Old Jan 01, 2012, 03:51 PM
flynfunny is offline
Find More Posts by flynfunny
Joined Jan 2009
Foam cutter set-up?!?!?! 3xQ's
I figured i would post this in the scratchbuilt thread since most of you have hot wire foam cutters.
1. Do I need a fuse? If so then just an inline fuse with a 10-15a glass fuse?
2. Do I have this hooked up wrong on the wire cutting end?(seems to work but makes a humming noise).
3. Is it ok to cap the black wire in the middle of the yellow ones? Does this wire do anything specific?
Pretty much I want to stay safe and not fry anything.
flynfunny is offline Find More Posts by flynfunny
Old Jan 01, 2012, 04:53 PM
Joined Jan 2009
Bumpy Bumperson
Old Jan 01, 2012, 06:31 PM
TFM70 is offline
Find More Posts by TFM70
USA, GA, Carrollton
I'll take a shot at it. I would put the fuse ahead of the dimmer.
Its ok to tape up the middle lead. Its a center tap on the secondary of the transformer.
TFM70 is offline Find More Posts by TFM70
Old Jan 01, 2012, 08:36 PM
blvdbuzzard is offline
Find More Posts by blvdbuzzard
The high desert of Southern California
Joined Jul 2002
I did not put a fuse in my setup. So far I have not let the magic smoke out of anything.
Buzz.
blvdbuzzard is offline Find More Posts by blvdbuzzard
Old Jan 01, 2012, 10:24 PM
jonesymj is offline
Find More Posts by jonesymj
Slopeosapien
jonesymj's Avatar
Joined Jun 2006
I didn't fuse mine either... Worked just fine wired up the way you've illustrated though... My hot-wire setup will hum when it's set pretty much right so I don't think it's an issue...
jonesymj is offline Find More Posts by jonesymj
Old Jan 01, 2012, 11:27 PM
Joined Jan 2009
I'm using a 16 gauge guitar wire. seems pretty slow for cutting but its an 19" cutting space.I love this thing!!!! All I have is 2' thick green foam from Lowe's.
Discussion Trainer with gyro's help with set up jonathan7x70 Electric Plane Talk 6 Dec 13, 2011 11:32 PM
Cool Controlling Gorilla white's foam up! UlteriorModem The Builders Workshop 8 Oct 06, 2011 01:07 PM
Help! Gravity Cutter need help with set-up Mr. Combat Certain Slope 87 Aug 17, 2010 06:57 AM
Wanted Hotwire foam cutter set up Concordefan Aircraft - General - Miscellaneous (FS/W) 6 Sep 20, 2008 08:20 AM
Foam Cutter Help...wiring it up FOShowNoClass Electric Ducted Fan Jet Talk 6 Feb 23, 2003 10:17 PM
