Old Jan 01, 2012, 04:40 PM
elossam is offline
Find More Posts by elossam
Joined Feb 2006
Brushless eficiency. DJI, Herkules esc, Droidworx CX4 and Axi 2217/2
Hi friends.
I made today several flying test with ghe following equipment. DJI wokong, droidworx CX4, herkules II esc, 4s 3300 bat, 4 axi 2217/20 engines and three different airscrews that reported the following numbers:
Graupner 10x5 : 18.5 A/h 9 min. Flying time. 45°c temperature inside the engines.
Graupner 11x5: 17.5 A/h 9.5 min Flying time. 38°c temperature inside the engines.
APC 12x3.8: 15 A/h 11 min Flying time. 60°c temperature inside the engines.
Al flights where done at outdors temp of about 10°c and hovering all the time. The setting in the esc includes a 24 degree timming as recomended by AXI for this engines.
The question are:
1) Why a lower total amp. consumption whith the APC generates higher engine temperature?
2) A friends exactly equal equipment and settings with the graupner 10x5 but a different brand of flying board instead of DJI gets the same numbers but absolutely zero increase of engine temperature over the outdoors temperature. Is the DJI specially agressive with the engines may be due to a faster comunication of variations to the engines? Have heard something so related to MK with the last firm but refered to the esc temperatures. Any idea?
elossam is offline Find More Posts by elossam
Old Jan 01, 2012, 05:40 PM
JanHenning is offline
Find More Posts by JanHenning
JanHenning's Avatar
Norge, Vestfold, Tønsberg
Joined Apr 2010
I'm using these motors a lot, and they run relatively cool on my MK/4S setup with 11x4.7 SF.
I think your low amp/high temp observation is interesting. My guess is that the 12x3.8 propeller is more efficient than the others you tested, and that this increase in propeller efficiency is more signifficant than the loss you see as higher motor temp. When that is said, I think 12x3.8 might be a little too much for the 2217/20, and especially if you are going to add payload to the craft.
JanHenning is offline Find More Posts by JanHenning
Old Jan 01, 2012, 06:32 PM
power is offline
Find More Posts by power
Begin with end in mind...
power's Avatar
Eagle Lake, Minnesota
Joined Apr 2003
I agree, the 12-3.8's for payload application is a bit over the top for the 2217-20's I don't have an MK setup but I run the AXI 2217-20's on 3s with my 3.5 lb tricopter spinning the APC 10-3.8SF and the motors come down pretty much cold. I started with the 11-4.7SF prop but I like the way the 10-3.8SF matches my disc loading, it just responds better. Great motors
power is offline Find More Posts by power
Old Jan 02, 2012, 03:54 AM
elossam is offline
Joined Feb 2006
That has sense, may be the way to go, as I want to add payload, is to lower the timming from 24 to 12 in order to accomodate it to the new weight and common rpm use (a non acrobatic UFO few times run at full power or full rpm).
Jan, can you tell me the weigh and rotor numbers of your ufo as well as an aproximate value of the engines temperature after a long hovering?
Old Jan 02, 2012, 04:24 AM
JanHenning's Avatar
Joined Apr 2010
The weight of the craft included payload is 3100 grams, and it has 6 motors in a Y6 configuration. I have never measured, since they are really never that warm, but my guess is 10-20 degrees above ambient temperature.
Old Jan 07, 2012, 08:12 AM
clie-easystar is offline
Find More Posts by clie-easystar
limburg Netherlands
Joined Aug 2004
payload
Originally Posted by elossam View Post
Hi friends.
The question are:
Nice setup!! what is the total weight and how many payload is acceptebel.
Can you place a photo about the connection between the DJI and Herkules?
clie-easystar is offline Find More Posts by clie-easystar
Wanted AXI Gold 2217-16 Outrunner Motor earp Aircraft - Electric - Power Systems (FS/W) 0 Oct 19, 2011 07:47 PM
Discussion The best ESC for AXI 2217/20 babanan Multirotor Talk 2 Aug 05, 2011 10:43 AM
Wanted Axi 2217-12 Brushless motor Wolfman Aircraft - Electric - Power Systems (FS/W) 0 Mar 21, 2007 07:54 PM
Sold For Sale AXI 2217/16 Brushless outrunner Gold series snoshoe62 Aircraft - Electric - Power Systems (FS/W) 2 Mar 15, 2007 12:16 AM
Discussion help me choose between axi 2217/16 and 2217/20 noobee Power Systems 15 Jan 02, 2007 08:51 AM
