Old Jan 01, 2012, 07:17 PM
jforkner is offline
Find More Posts by jforkner
jforkner's Avatar
Copperopolis, CA
Joined Sep 2003
After Naza upgrade motors won't start
All was well. My Naza kit worked & flew well. Then I noticed an Assistant Software & Firmware upgrade to take me from Assistant 1.0 to 1.1 and Firmware 0.1 to 1.02. Downloaded, installed, recalibrated the Tx, verified the firmware change in the Assistant.
Went out to give it a try and the motors won't start. Tried several CSC commands---nothing. Redid firmware upgrade and Tx recalibration several times. No luck. Verified the Rx is working.
I'm sure it's something stupid I did (or didn't do), but I can't figure out what. Doesn't appear I can backtrack to the older firmware version, so I don't know where to go from here.
Any thoughts or ideas will be appreciated.
Thanks.
Jack
jforkner is offline Find More Posts by jforkner
Old Jan 01, 2012, 08:00 PM
fajar is offline
Find More Posts by fajar
fajar's Avatar
Indonesia, Special Capital Region of Jakarta, Jakarta
Joined Jan 2011
Thanks.
Jack
Got similar situation in the field the other day. It turns out my tx is triggering failsafe, problem solved after corresponding dial was returned to neutral position.
fajar is offline Find More Posts by fajar
Old Jan 01, 2012, 08:12 PM
Tahoe Ed is offline
Find More Posts by Tahoe Ed
DJI Support
Tahoe Ed's Avatar
Las Vegas/Lake Tahoe
Joined Feb 2010
Fajar, doing the upgrade does require resetting your settings in Assistant.
http://www.rcgroups.com/forums/showp...1&postcount=10
Tahoe Ed is offline Find More Posts by Tahoe Ed
Site Sponsor
Latest blog entry: How to reload P3 firmware
Old Jan 01, 2012, 08:20 PM
fajar is offline
fajar's Avatar
Joined Jan 2011
Thx for reminding me on that, ed. Havent done the upgrade but I will in the next few days.
Old Jan 02, 2012, 06:45 AM
jforkner is offline
jforkner's Avatar
Copperopolis, CA
Joined Sep 2003
Mea Culpa. Mea Culpa
Operator error! I had to reverse the Elevator Channel in the Assistant software. The motors start as they should.
I had flown the quad a half dozen times (and once just prior to the upgrade), and "thought" i knew all the settings when using the old firmware. I'm using a Futaba transmitter and knew I had to reverse the throttle (which I did in the radio, not the software); I "thought" the other channels were all set to NORM. In reading the Users Manual for the umpteenth time, I noted "Elevator: Slide left is craft back, slide right is craft front." This makes sense and was how it worked before; but I didn't remember reversing the channel to achieve it. And I had assumed all the old settings would carry over after the upgrade, so I didn't verify everything as I should have.
My only excuse is I turn 69 in 3 weeks and my memory sucks. A poor excuse, true, but it's the only one I've got.
Thanks to all who offered advice. A frustrating experience for sure, but I did learn a couple things...RTFM (read the #$%@! manual) and if everything is working, don't upgrade.
Jack
Discussion DJI Naza / Flame Wheel 450 RTF Kit -- Engines Won't Start brianshell Multirotor Talk 49 Oct 08, 2012 04:22 AM
Help! motor won't start after running in deep sand flheloplt Nitro and Glow Power Cars 2 Mar 30, 2008 03:54 PM
Help! Won't start after charge peakheli BladeRunner Heli 11 Dec 29, 2004 04:59 PM
Motor won't run for long after start heb Racing Boats - Internal Combustion 5 Oct 19, 2004 10:23 PM
