Old Jan 29, 2012, 11:59 PM
tsymonds is online now
Find More Posts by tsymonds
Snappy Title On Backorder....
tsymonds's Avatar
United States, TX, Killeen
Joined Jun 2011
I've got an X4 mounted in a case with a Maxamps 47amp power supply and it's my favorite setup for the ~2200mah packs everyone including myself seems to have a pile of. I bought the setup shortly before the AC/DC version came out but I've run the heck out of it. Can't go wrong with either version IMHO. My setup was $159 for the charger and another $80 for the PS. The only issue I've run into is charging bigger packs. I use 5000mah 3s packs in one of my planes but only 50w per channel the best it'll do is 4.4amps which is less than 1c so they take a long time to charge. I just bought a pair of the X2 chargers to take care of that.
tsymonds is online now Find More Posts by tsymonds
Old Jan 30, 2012, 02:36 AM
o2begrn is offline
Find More Posts by o2begrn
Welcome to the Wind
o2begrn's Avatar
United States, CA, San Jose
well after having the charger all day today i just placed a order for one at advantage hobby and got it for $201.00 great charger works like 4 chargers in one and i like it...the other one clone the Q6 AC/DC i found for 200.00 but i rather get the hitec on as it comes with a 1yr warranty from hitec and they do have a great customer service dept ,,the Q6 AC/DC is 30 day warranty
o2begrn is offline Find More Posts by o2begrn
Old Jan 30, 2012, 06:36 AM
pmacko is offline
Find More Posts by pmacko
Go 4th Air Force
pmacko's Avatar
United States, PA, Washington
Joined Sep 2011
Originally Posted by bcovish View Post
What are your questions?
The biggest questions I had were around connecting the batteries I have to the charger and then around a power supply I have
I have several examples of this battery and this battery. Can I plug the balancing leads directly into the Hitec charger? If not, do I need extra copies of the adapters they supply with it? if so, which one?
The second question was whether this power supply would be ok to use.
pmacko is offline Find More Posts by pmacko
Old Jan 30, 2012, 06:41 AM
RC Accessory is offline
Find More Posts by RC Accessory
United States, FL, Tampa
Joined Jan 2004
Depends where you buy it. We offer a full 1 year warranty on all the Vista Power chargers.
RC Accessory, Inc
Auth US Bantam Charger Importer & Service Center
Auth US Vista Power Charger Importer
RC Accessory is offline Find More Posts by RC Accessory
Site Sponsor
Old Jan 30, 2012, 09:08 AM
bcovish is offline
Find More Posts by bcovish
bcovish's Avatar
Austin TX
Joined Jun 2008
Both the batteries you link to will plug directly into the balance of the X4
bcovish is offline Find More Posts by bcovish
Old Jan 30, 2012, 09:31 AM
o2begrn is offline
Welcome to the Wind
o2begrn's Avatar
well there you go both have the same warranty good to know
RC Accessory, Inc
Old Feb 26, 2012, 12:15 PM
D_FAST is offline
Find More Posts by D_FAST
D_FAST's Avatar
Denver CO
Joined Apr 2008
I purchased one of these chargers at the LHS $219.00, it smoked in less then 2 minutes of charging a single 2s battery.
It was exchanged no problem at the same LHS.
Now 36 days have passed and while chargeing a pair of 3s an open port that had nothing hooked up to it beeps out "Reverse Polarity"
Ummm,Nothings connected to it??
I shut it all down, fire it back up, "Reverse Polarity" pops out!
Now i own a Hitec 3X Ac Plus instead of 4x. Now they want me to ship it to them at my own cost.
Long story short,
!!!Dont buy this charger!!!
D_FAST is offline Find More Posts by D_FAST
Old Apr 14, 2012, 09:45 AM
rpm3 is offline
Find More Posts by rpm3
rpm3's Avatar
Pleasanton, California
Joined Nov 2000
Sorry to hear about you bad experience....I've had it a week now...probably charged and balanced 20 packs..
for me....
This charger works like a charm....every thing i need....i do NOT like the programming....but as time goes on...it probably will make more sense...for now....
I'm a real happy camper!
Ralph Matile
rpm3 is offline Find More Posts by rpm3
Old Apr 15, 2012, 09:36 PM
rpm3 is offline
rpm3's Avatar
Joined Nov 2000
I have used the charger to balance packs and did 4 at a time...WOW..this works like a dream...also...I have all my packs in "storage" mode....and i didn't realize i had so many....
I do have some without balancing plugs.....and a few 3 cell tanic packs that i should make a connector for.... anyone have any instructions on that?...i can probably figure it out if need be...
again..so far...this charger has been working like a charm...and if it continues...I'd highly recommend it for someone who has packs 3 cell, 2500mah and smaller...
Thats all I have for the most part...so this is sure hitting the "sweet spot" for me!
Ralph Matile
Old Apr 22, 2012, 09:58 PM
rpm3 is offline
rpm3's Avatar
Joined Nov 2000
I continue to have good luck with this charger....my only challenge at the moment is to pair the balance plug with a few of the older batteries i have....
I can highly recommend this charger...its my first balancing charger...and to be able to charge AND charge to storage level is fantastic....
Ralph Matile
Old Apr 23, 2012, 02:53 PM
roibmw is offline
Find More Posts by roibmw
Doug
New Hampshire
Joined May 2008
thanks for your post's ralph. i've been looking to upgrade too and i think the X4 is what i need. i may go to the X4 eighty due to the larger wattage capacity. glad you started this conversation. it helped me a lot.
roibmw is offline Find More Posts by roibmw
Old May 17, 2012, 09:32 PM
rpm3 is offline
rpm3's Avatar
Joined Nov 2000
Glad the posts help....
I continue to have good luck with my charger Hitec X4 AC ....i still get messed up a bit on the programming....but i used to have to balance each cell before I charged a pack.....and NEVER left them at the right voltage for longer term storage....now....i literally have saved hours in the charging process.....
Have a great day!
Ralph Matile
Old Jun 03, 2012, 05:27 PM
rotagen is offline
Find More Posts by rotagen
Scratch building addict
rotagen's Avatar
United States, CA, Felton
Joined Jan 2005
Well looking at the chasis and layout it looks exactly like the thunder 4-port charger which I completely wasted my money on. These button "pads" are very trouble-prone. Mine lasted about 6 weeks, of course past the return period on the vendor, and thunder did NOTHING to help me. Hitec is of course a better name but I would strictly advice against purchasing this charger.
rotagen is offline Find More Posts by rotagen
Old Jun 03, 2012, 07:44 PM
rpm3 is offline
rpm3's Avatar
Joined Nov 2000
Well Rotogen....
My tastes in chargers may not be as sophisticated as yours...because i skipped a couple of charger types with this purchase.....its my first charger that balances.and also charges in a storage state...4 packs at a time!!....so this by far for me is great..i may not be giving it the workout you do either...but so far....its does everything i need..and does it well....
I will watch it closely for the issues you have surfaced....
thanks
Ralph Matile
Old Jun 03, 2012, 10:44 PM
PMDRACER is offline
Find More Posts by PMDRACER
SoCal, California
Joined Feb 2009
FWIW, I've had this charger for ~6 months and I absolutely love it! I use it for my 2S 4000/5000mAh LiPos.
PMDRACER is offline Find More Posts by PMDRACER
Discussion HiTec X4-AC charger PMDRACER Electric Power Cars 4 Oct 26, 2011 06:50 PM
New Product BRAND NEW! Hitec X4 AC Plus Charger - in stock at ServoCity! ServoCity ServoCity.com 0 Oct 19, 2011 09:48 AM
New Product Brand New Hitec X1 AC Plus Multi-Charger : In Stock at ServoCity!! ServoCity ServoCity.com 0 Aug 23, 2011 11:48 AM
Discussion ac/dc multi-chemistry multiple charger? JeffinTD Batteries and Chargers 6 Jul 03, 2011 07:56 PM
For Sale HCAP0150 Hobbico 905 AC/DC Multi-Charger stretch1100 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Jun 19, 2011 05:11 PM
