Mar 12, 2012, 07:29 AM
United States, VA, Woodbridge
Joined Aug 2011
Drilling out the hole, if need be, isn't a big issue. I had to do that as well when I put on the metal clevis. Now my plane didn't initially come with a metal clevis. I chose to swap out the included plastic one plus they instructions had me to use a set screw connector for the throttle arm which was a total PITA to tighten up because of the location of the arm with the inside of the engine compartment. Maybe it's different on your LA as opposed to my AX? Anywho, I digress.
The metal clevis doesn't really over-close like a plastic one can, or at least mine didn't or I didn't force it, but whatever the situation you shouldn't need to pinch it so tight that it restricts movement. Using a bit of fuel tubing will help keep the clevis from opening. Now, I did have to be careful not to slide the tubing too far forward on the clevis because that would've inhibited the throttle arm movement.
Fun stuff, huh?
-bill
