Old Oct 04, 2003, 04:26 PM
sheerLuck is offline
Find More Posts by sheerLuck
Crash Site Instigator
sheerLuck's Avatar
Novato, CA USA
Joined Jan 2002
GWS PT-17 late bird maiden
I may be the last of the early birds to get their PT17 operational. It's stock except for the oversize wheels. Using 2S2P ETec 1200's. Had a great time with it this morning. Made 2 flights. Loops like crazy. Outside loops just barely make it to the top. Rolls without any problem, but my rolls looked like a drunken seagull - kind of a corkscrew. I set my throws to maximum for everything - ailerons demo'd below.
Need to finish the decals & trim it out. Batteries are all the way forward, but still seems tail heavy. My first biplane, and I think I have a new favorite flyer.
Larry
sheerLuck is offline Find More Posts by sheerLuck
Old Oct 04, 2003, 04:27 PM
sheerLuck's Avatar
Novato, CA USA
Joined Jan 2002
Another pic ...
sheerLuck's Avatar
Novato, CA USA
Joined Jan 2002
Last one for now....
Old Oct 04, 2003, 07:29 PM
Mindblade is offline
Find More Posts by Mindblade
Where's the CA?
Mindblade's Avatar
Long Island, NY
Joined Sep 2003
Nice job. Any chance of getting some video?
Mindblade is offline Find More Posts by Mindblade
Old Oct 05, 2003, 05:51 AM
imeins is offline
Find More Posts by imeins
imeins's Avatar
Australia
Joined Nov 2002
Very nice! I had not epoxied in my U/C and so I flew a bit without today and yesterday. I needed to add about 55g of ballast to the nose to get the cg just a bit nose heavy, that's with etech 2s1p. Seems to fly forever on those. I think it's my current favourite too. Also good to hear that someone else is doing wild cork screw rolls, I thought it was just me.
This is a pic of the legless bird today.
Ingmar
imeins is offline Find More Posts by imeins
Old Oct 05, 2003, 03:44 PM
LcJ is offline
LcJ
Find More Posts by LcJ
LcJ
Forever TMWT Pilot #11
LcJ's Avatar
United States, LA, Monroe
Joined Mar 2003
Ingmar,
I figured out something from your pictures and your post. Mine would not fly. It would go out and if you turned left it would tip stall right in. I must have tried everything I could think of and no luck. I even tried rudder only.
After studying your pictures, I noticed the uniform circular bend on you wing to fuselage struts. I had built mine with 1/16 balsa on each side and they were straight and removed any dihedral (which there is a little) in the top wing. I just finished removing the balsa and cleaning off the glue. Now mine have the needed flex and it flew great.
Thank you for posting the pictures.
Peace,
LcJ
LcJ is offline Find More Posts by LcJ
Latest blog entry: RC Logger's Eye One Xtreme Quad
Old Oct 05, 2003, 07:57 PM
GWS4CEO is offline
Find More Posts by GWS4CEO
Houng-wen Lin
GWS4CEO's Avatar
Shijr, Taiwan. DungGwan, China. City of Industry, California.
Joined Sep 2001
Dear LcJ, pls check the thrust line! You must to have a 2 degree off-set to the right to balance the torque from the prop.
GWS4CEO is offline Find More Posts by GWS4CEO
Old Oct 05, 2003, 10:50 PM
LcJ is offline
LcJ
LcJ
LcJ's Avatar
Joined Mar 2003
Mr. Lin, it was not the thrust line, that was always correct. It was the fact that having stiffened the inner struts, the top wing was forced into being either totally flat or with an slight bend down from the middle. Whatever the case, once I removed the balsa from the innder struts, it turned into the plane it was supposed to be. I did send you an e-mail rather that place my experience on this forum without a solution. That solution was provided by Ingmar's pictures.
You do have a nice plane design, and the problem was all mine. You never assume anything, and I assumed I could do the same thing with all the struts that I did with the Tigermoth. That was my mistake.
Peace,
LcJ
GWS PT-17 Maiden LuftAdler70 Parkflyers 19 Dec 04, 2004 09:49 PM
GWS PT-17 Stearman maiden jbird Parkflyers 41 May 08, 2004 12:33 AM
Question GWS PT-17: ready to maiden? jbird Parkflyers 4 Apr 22, 2004 10:31 PM
GWS PT-17 ships Sep 12th to Early Birds sheerLuck GWS (Grand Wing Servo) 76 Sep 28, 2003 09:10 PM
Gws Pt-17 JDMstuff Electric Plane Talk 1 Aug 23, 2003 03:33 PM
