Old Feb 09, 2012, 06:08 AM
space 1 is offline
Find More Posts by space 1
USA
Joined Apr 2007
great job. glad to see it work. I would try larger prop cut down it should give more surface at tip. I know its hard to after it fly's
space 1 is offline Find More Posts by space 1
Old Apr 05, 2012, 08:49 PM
Janusz Jawien is offline
Find More Posts by Janusz Jawien
Janusz Jawien's Avatar
Los Angeles Van Nuys, California, United States
Joined Apr 2002
Viggen in balsa (mostly)
I have to thank Fitz for inspiration and great help to start with this project.
I started my own first serious scratch build and I am having really good time using Zirolli plans and modydying them to my needs and taste.
I wanted to do this model little bit less "boxy" and add some "scale" features rounding the intakes, avoiding the cheatting hole, creating intake ducts, adding the retracts and most likely working canards. I am planning on keeping the aileron size as by the plans and getting serious
flaps on the rest of the wing.
The propulsion will be from 70mm HET fan with 2W-20 and 4 cells.
Any advice will be greatly appreciated!
Janusz
Janusz Jawien is offline Find More Posts by Janusz Jawien
Old Apr 05, 2012, 10:08 PM
AIR SALLY is online now
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
looking good JJ
AIR SALLY is online now Find More Posts by AIR SALLY
Old Apr 05, 2012, 10:31 PM
flyingfitz737 is offline
Find More Posts by flyingfitz737
United States, IL, Edwardsville
Joined Dec 2011
Looks great! I am anxious to see how that fan works. Also interested in what your finished weight will be.
flyingfitz737 is offline Find More Posts by flyingfitz737
Old Apr 05, 2012, 11:34 PM
Joined Apr 2002
Thank you guys !
Sure shot that this thing will not be light like Roger's Draken, the balsa I used were mostly
crappy "lumber" from Michales that I inherited from my friend.
I will try to keep the weight reasonable by flying on a smaller pack at least to begin with.
I am not interested in speed demon ...just a nice and easy flying model... the delta wing should give me that.
Any advice about the finish will be very helpful for me. I want to glass the front portion of the fuse and cover the wings with light covering then cover it lightly with Duplicolor grey primer -
then go from there with some high contrast to be able to keep eye on the model...
Discussion SAAB Viggen AJWoods Micro EDF Jets and Power Systems 11 Apr 05, 2014 07:19 PM
Discussion AJ-37 Viggen Sture Smidt Foamy EDFs 5 Dec 13, 2011 02:37 AM
For Sale Ziroli F4U-1 Corsair RTF kksejwilson Aircraft - Fuel - Airplanes (FS/W) 7 Nov 02, 2011 01:07 PM
Off Site ~Closed~ WINDSHEAR II Aircraft - Fuel - Airplanes (FS/W) 0 Oct 28, 2011 10:14 PM
Discussion Electric Motor for a Ziroli Stuka Greybranch Electric Warbirds 3 Sep 17, 2011 09:20 AM
