Old Feb 02, 2012, 06:42 PM
flyingfitz737 is offline
Find More Posts by flyingfitz737
United States, IL, Edwardsville
Joined Dec 2011
Are there any small diameter 3 or 4 blade props that will hold up at 38000 rpm?
flyingfitz737 is offline Find More Posts by flyingfitz737
Old Feb 02, 2012, 11:23 PM
LuvEvolution7 is offline
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
highly unlikely. after saying that, larger, cut down props will likely survive at these RPM's because there will be more meat at the root to handle the load. expect bigger loads on the motor though because of larger angle of attack of the blades.
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old Feb 03, 2012, 06:51 AM
space 1 is offline
Find More Posts by space 1
USA
Joined Apr 2007
let's say you got 3500kv motor ods of it ever reaching 3800rpm is un likely under load. use amp meter to ck. only way to ck rpm is with rpm gage not motor spec.
space 1 is offline Find More Posts by space 1
Old Feb 03, 2012, 07:36 AM
space 1 is offline
USA
Joined Apr 2007
PS battery C rating also
Old Feb 03, 2012, 09:11 AM
Joined Dec 2011
I know from flying the stinger and rifle speed 400 planes the 2 blade apc will hold up no problem. These props will also load the motor, speed control and battery in a predictable way. As long as these are producing suitable thrust, I think I will focus my attention here. Will report on results. Thank you all for the input!
Old Feb 07, 2012, 04:31 PM
Joined Dec 2011
Motor is wired. All I lack is one pushrod. I will try and fly tomorrow if the weather is ok. Final stats for the maiden:
All up Weight with 2200 mah pack is 1lb 9oz.
Wing loading is 9.4 oz/sq ft.
The motor is pulling 29-30 amps and 300 watts with the APC 4.1 prop.
Approx 200 watts/lb
The canard is fixed for the maiden
Potential problems I see:
It pulls with authority, but the thrust is nowhere near 1:1. Thrust was measued at 1 pound for a .67 thrust to weight ratio.
I am using the cg off of the original Zirolli plans. Who knows if this is optimal?
Control throw is off the original Zirolli plans. He used separate surfaces for elevator and aileron. I am using elevons with 40% differential and 30% expo dual rated to 80%. Will it work?
The thrust line is high. There is a significant tendency to pitch down with the power on. I feel a prog mix coming on! I think this will be the biggest challenge to overcome.
Wish me luck. I will try and get someone to video for me.
Last edited by flyingfitz737; Feb 08, 2012 at 12:45 AM. Reason: Measured Thrust Added
Old Feb 08, 2012, 06:01 AM
AirX is offline
Find More Posts by AirX
EDF rules... :)
AirX's Avatar
United States, TX, Katy
Joined Nov 1999
Good luck.
Eric B.
AirX is offline Find More Posts by AirX
Old Feb 08, 2012, 03:35 PM
Joined Dec 2011
Success! Stay tuned for video.
Old Feb 08, 2012, 04:38 PM
Janusz Jawien is offline
Find More Posts by Janusz Jawien
Janusz Jawien's Avatar
Los Angeles Van Nuys, California, United States
Joined Apr 2002
Congrads! Tell us more!
Janusz
Janusz Jawien is offline Find More Posts by Janusz Jawien
Old Feb 08, 2012, 04:49 PM
space 1 is offline
USA
Joined Apr 2007
Good
Old Feb 08, 2012, 05:17 PM
Joined Dec 2011
Depron Ziroli Viggen (3 min 51 sec)
Old Feb 08, 2012, 05:27 PM
pdawg is online now
Find More Posts by pdawg
Need 4 Speed!
pdawg's Avatar
United States, OH, Dayton
Joined Apr 2004
Well done! You guys took a very nice methodical approach! Definitely flew better with each flight! Are you planning to boost the performance?
pdawg is online now Find More Posts by pdawg
Old Feb 08, 2012, 05:47 PM
Joined Dec 2011
Thanks. The biggest performance killer is the pitching moment from the thrust line being above the vertical cg. It takes a ton of lift to overcome the pitching moment. When the power is pulled it floats like a feather. I plan on moving the battery up as high as possible to help control this unwanted moment. We tested it statically (sp?) and it does make a difference. Once that is optimized as much as it can be, I plan on making the canard functional for pitch. A little prog mix to cancel the remaining moment and it should be reliable throughout the flight regime. I have decided not to make the rudder functional or include the retracts. This will be a hand launch, outdoor-only airplane.
Old Feb 08, 2012, 06:42 PM
Frenche is offline
Find More Posts by Frenche
ooooh yeah
Frenche's Avatar
Ballarat, Victoria, Australia
Joined May 2004
Congrats! It looked great in the air. I swear I have those plans laying around here somewhere....
Frenche is offline Find More Posts by Frenche
Old Feb 08, 2012, 08:55 PM
Joined Apr 2002
WOW!
Now you have "deliciuos" looking well flying airframe to play with adding the flying canards etc. Really nice low key project!
Discussion SAAB Viggen AJWoods Micro EDF Jets and Power Systems 11 Apr 05, 2014 07:19 PM
Discussion AJ-37 Viggen Sture Smidt Foamy EDFs 5 Dec 13, 2011 02:37 AM
For Sale Ziroli F4U-1 Corsair RTF kksejwilson Aircraft - Fuel - Airplanes (FS/W) 7 Nov 02, 2011 01:07 PM
Off Site ~Closed~ WINDSHEAR II Aircraft - Fuel - Airplanes (FS/W) 0 Oct 28, 2011 10:14 PM
Discussion Electric Motor for a Ziroli Stuka Greybranch Electric Warbirds 3 Sep 17, 2011 09:20 AM
