Old Jan 02, 2012, 11:02 AM
TomLee is offline
Find More Posts by TomLee
Denver, CO.
Joined Feb 2006
900 Mhz
Because of 2.4's high use and vunerablety, sometime ago there was some discussion about using 900 Mhz. Does anyone know if that has gone any farther?
TomLee is offline Find More Posts by TomLee
Old Jan 02, 2012, 09:21 PM
theKM is offline
Find More Posts by theKM
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
the upcoming transmitter will have a 900mhz version as will the new receivers in development...
theKM is offline Find More Posts by theKM
Latest blog entry: Updated Hatcam - Apr2016
Old Jan 03, 2012, 09:07 AM
TomLee is offline
Denver, CO.
Joined Feb 2006
Thanks, any specs or costs yet? As I also recall, there was some discusions about a new system being available only to professionals, any truth to that?
Old Jan 03, 2012, 10:19 AM
theKM is offline
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
the 2.4 Tx is going to have a price tag of $250... Jim has mentioned that the 900mhz would probably be labeled as the "pro" version... but unsure if pricing will be any different, and for sure the "pro" is just a label, not that it will be restricted to professional customers.
Old Jan 03, 2012, 11:37 AM
TomLee is offline
Denver, CO.
Joined Feb 2006
When Jim's system first came out, a couple of us went to his system. We were having some very weird problems we could not solve. I used to range test with a receiver covered by a tin can 3ft above the ground greater than 100 ft., put that receiver and a LiFe receiver pack in an airplane and some days all would be well and the next day, crash the airplane. My friend would have the same problems. We also sent our Futaba's in for service and asked them to be sure to check the solder connections. We went to Jim's system because, we both really liked our old 8U and 9C's and we both had a lot of compatable 72 receivers we could go back too if need be.
We have since discovered that any non-hopper system is questionable to fly at our field. We have both went to a hopper system, him to Futaba and me to Hitec and eliminated our problems. So-my question is this, has Jim went to a hopper system?
BTY, I had a module, xdp, and about 10 receivers.
Old Jan 03, 2012, 12:34 PM
theKM is offline
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
yup, the XPS system is now hopping full time. I started using it after this update, but in use at events like SEFF, I've had no radio issues.
Old Jan 03, 2012, 03:35 PM
JimDrew is offline
Find More Posts by JimDrew
Xtreme Power Systems
Lake Havasu, AZ
Joined Jun 2005
We have always had frequency hopping. In October of 2008 we added 4 new frequency hopping modes (to conform with European EN300-328 rules changes). We also added a low voltage warning, and 80% of our customers immediately reported the warning coming on!
900MHz is definitely a better frequency for flying. We will have both 900Mhz and 2.4GHz versions of our transmitter, as well as the exact same receivers available in both 900MHz and 2.4GHz versions.
JimDrew is offline Find More Posts by JimDrew
Old Jan 03, 2012, 08:54 PM
theKM is offline
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
<---- is looking forward to being a 900mhz snob
Old Jan 04, 2012, 09:16 AM
TomLee is offline
Denver, CO.
Joined Feb 2006
When I opened this thread, I did not intend to get into a discussion about frequency hopping, or batteries. I am only really interested in 900 mhz, the transmitter specs, costs of both the transmitter modules and receivers.
Old Jan 04, 2012, 10:27 AM
theKM is offline
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
then why did you ask about hopping?... Jim only mentions the batteries because it was his experience that the reliability of the XPS system was there but it was an on-board power issue.
The transmitter thread can be found here... http://www.rcgroups.com/forums/showthread.php?t=1243767
...lighten up, it's a forum thread.
Old Jan 04, 2012, 01:16 PM
TomLee is offline
Denver, CO.
Joined Feb 2006
Your right it's just a forum thread, and I apologize for sounding negative.
Old Jan 05, 2012, 10:57 AM
GoFaster is offline
Find More Posts by GoFaster
Live for speed
GoFaster's Avatar
USA, CT, Bethany
Joined Mar 2004
Based on dev, compliance testing and production schedules - can we anticipate 900Mhz tx and rx system in 2012?
GoFaster is offline Find More Posts by GoFaster
Old Jan 05, 2012, 11:26 AM
theKM is offline
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
Jim was saying that the FCC delay in the 2.4ghz allowed some progress on 900mhz and that it may not be far behind the 2.4ghz set at all.
Old Jan 05, 2012, 01:20 PM
KeithK is offline
Find More Posts by KeithK
What Canary?
KeithK's Avatar
Huntsville, AL USA
Joined Jul 2000
Will there be a 900Mhz module for the Hitec Aurora 9?
KeithK is offline Find More Posts by KeithK
Old Jan 06, 2012, 12:10 AM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
We plan to make 900MHz as common as our 2.4Ghz, with indentical modules and receivers.
Sold Gently used 900 mhz patch and 1/2 wave 900 mhz tx antenna Kahuna717 FPV Equipment (FS/W) 2 Oct 02, 2011 04:50 AM
Help! RV 900 mHz TX/RX, DX-201. PROBLEMS bsfixit FPV Talk 3 Sep 12, 2011 02:13 PM
Found 900 mhz Receiver thefokker FPV Equipment (FS/W) 3 Sep 08, 2011 02:53 PM
For Sale Gently used 900 mhz patch and 1/2 wave 900 mhz tx antenna Kahuna717 FPV Equipment (FS/W) 1 Aug 02, 2011 08:53 PM
For Sale Gently used 900 mhz patch and 1/2 wave 900 mhz tx antenna Kahuna717 FPV Equipment (FS/W) 4 Jul 02, 2011 11:20 PM
