Old Jan 01, 2012, 02:12 PM
schusterjo is offline
Find More Posts by schusterjo
United States, IN, Lebanon
Joined Oct 2011
Need help getting all the correct tools (links,basic hand tools to basic power tools)
I am going to start building balsa scratch built planes (from plans) as well doing my own repairs. What tools do I need? Balsa is so thin an easy to break like wing spars, how do you cut hem without snapping, chipping or cracking the balsa?
45 degree cuts? what tools needed? (also could use this method on foam)
Links to the suggested tools would be great.
Any help is appreciated..
Jo
schusterjo is offline Find More Posts by schusterjo
Old Jan 01, 2012, 02:38 PM
eflightray is online now
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
If you go back to The Builders Workshop main page, click on Search this Forum, type tools in the search box, set Show Threads to search only thread titles, then click Go.
There are a quite a few threads that have asked the same question, with plenty of replies on all sorts of tools and material types.
The basic ones I use are a scalpel knife, (get plenty of blades), a razor saw, (though a junior hacksaw will do), a range of sandpaper, (coarse to fine), some pins, and that should get you started.
Then there are threads on workbenches, power tools, right up to CNC machining tools. But considering many of us 'oldies' used a single sided razor blade and 'balsa cement', power tools can be a bit of an overkill for a beginner
eflightray is online now Find More Posts by eflightray
Old Jan 01, 2012, 03:12 PM
Joined Oct 2011
Thanks... it gives me a place to start
Old Jan 01, 2012, 03:53 PM
Joined Oct 2011
Well Kinda looked a little an seems spread out a little here a little there..
Really would like power tools but of coarse no cnc machine.. more along the lines of the perfect dremel setup... But need the basic tools as well
So, if anyone has a little time on their hands i appreciate the effort to post links here to the tools needed to get a decent shop going. From the basic hand tools to the basic power tool setup...
Have to get back to work an will have little time to research this for several weeks is why i am asking... thanks.
Old Jan 01, 2012, 04:39 PM
cracksmeup is offline
Find More Posts by cracksmeup
cracksmeup's Avatar
United States, IL, Joliet
Joined Jun 2009
http://www3.towerhobbies.com/cgi-bin...?&I=LXAA64&P=M Master airscrew razor planer. Stripper for making your own sticks http://www3.towerhobbies.com/cgi-bin...?&I=LXAA63&P=7 These two tools will be used the most in scratch building .Ad some sanding tools small balsa saws and exacto nifes and it good to go. I have a all the power tools but i dont use them that much. I have permagrit sanders and they work great also. joe
cracksmeup is offline Find More Posts by cracksmeup
Old Jan 02, 2012, 06:41 AM
Joined Oct 2011
Great! this is the kinda stuff i need to know about..
is there a tool just for cutting spars?
how about a tool that will contour the front of the wing for sanding? (like in a repair an your trying to match the original curve)
what about a tool that will cut 45 degree angles on very long strips? (power is ok here)
how about a tool or jig that will keep your spars (or whatever) at 90 degree or adjustable to other degrees?
I have a exacto knife kit so i am good there.
Ya, i know im kinda lazy in doing research myself but for next several weeks i only have like 1 hour a day to spare an i still have to eat an shower in that hour...
Thanks for your help
Jo
Old Jan 02, 2012, 07:08 AM
cracksmeup's Avatar
Joined Jun 2009
You can buy sanding tools to put slots in ribs for spars , The balsa stripper i gave you a link for is what i use for making spars . .http://www.bvmjets.com/Pages/Catalog/permprices.htm I use my razor plane to rough shape my leading wing edges then finish sand them. Angle cutters and sanders for balsa sticks is a formost cutter or sander you can find both here. joe http://www.hobbylinc.com/htm/for/for...source=froogle Tools will help you scratch build but if you dont get plans and learn how to cut things out with simple tools and stick with it all the tools in the world wont help you to finish a plane. Good luck ,joe
Old Jan 02, 2012, 09:08 AM
Joined Oct 2011
Yes, i plan on getting plans... I have a few wings laying around i like to repair the correct way as well.
The correct tools is the first step for me..
Old Jan 02, 2012, 10:05 AM
Joined Oct 2011
LXL494 Hobbico Steel T-Pins 1" (100)
LXLH64 Zona Mini Hack Saw
LXM406 House of Balsa Upright 90 Degree Alignment Jig
LXAA63 Master Airscrew Balsa Stripper
LXAA64 Master Airscrew Razor Plane
LXAA65 Master Airscrew Razor Plane Blades (3)
LXG872 Fourmost Gapless Hinge Slotter
L5K26202 Great Planes Precision Hinge Marking Tool
LXBJU0 Midwest Hobby/Craft Square
LXJC83 Tower Hobbies #11 Blades (5)
This is what I have on my list so far... if you can think of anything else please add to the list... I am really interested in a dremel type setup with the router table ext.. as well.. if you know of any items that can make the job closer to perfect an easier to use let me know..
Jo
Old Jan 02, 2012, 10:34 AM
ltc is offline
ltc
Find More Posts by ltc
ltc
AMA 97737
ltc's Avatar
United States, MA, Mendon
Joined Mar 2010
I prefer these to T pins...
http://www.hobby-lobby.com/pins.htm
These are also better than the similar pins from Midwest, which can have a tendency to seperate.
I also like this hinge slotter
http://www.hobbylinc.com/htm/hig/highin001.htm
ltc is offline Find More Posts by ltc
Old Jan 02, 2012, 03:15 PM
cracksmeup's Avatar
Joined Jun 2009
Those are the pins i like also . I slot my own hinges with a exacto knife but i might try one of thos . joe
Old Jan 03, 2012, 06:10 AM
TomCrump is offline
Find More Posts by TomCrump
ARFs Are Me
TomCrump's Avatar
Traverse City, Michigan
Joined Dec 2005
Jo
I've been building since the 50's, and you have tools listed that I don't have, and do not see a need for.
In my opinion, you are going about this in the wrong way. I suggest that you build a flat building board, and purchase a few essential tools (razor knife, saw, pins, etc). Then as you go along, buy the correct tool for the job, as it comes up.
It's impossible to have every tool on hand, when you are just getting started. How would you know what you need, until you need it ?
Take your time. If you do, you'll acquire a tool set that will serve you well. Get in a hurry, and you may spend money on tools that you will never use.
The suggestions made above, are useful to the posters, for the models that they build. Different model types, require different tools. Are you going to build models like theirs ?
For instance. I could not complete a model without using my 60 gallon, 6 horse compressor, and HVLP spray gun. Does that mean that YOU need one ? I doubt it. I have 2 drill presses, a band saw, and a table mounted belt sander. These are all used in all my builds. I don't think that anyone else has mentioned them.
My point is that each builder develops his own, personal, set of tools.
I suggest that you do the same. When you have questions about specific tools, we can make suggestions, then.
TomCrump is offline Find More Posts by TomCrump
Old Jan 03, 2012, 07:21 AM
Joined Oct 2011
Ok good point...
Old Jan 03, 2012, 07:49 AM
Hemikiller is offline
Find More Posts by Hemikiller
-insert witty saying here-
Hemikiller's Avatar
United States, CT, Killingworth
Joined Dec 2005
I agree with Tom, you're going to develop your own tool set in time. The items you have listed are those that I use as well, but with a few differences...
Get the Zona 3 in 1 saw kit, not the hack saw. I use this all the time.
http://www3.towerhobbies.com/cgi-bin...?&I=LXLH56&P=7
Buy good #11 blades, not cheapies from Tower or Hobbico. Xacto makes their top of the line X-life blades in a 100 pack, which will last you for several years, for about $25. I use this dispenser and then reload when empty...
http://www3.towerhobbies.com/cgi-bin...&I=LXKY49&P=ML
Hemikiller is offline Find More Posts by Hemikiller
Old Jan 03, 2012, 07:54 AM
cracksmeup's Avatar
Joined Jun 2009
I own a scroll saw and sander, drill press, band saw but in 30 years i have only used the band saw and scroll saw for cutting out ply parts or hard woods. Iam a master carpenter so i own all the big stuff.My main tools for building are a razer plane small balsa saw exacto knife balsa stripper and sanding tools. and thats it.I dont see how any one can build with out at least thos basic tools. joe
Discussion Need Help getting my Turbine waiver! jetfan20 Fuel Jet Talk 26 Jul 21, 2012 11:42 PM
Discussion Got my new plane! Getting ready for maiden, question about cg, need help please. cfiiman Electric Plane Talk 5 Jun 07, 2011 11:10 AM
Help! Need Help and guide in getting a contour shape / Round shape of fuselage Skyline00 Foamies (Scratchbuilt) 4 Jun 02, 2011 10:11 PM
Discussion need some help out getting info madmikeyreturns Indoor Pattern/F3P 3 May 31, 2011 10:34 PM
Help! PLEASE HELP me locate the correct retracts that I need for my NEW paatern plane! mechengineer03 Classic Pattern Flying 3 Apr 06, 2011 04:10 PM
