Old Jan 01, 2012, 07:02 PM
brianshell is offline
Find More Posts by brianshell
brianshell's Avatar
United States, UT, Ogden
Joined Nov 2011
DJI Naza / Flame Wheel 450 RTF Kit -- Engines Won't Start
First, I'm brand new to quads.. so be gentle. (Hopefully I'm just doing something stupid)...
Brand new RTF kit from DJI showed up yesterday. I've run into a road-block and need some assistance.
I'm unable to get the throttle to power up the motors.
1) When I power everything up, I hear the satisfying "1234567" song from each of the ESCs.
2) When I turn on the throttle on my radio, the unit just sits there like I've done nothing. I've tried all three flight modes (the flight-mode switch does seem to be working on the TX, since moving it does change the blinking on the Naza LED thing).
3) I know the RX is connected properly to the Naza unit because I can hook the Naza unit to my computer and see the throttle move when I move the control on the TX. This is an indicator that all sorts of things are properly connected and functioning.
4) If I disconnect the ESC and plug is straight into another RX (like it's for an airplane), it seems to work great. So I know the ESCs and motors are functioning properly.
The only conclusion I can draw is that the Naza unit is preventing the throttle from engaging the motors for some reason.
Any ideas would be very welcome!!
brianshell is offline Find More Posts by brianshell
Old Jan 01, 2012, 07:20 PM
jforkner is offline
Find More Posts by jforkner
jforkner's Avatar
Copperopolis, CA
Joined Sep 2003
Are you following the one of the CSC combinations listed under STEP2: Cut Off Type? Took me a bit to figure that out.
Jack
jforkner is offline Find More Posts by jforkner
Old Jan 01, 2012, 07:29 PM
brianshell's Avatar
Joined Nov 2011
Jack
Somehow I missed this in the manual.... I was hoping it was something that simple, but no luck. Does the system beep once armed? I've tried all 4 different positions, including powering on fresh between each of the 4 positions the manual lists.
Old Jan 01, 2012, 07:36 PM
jforkner is offline
jforkner's Avatar
Copperopolis, CA
Joined Sep 2003
Yes, the system beeps when armed.
But I must tell you, I just upgraded the firmware on my Naza to v1.02 and now my motors won't start---everything worked fine under v0.1. Not sure if it's operator error or a bug in the firmware, but you may want to check your firmware version.
Jack
Old Jan 01, 2012, 07:37 PM
brianshell's Avatar
Joined Nov 2011
Jack
Ugh.. I'm also running v1.02.
Old Jan 01, 2012, 07:41 PM
jforkner is offline
jforkner's Avatar
Copperopolis, CA
Joined Sep 2003
Perhaps there's a bug in the firmware. Stay tuned.
Jack
brianshell's Avatar
Joined Nov 2011
There appears to be no way to downgrade the firmware... SO I'm sort of screwed, it would seem.
Old Jan 01, 2012, 07:43 PM
Tahoe Ed is online now
Find More Posts by Tahoe Ed
DJI Support
Tahoe Ed's Avatar
Las Vegas/Lake Tahoe
Joined Feb 2010
Brian, welcome to the world of the Naza. I would start here:
http://www.rcgroups.com/forums/showthread.php?t=1536553
I am running v1.02 and have no issues at this point. Motors arm and respond as they should. I am sure that it is something simple and you will be flying shortly. Spend a little time reviewing the setup in the Assistant with your transmitter. Did you calibrate your esc's independently with your receiver? Are your throttle travel adjustments at 100%? Do you have any trim or sub trim in your throttle channel? Lots of little stuff, but nothing that cannot be corrected. Let us know if you cannot find the solution.
Tahoe Ed is online now Find More Posts by Tahoe Ed
Site Sponsor
Latest blog entry: How to reload P3 firmware
Old Jan 01, 2012, 07:44 PM
jforkner is offline
jforkner's Avatar
Copperopolis, CA
Joined Sep 2003
Yeah, I couldn't figure out how to back-peddle either. I posted the problem on another multicopter forum, too. Maybe DJI will be monitoring. Hopefully it's a simple fix.
Jack
Old Jan 01, 2012, 07:46 PM
DJI Support
Tahoe Ed's Avatar
Joined Feb 2010
Jack
Jack when you upgrade the software, you need to reset your Assistant settings. I click on default, enter in the prior settings and then write. That includes recalibrating your transmitter and mode switch. I hope this works for you.
Site Sponsor
Old Jan 01, 2012, 07:48 PM
Dolby is offline
Find More Posts by Dolby
Needs more bacon!
Dolby's Avatar
United States, WI, Milwaukee
Joined Jan 2011
My Naza works fine on 1.02. I did notice that after the upgrades the throttle channel was reversed so it wouldn't let me arm the ESC's because it was protecting since the throttle is high.
Did you check your throttle channel in the software? Maybe also re-run the tx calibration with the software?
Dolby is offline Find More Posts by Dolby
Old Jan 01, 2012, 07:52 PM
brianshell's Avatar
Joined Nov 2011
http://www.rcgroups.com/forums/showthread.php?t=1536553\
Thanks!! I read that thread tirelessly before purchasing the RTF kit. Couldn't be more excited about the purchase afterwards. =)
This is good news. I'll keep trying.
This problem is about 10 hours of "trying" old now. I'm a network engineer by trade and a ham radio operator, and I've got lots of experience with RC airplanes... So while I'm a total newb when it comes to quads, the related concepts here are pretty comfortable.
The manual for the Naza indicates ESC calibration is only required if I'm using third-party ESCs. This is the RTF Kit for the Flame Wheel 450. However, I guess it wouldn't hurt to go through this process anyway.
Yes.
No.
I'll keep digging I guess.
Old Jan 01, 2012, 07:54 PM
brianshell's Avatar
Joined Nov 2011
Throttle channel is moving from left-to-right as I increase the throttle. I've also tried reversing it.
I've done the TX calibration no less than 20 times now. =)
Thanks for the comments!!
Old Jan 01, 2012, 07:59 PM
brianshell's Avatar
Joined Nov 2011
It looks like this person was having the exact same problem, although he was using third-party ESCs. Ultimately, his solution ended up being to power on the ESCs a few seconds before powering on the Naza.
http://www.rcgroups.com/forums/showthread.php?t=1562668
Ultimately, I would hope that's not required here, since these are the matching ESCs.
Old Jan 01, 2012, 08:07 PM
DJI Support
Tahoe Ed's Avatar
Joined Feb 2010
I did the esc calibration even with the OPTO esc's on the Naza Kit. The calibration beeps were not like doing a Turnigy and I eventually just waited about 1-2 sec and lowered the throttle. I got a confirming beep so I assume it worked.
Another question, when you power the Naza with the transmitter on while not connected to the computer, what is the led doing? Are you getting rapid yellow/orange flashes, intermittent yellow/orange flashes or no flashes? If you are getting rapid yellow/orange flashes, it indicates that you are in failsafe and you cannot arm.
Site Sponsor
Found Delete there is nothing for sale here.. Quad_Addict Aircraft - Electric - Multirotor (FS/W) 15 Jan 03, 2012 04:28 PM
Sold DJI F450 Flame Wheel White/Black NEW SEALED $70 Shipped Priority 2-3 Day Mail Z06 Tony Aircraft - Electric - Multirotor (FS/W) 6 Jan 01, 2012 02:04 PM
Sold DJI Flame Wheel F450 White/Black frame x2 timecop Aircraft - Electric - Multirotor (FS/W) 5 Dec 13, 2011 09:50 PM
Discussion Wookong-M + Flame wheel 450 nest Multirotor Talk 3 Nov 10, 2011 11:48 PM
Help! Align T-rex 450 SE V2: Why won't you start?! dylantorquerol Mini Helis 2 Apr 19, 2011 11:24 PM
