Old Dec 31, 2011, 09:21 PM
scorpion1 is offline
Find More Posts by scorpion1
I feel the need for speed!
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Turnigy motors
These are a few of the motors i got my free go-cart for buying.
These are very nice, strong cogging, well built and 4 pole..............not to mention a real cool feel to the can surface. The 3665 is going in a Truck, but i may use the 3674 in a boat on 6s. Although the 3665 2100kv could be a very good candidate for 26-32" boats on 4s...........
Getting ready to solder 5.5 bullets on each..............
scorpion1 is offline Find More Posts by scorpion1
Old Dec 31, 2011, 10:23 PM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Just got in from running the 3665 in my extended wheelbase Emaxx after adding 5.5 bullets...............wheelies with ease and has some brutal acceleration on 2 x 2s 5800 40c batts. I think these 4 pole 36mm motors will really catch on, i'm estimating about a 20-25% power increase over a same size 2 pole motor with more low end power.........very nice for $40.
Ran it in this truck:
Old Jan 02, 2012, 12:17 AM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Vid of the 3665 4 poler.......................very strong motor, it sure moves out this heavy Emaxx on 4s..............
These 36mm motors are gonna be makin' some noise in boats is my guess............... This 3665 2100kv would be great in 26-32" hulls..................
Emaxx Tundra with Turnigy 4 pole 3665 (1 min 25 sec)
Old Jan 02, 2012, 01:35 PM
pompebled is online now
Find More Posts by pompebled
Boaters are nice people.
Sneek, Netherlands.
Joined May 2004
Hi Scorp,
After seeing the video, I'm convinced those motors have torque, but, how much runtime should I expect with this 3665 2100KV on 4S in my Arowana, turning a 42K prop (at least...)?
Regards, Jan.
pompebled is online now Find More Posts by pompebled
Old Jan 02, 2012, 03:22 PM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Originally Posted by pompebled View Post
Hi Scorp,
Regards, Jan.
I'm sure the efficiency level is higher than a comparable 2 poler, my guess would be 15-20% longer runtime. On 5000 40c batts it should give in the 5-6 minute range minimum. I'd sure recommend it for the arrowana, and for 40 bucks its a real deal.
I bet the 42mm you suggested would be real good for it.
Old Jan 02, 2012, 05:06 PM
F1 madness is offline
Find More Posts by F1 madness
F1 madness's Avatar
Staffs UK
Joined Feb 2010
Hi jan
i run leopard 3674,2200kv on 4s in my 25" rocket on x442,2x2s inseries 5000mah,30c, heres the the time got over 6mins,infact nearly 7mins and temps werent even warm so a bigger prop was easy just not big enough pool LOL
HOR rocket 2nd outting (6 min 48 sec)
Cool vid scorp shows how much torque they have,im really liking the 4 pole motors at mo
F1 madness is offline Find More Posts by F1 madness
Old Jan 03, 2012, 06:00 AM
SARCFAN is offline
Find More Posts by SARCFAN
Joined Dec 2010
What is the min amount to spend to get a free gift? I bought there a few days ago but did not even got heat shrink as a gift
SARCFAN is offline Find More Posts by SARCFAN
Old Jan 04, 2012, 07:48 AM
mike__ is offline
Find More Posts by mike__
Perth, Western Australia
Scorp: im running a turnigy 4074 2000kv / 4s / aquastar120a in my 32" arowana. Impressive motor and runs warm at most.
Jan: With a graupner 45k run time is ~4min 30+. From memory 2 weeks ago pack voltage was 7.65ish v on the charger. I put back roughly 70% into each 2s lipo. With a 48k prop i was putting back the same mah after ~3min 30. The speed was only +1km/hr more @ 65km/hr with the 48k but the initial acceleration was impressive. Just recieved some graupner 42mm 3 blades to try after a minor mix up but unfortunately on the w/e my 4mm shaft snapped at the end of the stinger after i got caught in weed trying to rescue my cousins boat. New stainless shaft on the way, hopefully in time for the w.e. Will post results & hopefully a video in the arowana thread. The shaft snapped before my graupner 'flex drive' adaptor. go figure......
mike__ is offline Find More Posts by mike__
Old Jan 04, 2012, 08:17 AM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Cant figure it out.................i tried puttin different $$ stuff in my cart just to get it to do it again, i got a motor to come up once too. It may be on certain items, or it may be random................
Old Feb 02, 2012, 09:05 AM
yellowrocket is offline
Find More Posts by yellowrocket
Joined Aug 2011
look im stuck picking what motor will be best for my 25'' rocket the 2600kv gold can or an 8xl im am looking for speed
yellowrocket is offline Find More Posts by yellowrocket
Old Feb 02, 2012, 09:27 AM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Are you referring to the 2600kv 3656 Turnigy.........if so it's a decent motor and would get a 25" boat going fast on 3s.
It would be a rocket with this one on 4s............
http://www.hobbyking.com/hobbyking/s..._Inrunner.html
Old Feb 02, 2012, 01:30 PM
hotrodder is offline
Find More Posts by hotrodder
hotrodder's Avatar
United States, CT, Manchester
Joined Jan 2007
Scorp you gotta put some better shock springs or just go a little heavier on the shock oil, to much bouncing..
hotrodder is offline Find More Posts by hotrodder
Old Feb 02, 2012, 01:33 PM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
It already has xtra firm spring, much stiffer than stock, i like some travel and ability to absorb bumps, heck, it may be bouncy cuz they are too firm.
Old Feb 07, 2012, 07:31 AM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Bouncy means the oil is too thin (or too many holes in the pistons) for the spring rate being used.
Scorp, I just bought one of these motors' little brother for my mini revo build. I went with the 2850-4400kv, should be pretty nuts on 3s!
wparsons is offline Find More Posts by wparsons
Old Feb 28, 2012, 12:50 AM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
That thing will be insane!!! Need vid for sure..............
Discussion Has anyone used the Turnigy XK28xx motors? heli3d Electric Ducted Fan Jet Talk 18 Oct 25, 2011 08:17 PM
Sold Scorpion SII-2215-900KV (V2) Motors and Turnigy ESC`s tdmaros FPV Equipment (FS/W) 1 Oct 03, 2011 11:36 PM
Sold Scorpion SII-2215-900KV (V2) Motors and Turnigy ESC`s tdmaros Aircraft - Electric - Multirotor (FS/W) 0 Sep 15, 2011 11:18 AM
Sold Scorpion SII-2215-900KV (V2) Motors and Turnigy ESC`s tdmaros Aircraft - Electric - Power Systems (FS/W) 1 Sep 14, 2011 08:25 AM
Sold Motors And Esc's Motors And Esc's E-flite And Turnigy java8297 Aircraft - Electric - Power Systems (FS/W) 8 May 31, 2009 02:19 AM
