Old Jan 02, 2012, 03:13 AM
Nelatonin is offline
Find More Posts by Nelatonin
Joined Dec 2011
Can Brushless motors run on 2 wires? Can they work without an ESC?
Can brushless motors work with only 2 wires?
Eg; not connecting the third to an ESC?
Will it still run?
Nelatonin is offline Find More Posts by Nelatonin
Old Jan 02, 2012, 03:35 AM
scirocco is offline
Find More Posts by scirocco
scirocco's Avatar
Australia, ACT, Kambah
Joined Feb 2001
The answer is no, and you can't run a brushless motor off a brushed ESC.
I highly recommend you visit this forum: http://www.rcgroups.com/forums/showthread.php?t=739069 as there are masses of resources for learning about the ins and outs of electric flight that will help you focus your questions.
Another fantastic resource is here: http://homepage.mac.com/kmyersefo/sitetoc.html
And one more: http://www.rcgroups.com/forums/member.php?u=106813
scirocco is offline Find More Posts by scirocco
Old Jan 02, 2012, 04:51 AM
Piece is offline
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
Simple answer: No.
More detailed answer: No.
Piece is offline Find More Posts by Piece
Old Jan 02, 2012, 09:20 AM
slipstick is online now
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
Oh I don't know . If you want a detailed but fairly useless answer :
- no ESC, nothing will happen
- ESC and two wires only connected it will never start
....BUT
- if you start a motor with all 3 wires connected to the ESC and then cut one of the wires it will carry on working after a fashion.
So what was it you really wanted to know ?
Steve
slipstick is online now Find More Posts by slipstick
Old Jan 02, 2012, 09:47 AM
Gary_Canada is offline
Find More Posts by Gary_Canada
Gary_Canada's Avatar
Southern Ontario
Joined Jan 2002
Many folks ask this type of question to avoid spending money.
Take a look take a look at some of these very inexpensive controllers (ESC) from
China:
\http://www.hobbyking.com/hobbyking/s...yKing_ESC.html
or one shipped from US, here is a 25 amp one for less than $11:
http://www.hobbypartz.com/60p-dye-1002-25a-esc.html
Gary
Gary_Canada is offline Find More Posts by Gary_Canada
Old Jan 02, 2012, 09:53 AM
Masterpiece is offline
Find More Posts by Masterpiece
Hervey Bay, Sunny Qld, Australia
Joined Jun 2001
Will it still run?
Hmmm. Brushless because the motor has no brushes and relies on a alternating current provided from the ESC (the ESC converts the battery current from DC to AC) to provide the opposing electro magnet fields in the windings, in the casing. Opposing to the neodymium magnets on the rotor (inrunner in this case) which causes the motion.
All you'll get is a brief jolt in the motor but no spin.
Masterpiece is offline Find More Posts by Masterpiece
Old Jan 02, 2012, 11:59 AM
pilotpete2 is offline
Find More Posts by pilotpete2
pilotpete2's Avatar
The Northeast Kingdom, Vermont
Joined Jun 2004
As opposed to the 50 or 60Hz Hmmm you'll get with an AC input to a BLDC motor
The ESC provides electronic commutation of the DC input, based on the feedback the ESC gets from the motors back EMF.
Pete
pilotpete2 is offline Find More Posts by pilotpete2
Old Jan 02, 2012, 01:41 PM
Ron van Sommeren is offline
Find More Posts by Ron van Sommeren
homo ludens modellisticus
Ron van Sommeren's Avatar
Netherlands, GE, Nijmegen
Joined Feb 2001
Originally Posted by slipstick View Post
- ESC and two wires only connected it will never start ...
Controller may even burn.
- no ESC, nothing will happen ...
- connect two of the three wires directly to battery and you will cause a minor conflagration: motor and/or battery will go up in flames. A brushless motor is a massive short for DC voltage/current!
Pete
More pictures and explanation:
http://www.aerodesign.de/peter/2001/...DY-BL_eng.html (English version)
Full throttle, no PWM chopping
Partial throttle, PWM chopping for lower RPM
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old Jan 02, 2012, 01:50 PM
Joined Feb 2001
Several animations. It's obvious that the three motorwires (phases) are equivalent, but not the same.
http://www.aerodesign.de/peter/2001/...index_eng.html (English)
-> Animation 14-magnetpole outrunner
Two magnetpole inrunner
http://townbiz.com/animations/2-pole_bldc_motor.swf
Four magnetpole inrunner
http://townbiz.com/animations/4-pole_bldc_motor.swf
More
http://townbiz.com/animations/animations.html
Old Jan 03, 2012, 01:30 AM
Joined Dec 2011
thank you
Old Jan 03, 2012, 12:11 PM
Mark Wood is online now
Find More Posts by Mark Wood
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
It's also obvious that there is NO ac current but pulsed dc.
mw
Mark Wood is online now Find More Posts by Mark Wood
Old Jan 03, 2012, 12:59 PM
Joined Feb 2001
Thanks Mark for opening that can of worms
Gelukkig Nieuw Jaar Ron
diy motor tipsDrive Calculator
diy motor groupCumulus MFC
Old Jan 03, 2012, 01:25 PM
Lnagel is online now
Find More Posts by Lnagel
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
mw
Actually, the pulsed DC does create an AC current through the motor windings. The scope traces that Ron posted display represent the voltage applied from the ESC to the motor, not the current flowing through the motor windings. I have attached a photo of a scope trace that does represent the current through one pair of windings on a brushless motor. The center horizontal line with the hash marks represents zero amps. You can clearly see that the current flow is maximum in one direction (trace is above the zero reference) for 2/3 of the commutation cycle and the current is zero for 1/3 of the commutation cycle. During the next commutation cycle the maximum current trace is below the zero reference indication that the current is flowing through the coils in the opposite direction, i.e. AC current.
Larry
Lnagel is online now Find More Posts by Lnagel
Old Jan 03, 2012, 03:14 PM
pilotpete2's Avatar
Joined Jun 2004
Isn't this pretty much the same thing that we'd see if we looked at the current flow in the coils of a brushed motor running on DC?
Pete
Old Jan 03, 2012, 04:59 PM
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
Exactly the same, Pete. Very perceptive of you.
Larry
Discussion can you use a single esc to run 2 motors? captaingeek DIY Electronics 4 Apr 30, 2011 05:50 PM
Help! Can I run 2 brushless motors on one esc? foxsavage Scratchbuilt Indoor and Micro Models 3 Aug 29, 2008 12:49 AM
Discussion Can you run 2 brushless motors from 1 ESC??? SGTalon Power Systems 1 Jun 30, 2006 10:20 AM
can you run 2 brushless motors off of one esc? jeff262 Power Systems 4 May 31, 2004 12:39 AM
Can you run 2 brushless motors off of one ESC nikolaus_c Power Systems 1 Jul 05, 2003 12:44 PM
