30. I've never owned that one.
http://www.rcgroups.com/forums/showt...85#post1466385
Wiz
Mr. Wiz is offline Find More Posts by Mr. Wiz
Old Nov 17, 2003, 06:00 AM
rceagle1a is offline
Find More Posts by rceagle1a
Generally R/C Insane!!!
Newton Iowa USA
Joined Oct 2003
I also have an OPINION! I own a magnum .52 four stroke and it runs great! I also have saitos and yes they do like more nitro but they are no harder to adjust than an os and they are More reliable in my club. Almost all of the fourstroke guys in my club run either magnum four strokes or saito's and just a few O.S I think this one engine is so much better thing is getting out of hand. Break it in right and it wil run fine.
rceagle1a is offline Find More Posts by rceagle1a
Old Nov 17, 2003, 03:27 PM
bigbobed is offline
Find More Posts by bigbobed
Awsome 2.5D Pilot.
bigbobed's Avatar
United States, NC, Jackson Springs
Joined Nov 2003
I would like to try Magnum engines but I have a concern. The manuals specify fuels with castor oil. All that's available here is synthetic. Any comments would be appreciated.
bigbobed is offline Find More Posts by bigbobed
Old Nov 17, 2003, 03:54 PM
Mr. Wiz is offline
Mr. Wiz's Avatar
Joined Jan 2000
Last summer one of my flying buddies showed up to the field with a Magnum .91 4-cycle. We were both thinking as we watched him fly, that it didn't seem to be making as much power as the plane (Venture 60) needed. On the ground we tached the engine and found my O.S. .70 Surpass II would spin the same prop APC 14x6
at the same RPM. Same fuel....same plug...same day...FWIW.
Wiz
Old Nov 17, 2003, 04:02 PM
Hammer is offline
Joined Mar 1999
I don't understand this statement.I see several recommendations from different people.You also gave yours.Just because more of the people here prefer OS, or Saito, means anything is getting out of hand.
bigbobed,
I would run the Magnum on straight synthetic fuel.Just make sure to run a little rich and you'll have no problems.OS recommends fuel with castor and/or synthetic oil.Saito does not recommend all castor fuels.Castor/synthetic blends are recommended.YS is the same as OS.All Castor,or all synthetic,or a blend is OK.
I personally hate Castor oil as it gunks up engines and turns them all brown.I always make sure my fuel has zero Castor,and I never have engine problems,and have nice clean engines too.That's a topic for another thread though,as I'm sure that would stir up quite a debate also.
Old Jul 25, 2004, 04:10 AM
mattkillkill is offline
Find More Posts by mattkillkill
mattkillkill's Avatar
Sydney
Joined Jan 2003
I have a thunder tiger pro 46 and have had absolutly no problems with it. In fact my opinion of them is very good. It started at forth flick by hand when running in and for tuning. Since then it has been easy to start and 100% reliable. It has tonnes of grunt and is my engine of choice for 40 sized sport planes. I can only assune that "flyingflying60" got a dud engine. I didn't, and consequently have and will buy them again.
mattkillkill is offline Find More Posts by mattkillkill
Old Jul 26, 2004, 01:40 PM
rayfisher is offline
Find More Posts by rayfisher
Northampton Sywell, Great Britain (UK)
Joined Jan 2004
Come over to the NVA field (Olney) and I'll show you how to set it up :-)
rayfisher is offline Find More Posts by rayfisher
Old Jul 27, 2004, 03:15 PM
Gerald is offline
Find More Posts by Gerald
ὅπερ ἔδει δεῖξαι
Gerald's Avatar
Joined May 2000
Wiz
Mike, have you owned the O.S. 48 Surpass? I've had a lot of trouble with the one I have getting it to stay running through an entire flight. It seems to be hypersensitive to mixture. Makes great power when it's running right but changes drasticly during the course of a flight. I usually have to land and retune it about 3 times per tank. Needle valve seems to have kind of a sloppy fit and I had to put a piece of fuel tubing over it to seal the air leaks. Any suggestions on making this engine run consistently?
Gerald is offline Find More Posts by Gerald
Discussion best 4 stroke engine for a cessna 50 Erwin Z Fuel Plane Talk 3 Aug 12, 2007 05:25 PM
Discussion Best 4 stroke for a 60" Edge 540 jason@macaid Australia 6 May 14, 2007 09:19 AM
Best 4-Stroke for the money? Rhathid Fuel Plane Talk 25 Oct 17, 2004 02:00 PM
Trade NIB HP-49 4 stroke/ For NIB ARF PLANE Doc11 Aircraft - Electric - Airplanes (FS/W) 3 Aug 02, 2001 07:25 PM
Best covering film for newbie? astroboy Electric Plane Talk 8 Jul 20, 2001 02:59 PM
