Old Mar 06, 2012, 05:54 AM
starscream4002 is offline
Find More Posts by starscream4002
starscream4002's Avatar
Tabriz, Iran
Joined Sep 2008
just takes 5 minutes to make a reliable adapter out of heatshrink tubing. for making it lighter you can remove some or all the CF used to re-enforce the tail and cut and add a depron gusset.(just like on the extra300 3D) that should make it lighter quite a bit.
make the aileron pushrods shorter. This will make your plane lighter and will also make it fly better.
For more power, you could order a nine eagles p-47 motor online. On a GWS 5043 it produces 1.6 times more power than the stock setup.
that's about it!
SS
starscream4002 is offline Find More Posts by starscream4002
Old Mar 06, 2012, 05:56 AM
Tabriz, Iran
Joined Sep 2008
You could also use less tape!
SS
Old Mar 06, 2012, 07:14 AM
BladeScraper is offline
Find More Posts by BladeScraper
Custom User Title
Joined Jun 2011
I barely used ANY tape!!!!!!!!!
I also want a prop saver. and my dad probably won't let me make the heat shrink adapter but I think the CF is better. I don't want to do too much mods. just enough, really. And also, the motor is kind of stuck in it... it is CA'ed in. I probably won't be getting that out! I just need either A.) 2g more thrust, or B.) 2g less weight, and it should be fine. Do you think the 5x4.3 will give me 2-3g more thrust?
BladeScraper is offline Find More Posts by BladeScraper
Old Mar 06, 2012, 11:00 AM
Tabriz, Iran
Joined Sep 2008
definitely! you'll get much better performance with the 5043 props.
Not much tape?! just look at the rudder joint!
SS
Old Mar 06, 2012, 03:49 PM
Grabber5.0 is offline
Find More Posts by Grabber5.0
Professional Plane Crasher
USA, MO, Kansas City North
Joined Sep 2010
Those carbon rods are very light, I can't see replacing any of those with foam saving a significant amount of weight. I didn't think of just using two small pieces of tape for the rudder and elevator, we just did them like they did the ailerons. Not used to building ultra-micros. He hacked some off the end of the wings and rounded the nose a bit more - though I'm not sure why as the entire rudder only weighs 1 gram, so he'd have to cut off a lot more foam to make any difference. Aren't you glad I didn't let you use any hot glue on it?
So starscream - how do you make the adapter from heat shrink? I suppose I could google, but I'm supposed to be working..
Grabber5.0 is offline Find More Posts by Grabber5.0
Old Mar 06, 2012, 04:58 PM
Custom User Title
Joined Jun 2011
Dad...
I need this so I can get more power:
http://www.hobbyking.com/hobbyking/s...zone_Etc_.html
and someone told me how to do the heatshrink.... let me find it.
ah, here it is.
"Probably the cheapest(and maybe lightest) method of mounting the 5*4.3 (which i have used) is using layers of heatshrink on the shaft and then slightly sanding it while it's spinning till you can get a snug fit on the prop. I can post pics if you'd like."
-From StarScream
I need that battery and if you can do the heatshrink thing that would be nice.
Old Mar 06, 2012, 05:45 PM
Custom User Title
Joined Jun 2011
Video:
Aileron Test/TechOne mini Yak-54 build update part 2.mp4 (1 min 0 sec)
Words for people who can't see YouTube (StarScream, etc.)
Ailerons are set up in a interesting way; the 2, AS2000L servos are up right behind the motor, making the CG a bit forward. It works great; but i wish I had cut the carbon fiber rods for the push rods a bit shorter. The carbon fiber pushrod is CA'ed to the original pushrod for the ailerons on the UMX Extra 300 3D, which I cut the Z-bend off of. I CA'ed it with Super thin CA glue from HobbyTown, (cures in 1-3 sec.!) and then heat-shrinked it, then put a tiny drop of CA on the ends of the heatshrink, to be sure of bond.
It works fine, but like I said, "...I wish I had cut the carbon fiber a bit shorter."
Old Mar 07, 2012, 11:29 AM
Tabriz, Iran
Joined Sep 2008
you'd better get the 160 mah version. more flight time with little weight gain.
I shrink the heat shrink with a soldering Iron. I forgot to mention, shrink the layers of the heatshrink on a non-threaded shaft smaller than the extra300 shaft (I used 1mm wire) till you get it larger than the 5043 prop's 4mm hole and after taking it off and mounting it on the gearbox shaft, power it up and sand it till you get a tight fit on the 5043 props. if you see vibration, try balancing the prop first
you wouldn't like the forward CG if it's intended for 3D... trust me!
SS
Old Mar 07, 2012, 01:23 PM
airheli1201 is offline
Find More Posts by airheli1201
United Kingdom, England, Milton Keynes
Joined May 2007
kpilot,
have you flown it yet?? I just got back from flying my almost wreaked extra 300. I just realised today how much eaiser it is to hover and do 3d with the cg way back. And I mean way back, my battery is placed just above the alieron.
after you have test flown it, you may want to consider placing the aileron servos back on the wing which should save a bit of weight and make the plane much more 3d capable. That's how I plan to set up my techone once I totally wreak my extra 300 beyond repair.
airheli1201 is offline Find More Posts by airheli1201
Old Mar 07, 2012, 04:07 PM
Custom User Title
Joined Jun 2011
Airheli:
I can't fly it because I don't have the rudder and elevator push rods yet. I need to buy new carbon fiber as the stock ones aren't long enough.
Also, I found it is actually easier to hover (at least with my Edge 540) wehnthe CG is where it is recommended or a bit forward. I don't know why, but...
StarScream:
Thats a bit confusing...
How do you do it? Can't you just shrink it onto the shaft a bit bigger than the hub of the prop, then sand it down til it fits? and how will I make sure the prop is completely straight (not crooked) meaning it's facing exactly forward?
Old Mar 07, 2012, 04:29 PM
Custom User Title
Joined Jun 2011
Well, my dad says I can't do the heatshrink thing. But I am going to use the one that the guy recommended on the other forum (Jimsomething?) because also I can take the prop off
Custom User Title
Joined Jun 2011
also,,,,,, the 160mah version are ALWAYS out of stock.
Old Mar 07, 2012, 04:32 PM
Custom User Title
Joined Jun 2011
I'll get them when they're back in stock.
Old Mar 07, 2012, 04:55 PM
Joined Sep 2010
Well Keith, when you were hovering the unfinished TechOne in your room, where did you have the CG?
-- Sent from my Palm Pre using Forums
Old Mar 07, 2012, 05:20 PM
Custom User Title
Joined Jun 2011
um...
with the E-Flite 150mAh it balanced right behind the AR6400L.
Alert For Sale: E-Flite Ultra Micro 4-Site, BNF, $60 LPU SargeAF Atlanta Area RC 6 Jan 02, 2012 05:59 PM
Found E-Flite Ultra Micro 4-Site GOOD condition BladeScraper Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Dec 30, 2011 03:08 PM
Sold LPU E-FLITE Ultra-Micro 4-Site oosul Aircraft - Electric - Airplanes (FS/W) 1 Oct 12, 2011 05:58 PM
Sold E-FLITE Ultra-Micro 4-Site bnf\pnp oosul Aircraft - Electric - Airplanes (FS/W) 3 Oct 12, 2011 01:42 PM
Found E-FLITE Ultra-Micro 4-Site bnf 3d astronaut Aircraft - Electric - Airplanes (FS/W) 1 Oct 12, 2011 06:57 AM
